Question about HP PSC 1210 All-In-One InkJet Printer
Problem with HP PSC 1210 printer
The alignment is off when printing documents. Items print in a "wave" form. Spreadsheet lines print with a section up, then a section down, etc. Is there a way to fix the alignment?
  • 1 more comment
  • nycaw Jul 26, 2008
    The
    The strip appears very clean. If I scan a document, the result comes out fine. The problem happens when trying to print from my computer. Is there a setting that I need to adjust?
    Got it....THANK YOU!!!
    Scholar:
  • 121 Answers
SOunds like your linear encoider is dirty.
If you look back along the rail that the carriage moves back and forth on, you should see a thin plastc strip...almost clear...going accross. You have to make sure that's clean. If you clean it real well with a lint-free cloth, and it still doesn't work, it needs to be replaced. They're probably not available and you might need a new machine.
Posted on Jul 26, 2008
  • Eric Engel Jul 26, 2008
    Yes...I'm talking about when you print.
    The thing that the cartriges go in...It should move back and forth. If it doesn't move, unplug the printer in the middle of a print, and you'll be able to slide it back and forth.
    Behind that, you should see a thin sheet of plastic. It runs along the length of the printer, and it's about a half inch wide.
Black ink cartridge only uses about 50% of ink before it needs relacing.
Posted on Jul 28, 2008
Printer printing blured images and text. It looks as if the printer prints a line then about 1/8 to 1/16 if an inch it prints the same line again.
You need to run a new alignment on the machine, Assuming you have the software installed open up the hp help center and print an alignment page after that look at the numbers and letters and line up the marks by selecting the numbers closet to the perfect alignment that you can see after you have finished click on the front of the printers OK button.to finish they try printing a new page. If this does not help try updating your software at http://www.hp.com.
Dec 24, 2009 | HP PSC 1210 All-In-One InkJet Printer
I have printer HP PSC 500 S/N SGH02E112T WORKED FOR 5 YRS - NOW WILL NOT PRINT EXCEL SPREAD SHEETS OR WORD DOCUMENTS - STILL PRINTS EMAIL AND INTERNET DOCUMENTS HAVE HAD OTHERS CHECK SETTINGS...
Friend,
There's apparently a problem bwtween your Office suite and the spooler. Usually uninstalling/reinstalling the Office suite will fix the problem. (please do a backup of all your Office documents before proceeding!)
When reinstalling, please make sure that any antivirus program is shut down or deactivated during install, in some cases for example Norton Antivirus will block files that need to be updated, causing problems. You SHOULD use some form of virus protection when using your computer, don't get me wrong! :)
//Al
Mar 08, 2009 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1200 color problems with website prints
It strabge... Anyway u just clean your print heads and nozzles... it shuld make it fine... or just replace ur catridge...
Sep 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet print problem
Follow the steps below to enable or disable the cover page option in Microsoft Word.
  1. In Microsoft Word, click File , then Print . The Print window opens.
  2. In the bottom-left of the Print window, click Options . A new Print window opens.
  3. Do one of the following:
    • Select Document Properties to enable cover page printing.
    • De-select (remove the check mark from) Document Properties to disable cover page printing.
  4. Click OK to close that window.
  5. Click OK again to print the document.
Jan 14, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC1210 not printing all items on the document with vista
The issue is occuring due to the Windows Vista . You can get solution by using below web link :
http://support.microsoft.com/kb/934633
Please copy the entire URL and paste it in a new window of Internet Explorer and press Enter.
Follow instructions from above link.
Thanks
Silan
Dec 24, 2007 | HP PSC 1210 All-In-One InkJet Printer
Can't print from Adobe Acrobat
You did update the printers software to VISTA drivers, correct?
Nov 10, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
248 people viewed this question
Ben Johnson
