Question about KitchenAid Pro Line Coffeemaker Coffee Maker
E2 error code
My proline coffee maker keeps displaying an E2 error code and stops brewing. How do I fix it?
  • 1 more comment
  • qdskinner Sep 01, 2008
    I am having the same issue
  • Anonymous Dec 26, 2008
    The coffee maker is stuck in the E2 mode. I have unplugged, descaled which was hard because it was still in the E2 mode. It was not a cheap coffee maker but it is so unreliable.
  • pelham mom Mar 01, 2009
    I had the same problem. I descaled and tried everything in the manual.  I contacted customer service (thankfully, I had sent in the warranty) and was sent a replacement maker.
In reading the manual for this coffee pot, it needs to have the descaling procedure run. The manual lists running a mixture of 6 cups water and 6 cups vinegar in a normal brew cycle...twice to clean hard water deposits from the machine. It says to make sure to remove the filter basket. Once the procedure is complete, unplug the unit and replug in to remove the E2 code.
Posted on Sep 01, 2008
A E2 ON A PRO LINE KITCHENAID AFTER YOU DESCALE WITH NO LUCK CAN BE THE AUTO THERMO RESET SWITCH ON TOP OF THE HAETER ASSEMBALY. IF THE THERMO RESET TRIPS BEFORE THE LOWER FLOAT SEES NO MORE WATER THE UNIT WILL ERROR WITH A E2. THE THERMO RESET CUTS OUT AT 110 DEG C AND RESETS TO ON AT 95 DEG C. THATS WHY WHEN THE UNIT SITS FOR AWILE YOU CAN TURN IT ON AGAIN. IF YOU SIT REAL QUIT WHEN IT CUTS OUT AND LISTEN AFTER ABOUT 2-3 MIN YOU CAN HEAR A CLICK OF THE THERMO RESET SWITCH. YOU CAN FIND THESE RESETS THERMO SWITCHES ON THE INTERNET FOR ABOUT $ 2.00.
Posted on Sep 02, 2012
  • 2 more comments
  • Mark Dec 01, 2012
    Pete B - can you point me toward a website where I can buy this thermo switch? Thank you very much
  • Mark Dec 01, 2012
    Pete B - Can you point me toward a website that sells this thermo switch? Thank you very much
  • PETE B Dec 01, 2012
    I GOT MINE FROM EBAY. THEY DO NOT COST THAT MUCH. I THINK THE TEMP IS 110DEG F. YOU CAN JUST SERCH FOR THERMO CUT OUT IN EBAY.
    IF YOU LOOK AT YOUR OLD ONE AND WIPE OFF THE THERMO GREASE IT SHOULD HAVE THE TEMP MARKED ON IT IN SOME FORM OF NUMBERS. IT MAY ALSO BE MARKED IN CELCIUS SO WATCH THAT. WHEN YOU PUT A NEW ONE ON YOU MUST USE NEW HEAT SINK COMPOUND. YOU CAN GET THAT FROM RADIO SHACK OR A COMPUTOR CENTER. IT IS THE SAME THEY USE ON COMUPTOR CPU'S.
    New Friend:
Cbrown1232: Mine did the same thing, so I tipped it upside down over the kitchen sink and drained it. When I tried refilling machine again I discovered water was now flowing through it freely (a valve must have opened when I tipped it) so I was able to simply pour several rounds of cleaner through the top of the machine, while catching it from below with another container. Once I did that several times and plugged it in again, the E2 code was gone and it started to cycle normally.
Posted on Oct 31, 2014
Yes gdskinner, that's what the manual says.
The problem is that you cannot run a descaling procedure while the E2 message is displayed. It tells you to reset it by unplugging the machine for 30 seconds. Except that mine refuses to reset - it's stuck at E2!
Posted on Oct 01, 2008
  • keithspla397 Oct 24, 2010
    Same here anyone found a sollution if out of warranty and Kitchenaid refuses to replace or repair?
I have a 12-cup DCC-1200 black & chrome Cuisinart coffee maker, like the one pictured below. Once every three weeks or so the brewing function goes into overdrive and, instead of brewing a pot of...
It sounds like there's a problem with Charcoal Water Filter. What it does is it eliminates chlorine, calcium, bad tastes and odors on the brewed coffee. You can try to clean it manually or if that doesn't work, replacing that might fix the problem.
Keep us updated. Hope that helps.
Sep 09, 2008 | Cuisinart DCC-1200 Coffee Maker
My black & decker coffee machine stop brewing coffee, sound like is going to keep working but is not .
Does the display work? Does the platter heat up when it is turned on to brew? If yes to both, this string might address the problem. Email me at the posted address if you need the part.
Jan 10, 2011 | Black & Decker Spacemaker 10-Cup Coffee...
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
I put the coffee on to brew and it stops after a few cups
If the display works and the platter heats up when it is turned on to brew, this might be the problem and solution. Please read both (scroll).
May 30, 2010 | Black & Decker Spacemaker 10-Cup Coffee...
Error Code 8 The machine won't make coffee and keeps trying to eject a puck over and over before it stops and Error Code 8 shows on the display.
I have the same problem..... you have a faulty brew unit... you will need to send your unit to Jura USA for repair..... I know this the hard way as I cant get them to sell me the darned spare part....
Nov 16, 2009 | Jura Capresso Impressa S90 Espresso...
Kitchenaid Proline program light doesn't stay on & it won't auto start brewing
Pro Line appliances have an extended 2-Year hassle free warranty on them. If you are experiencing any problems with a Pro Line coffee maker, I would suggest calling Kitchenaid Customer Service.Their toll-free telephone number is:
1.800.541.6390.
Aug 03, 2009 | KitchenAid Pro Line Coffeemaker Coffee...
Error keeps popping up
PROBLEM
CAUSE
SOLUTION
3 beeps sound and E:rr flashes on LCD display (31)
prog (24) was pressed before clock time was set
auto (23) was pressed while no program was stored
TSB was pressed (25) before brew cycle was complete
Set clock time, then set the program
Set the program first.
Wait until brew cycle is complete and 2 beeps sound
Mar 05, 2009 | GE 106591 Coffee Maker
I have Err 4 on my coffee maker... help
If “Err4” appears on the brew
timer display:
A button is jammed. Unplug the
Coffee Maker, press each button
several times, then plug the Coffee
Maker back in. (If the Coffee Maker
has been stored or used in a cool
environment, warm the unit to
normal room temperature before
doing this.) If “Err4” appears again
on the display, repeat this procedure.
• If “Err1”, “Err2”, or “Err3”
appear on the brew timer
display:
Press the On/Off Button to reset the
Coffee Maker. If the error codes
reappear, there is a problem with the
Coffee Maker electronics. Please refer
to the Warranty and Service section
beginning on the following page.
If the problem cannot be fixed with
the steps above, please refer to the
Nov 25, 2008 | KitchenAid KCM511 Coffee Maker
Takes 2 hours to brew one pot
sounds like a loose connector to the main heating coil
Feb 16, 2007 | Emerson EM83701 Coffee Maker
KitchenAid Pro Line Coffeemaker Coffee Maker Logo
2,292 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
