Check weather u have installed sound driver or not if u have not installed plz install it and use the driver which is compact-able to your system. and if u didnt find it then u can use realtek sound driver it will work u can purchase realtek driver cd from computer hardware shop. and after installation if ur not able to play the sound then check ur sound system by connecting it to another system.
Open control panel, go to sound and audio devices, in the window that opens look under the volume tab make sure your sound is not muted. Also look under the sounds tab and make sure your sound card is selected in the drop down boxes.
Start there and let me know how you do. If this does not work, I have more areas you can look at, but we will start with this.
If this solution helps solve your problem, please remember to leave positive feedback.
Thank You,
Brian
