Question about GE GSL25JFPBS Side by Side Refrigerator
GE MODEL GSH25JSRF-SS PROBLEM HELP PLEASE
Fridge started to make a clicking sound, removed rear panel and noticed fan was not spinning, clicking was coming from the circuit board also located in rear, I unpluged the quick connector to the fan and clicking stopped and compressor started , do I need a fan or a circuit board,
  • 8 more comments
  • PGRACE3 Aug 30, 2008
    ICE WOULD NOT DISPENSE, THE BACK OF THE FRIDGE HAD A CLICKING NOISE. THE FREEZER AND THE FRIDGE STOP WORKING.
    TOOK THE BACK PANEL OFF AND THE MOTHERBOARD HAD A CLICKING NOISE. THE COMPRESSOR IS VERY HOT.
  • Anonymous Sep 26, 2008
    I have the same problem.
  • Anonymous Oct 13, 2008
    Same problem.
  • lsh1 Nov 17, 2008
    I have the exact same issue.
  • azpnd Nov 17, 2008
    Fan not running and a clicking sound. GE said approx $350 to fix (phone quote). The fridge is just 2 1/2 years old!
  • Anonymous Dec 01, 2008
    I have a different model, just 3 years old and had to pay $315 to get a new motherboard today, GE needs to do something about this.
    I have the same problem, our motherboard went and the fridge is just 3 years old. I had to pay $315 to fix it today.
  • Anonymous Dec 04, 2008
    I have the same issue, too. Does replacing the motherboard work?
  • Anonymous Dec 20, 2008
    We have the same problem...
  • JoeMerchant Jan 12, 2009
    Click of death - water/ice through door light dims, nothing is dispensed, clicking starts, cooling stops.
    Put a call into 1-800-GE-CARES, they confirm there is a replacement program but cannot guarantee that the $79.99 service call will be covered just by description over the phone. Welcome to Vegas - $80 for a service call that _might_ give a free repair, or might tell you that you need to spend another $250 vs $800 for a decent new fridge that probably will run for 20 years without problem.....
I had the same problem back in March. First the water and ice dispensers stopped working, then the clicking started and the compressor wouldn't turn on. I replaced the circuit board and everything started working again, until today. This is a very common problem with the circuit board on these refrigerators. Do a search for "GE circuit board" and you'll see what I mean. GE issued a service bulletin to its technicians that this service should be provided free of charge, and anyone who already paid to have the circuit board replaced will be reimbursed. I wish I would've known about it 6 months ago. I will be calling GE Consumer Affairs on Monday to get this resolved.
Posted on Dec 13, 2008
  • Mike_Hay Dec 13, 2008
    Here's the bulletin:
    November 7, 2006
    Dear GE Customer Care Servicers,
    GE Consumer & Industrial places a very high priority on product quality and customer satisfaction and thus continuously assesses our product reliability. Recent analysis has discovered a potential problem with the main circuit board on a limited number of refrigerator models, which could lead to lower than anticipated life expectancy on that component. Therefore, if the main circuit board fails, GE Consumer & Industrial will replace this part free of charge to the consumer until further notice.
    Models Covered: see attachment
    The models affected are side-by-side plastic liner, side-by-side metal liner, bottom freezer two door and bottom freezer French door. The models were produced between May 2005 and August 2006 (HH – RL serial range) and are included in this program. See enclosed list.
    Potential Additional Covered Parts:
    Specific parts involving the failure of the main board are included in this program. These parts are limited to the following:
    -Evaporator Fan failure, only if accompanied by a Main Board failure
    -Dispenser Board failure, only if accompanied by a Main Board failure
    The main board part number in cases in WR55X10552. Please use your normal warranty MA00 job code for this repair. If you encounter an evaporator fan or dispenser board failure due to the above main board, please include on your invoice and use the normal MA00 job code. It is critical that you verify the proper functioning of the unit including the evaporator fan motor and dispenser board before leaving the home to avoid a repeat call.
    Units may be in or out of the standard 1-year product warranty and both instances are covered under this concession program.
    If you previously completed this repair and charged the consumer, please send a copy of the service invoice to General Electric Consumer Relations, PO Box 10736, Norfolk, VA 23513 or fax a copy to 1-877-299-0725 so that we may issue a refund to the consumer.
