Problems installing a printer
I am having problems installing my EPSON LX-300 printer.i dont have any disc or floppy disc to install it cause i alredy miss placed it.please help me solve this problem. icannot install my printer driver for epson c43 sx printer
    Problem Solver:
  • 6 Answers
SOURCE:
I dont have a installer for may epson lx-300 how can i install???
You can download the driver here (make sure to select the correct operating system):
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=75683&infoType=Downloads
Apr 04, 2011 | Epson LX-300+ II Matrix Printer
I want to install lx-300 on line because i dont have available cd intaller
Here is the Epson driver guide for the lx-300+ http://tech.epson.com.au/downloads/RedirectLink.asp?ProductID=lx300plusII&Email=&DownloadID=5278
It will guide you to the drivers you need. Most are found on the windows install CD
Sep 09, 2010 | Epson LX-300+ II Matrix Printer
I wanted to download the driver for epson lx-300
wanna free downlode software of Epson Lx-300+
Apr 05, 2010 | Epson LX-300 Matrix Printer
The printout is code with epson lx 300
try to change your printer cable and dont forget to check your printer driver if it is default to epson lx300+
Mar 02, 2010 | Epson LX-300 Matrix Printer
How do i install an epson lx 300 printer to a vista machine using a parallel to usb converter? i can't locate nor create usb 001 port with the driver cd of the said printer.
1. Start
2. Settings
3. Printer and Faxes
4. Add a printer
5. then Next
6. then Next
7. then Next
8. then Next
9. select Manufacturer name : Epson
10. select Printer name : Epson LX-300
11. Next
12. Windows will automatically install the driver for your Printer
Jun 21, 2009 | Epson LX-300+II Matrix Printer
Installation of LX 300 epson printers
i need software driver for epson lx 300 to install the printer
Sep 08, 2008 | Epson LX-300+ II Matrix Printer
what is your operating system? If you have windows XP or Vista, you dont need to download anything from Epson. Just go to your start menu and look for control panel. In control panel, open "printers and faxes" or "printers and other hardware" then "printers and faxes". Once you are in "printers and faxes" click Add Printer...
An "add printer wizard" will appear in a new window, click next...
On the next screen, choose local printer. And make sure that the option "Automatically detect and install..." is selected. It will start searching... If the wizard did not find the printer, it will come up with a list of manufacturers... From this list choose EPSON and a list on the right side will show you the model names. Look for the LX-300 on the list, it should be there! Install it and you're done... The driver is already included in the windows operating system. You dont need the disc if you have Windows Xp or Vista....
Jun 27, 2008 | Epson LX-300 Matrix Printer
How do you connect it to your computer? What type of cable?
check this link it will give you info if its compatible with vista
EPSON
But you can also use the generic text only driver from vista
Go to control panel
then printers
then add a printer(local), choose port (the type of cable)
manufacturer Generic, Printer generic text only
then click until finish and that should work.
tell me if you encounter an error or something
Apr 26, 2008 | Epson LX-300 Matrix Printer
You can follow the steps below to install a resident printer driver which is part of your operating system.
NOTE: Windows should detect and automatically install devices attached via the Parallel or USB ports on the computer. You should be able to attach the printer, and the "Plug and Play" feature will install the appropriate driver.
If the driver does not automatically install, please contact your Computer vendor. The "Plug and Play" feature may be disabled within your computer.
The resident driver installation should only be used if the printer is not detected and installed.
1. Start by opening the "Printers and Faxes" window. Click on "Add Printer" on the left hand side of the screen.
2. The "Add Printer Wizard" screen will come up. Click on "Next".
3. At the "Local or Network Printer" screen, select "Local Printer" and place a check on "Automatically Detect and Install my Plug and Play Printer". Click on "Next".
4. Windows should report it will check for Plug and Play hardware. It should also detect and install the appropriate resident printer driver.
5. A window will appear and tell you when the process is completed.
*NOTE: If Windows does not detect your printer automatically, you can manually install the printer. Simply select EPSON under manufacturer and select your appropriate model under PRINTERS.
6. When the printer is installed, it will ask you if you would like to print a test page. Check "Yes", then click on "Next".
7. The next screen will display the settings for the printer. Click on "Finish" to complete the installation and print the test page.
May 27, 2006 | Epson LX-300 Matrix Printer
Open Questions:
Computers & Internet Logo
62 people viewed this question
Ekse
Alun Cox
