Sony CMT-SE1 CD player works fine for weeks then suddenly jumps tracks and gets into a loop. Not CD, as it happens with new CDs. Sometimes it will jump to end of CD. Problem appears to be electronic rather than mechanical as it disappears just as quickly as it appears.
I reinstalled the original factory settings as per their instructions. All seems to be well.
Cheers.
Posted on Jul 27, 2008
I have a technics SL-CH505 compact disc but it will not play burnt CD;s any suggestions my other technics SL PG 400A plays them noproblem
The Optical Pickup(laser) may be weak. It takes much more power to record than play, which I guess it works.
Oct 13, 2014 | Technics Audio Players & Recorders
Hi, the cd player for this Sony system works fine with most of my cds. However, some of my older ones and burned ones don't produce any sound. The system recognizes the cd's cause I can skip tracks and see...
The only audio formats supported by the CMT-BX20i are "CD-DA and MP3". When DVDs were first getting started, they didn't have standardized audio and video formats. The burned videos are likely AC3. For both your old and burned DVDs, you can convert them on your computer with an audio video program like Nero or DVD Videosoft.
Mar 06, 2011 | Sony CMT-BX20i Shelf System
TABLE ERROR SHOWS IN WINDOW
What probably happened is that some CDs fell off their tracks and are blocking the main wheelhouse from turning. To solve this you will need a philips head screw driver. First unplug the machine. You will need to remove the top of the unit (which slides off towards to the back) after removing the 9 screws (2 top, 4 side, and 3 top back). Once you slide off the cover, you will expose the wheelhouse and you should see the CDs that fell off. Simply take the cds out. Once you have taken out all the CD that came off the tracks, slide the cover back on and screw in the 9 screws. The CD player should work again. This worked for me and hopefully will work for anyone encountering this error.
Dec 01, 2009 | Sony CDP-CX300 CD Player
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
Sony system not reading discs
if cleaning does not work, then you need to replace the laser, this not hard to due if you have some technical
Jul 18, 2009 | Sony Audio Players & Recorders
Only records Lps and CDs, but not other cassettes
there are programs on the net that will copy from tape to cd via the computer if you have a cd writer on the pc hope this helps regards Jim
May 02, 2009 | Audio Players & Recorders
My tracks don't play in the recorded order, list I made them.....
If song tracks jump or skip then it is problem of cd player like optical laser is dirty / clogged,
and if track doesn't jump or restarts in middle of playing back then cd player is just fine,
Please check cd creator software settings.
Dec 18, 2008 | Sony CDX-MP40 CD Player
CMT-BX1 won't play CD's - "No Disc"
If they're clean (i.e. not scratched up or dirty) store-bought CDs (burnt CDs can be iffy in some players), then yes you should return it.
Sep 16, 2007 | Sony CMT-BX1 Shelf System
Reading CD message
You can use a CD Cleaner as a first step, if it didn?t work the problem need an expert technician to clean the lens or replace it. Good Luck Toufic Malek
Jun 04, 2007 | Sony CMT-HPX9 CD Shelf System
Open Questions:
 Grubhead
Grubhead