    Sincerely,
    Richard Zutterman
    GE Consumer & Industrial Appliances
    Richard Zutterman
    National Service Manager
    Consumer Home Services
    Appliance Park, AP6-239
    Louisville, KY 40225
    USA
    T 502-452-3168
    F 502-452-7940
    Richard.Zutterman@ge.com
    ...and the affected model numbers:
    Plastic Liner Models
    Serial # ZH - RL
    Dec 05 - Aug 06
    Metal Liner
    Serial # MH2 - AL2
    Jul 05 - Jan 06
    DSF25MG PSI23NS BSS25JFR
    Bottom Mount
    Full Door
    Serial # TH0 - ML0
    Oct 05 - Jul 06
    DSS25MG PSI23SG BSS25JSR GBS20 DSS25MS PSS23MG DSS25JFP GBS22 GSL25LG PSS23MS GSH22JFR GDL20 GSS23LG PSS23NG GSH22JSR GDS20 GSS23LS PSS23NS GSH22UFR PDF22 GSS25LG PSS23SG GSH25JFR PDS20 GSS25LS PSS26MG GSH25JSR PDS22 GSS25MS PSS26MS GSH25UFR PDW22 GSW25LS PSS26NG GSL22JFR SDL20 PCF23MG PSS26NH GSL25IFR PCF23NG PSS26NS GSL25JFR
    PCF23NH PSS26SG GSS20DBP PCT23SG PSS26SH GSS20IBP PCT23SH PSS27NG GSS20IEP PIT23SG PSS27NS GSS22IBP PSC23MG PSS27SG GSS22IFR PSC23MS PSS29NG GSS22JER PSC23NG PSS29NH GSS25IFR PSC23NH PSS29NS GSS25JER
    PSC23NS PSS29SG HSM25GFR
    Bottom Mount
    French Door
    Serial # HH0 - ML0
    May 05 - Jul 06
    PSC23SG PSS29SH HSS25GFP PFS22 PSC23SH PST26NG SSH25KFR PSF23MG PST26SG PSF23NG PST26SH PSF26MG PST27SG PSF26NG PST29NH PSF26NH PSW26MS PSF29NG PSW26SG PSF29NH PWT26SG PSH29NH SSL27RG PSI23MG ZFSB26D PSI23NG
    Problem Solver:
  • 8 Answers
I fixed my motherboard.
Board WKKT Model 0158-00-04
Board GEA Part 200D4854G013
I replaced both 47uF x 400V capacitors - one of them was bulged. The bad one was open, and the other still had it's nominal value.
I tryed to make the refrigerator work, to no avail.
After a careful inspection, i replaced both 470uF x 25V capacitor (c29 and c30, i guess - near the 7805 regulator). Both had around 0.5% of their original value, and i belive it was the source of the problem.
Everytime the processor tried to start the relay, the power level dropped and the motherboard "rebooted"... and thus the cycles and clicks from the relay.
The refrigerator got back to life!
There was a recall by GE on November, 2006.
Call GE at 18003861215, option 3. Mention the recall and maybe it's still valid a free replacement.
Posted on Dec 17, 2013
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
Gsh25jsrf side by side ge it is making a buzz clic clic from the back buzz from compressor clic from circuit board came back on after spinning the fan worked for a night then back to noise and not working
it sound like the compressor is overheating and the start relay could be failing because of the holiday and possible not getting a tech out there, pull the frig out from wall and remove the back panel and get an portable fan and let it blow air on compressor to keep it cool, If you here the sound on the covered axcess panel on the back the mother board is questionable. Hope this helps....
Dec 24, 2010 | GE GSH25JFR Side by Side Refrigerator
Model GSH25JSRF SS The fan in freezer clicking and working intermittley, the augor in the ice machine and the water dispensor are only working part of the time. You can hear a clicking sound as the fan...
On this particular model the fan and all operations are controlled by the main board on the back of your Refrigerator. This is part number wr55x10942. Less than $200.00 and not hard to change out.
Jan 31, 2010 | Refrigerators
GE Model GSH25JSRF SS is clicking non stop, the click comes from a small panel on the back right of the fridge. Started out that the water and ice dispenser didn't dispense. Then the clicking just came...
Is it still cooling? I had an issue where there was a clicking noise from the back panel and the fridge did not cool. Pulling off the panel the noise seemed to from a box on the circuit board. Turns out there was a problem with the controler board and after some research I found that the board was covered under a recall. GE ended up sending a guy out to replace the board at no charge. Pretty cool being that if was after the warranty had expired; but I guess it makes sence since there was a recall. Good luck.
Dec 10, 2009 | GE GSH25JFR Side by Side Refrigerator
Fridge not cooling, freezer not freezing even on coldest settings
From what you are describing, you have a refrigerant leak. The freon has leaked from the system, The compressor will still run and evrything looks fine. To double check you will have to have someone hookup gauges to the system and verify that the charge is lost.
It may be possible to find and repair the leak. This is not always possible as some of the system is virtually inaccessible in many refrigerators.
Make sure if you do have someone repair the system that they evacuate the system very well and do a good vacum test before recharging the system.
This should help you to solve your problem.
Thanks for using Fixya!!
Heatman101
Nov 23, 2009 | Refrigerators
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side fridge/freezer. Fan in fridge is not spinning.
Replace that fan that blows the cold air into the refrigiator.
Jan 06, 2009 | Refrigerators
GE GSL25JFPBS Side by Side Refrigerator Logo
5,246 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
