Question about Gateway MX6912 Notebook
LAPTOP My laptop has a blue screen states checking file system C then states the type of file sx is NTFS and that one of my disks needs to be checked for consistency thenit strats to verify 1 of 3 stages but can only complete 25% then states it is unreadable this is all on a windows blue screen
  • topkopp Jul 26, 2008
    I was able to get into safe mode but now itis stuck on a black screen with several lines saying multi (0) disk (0)rdisk (0)partition (1) windows \system32\Drivers then a bunch of jibberish after each line
    Genius:
  • 1,268 Answers
Reboot it and keep pressing F8. Select boot to Safe Mode.
-Try to uninstall the last application that you installed.
-Try to do system restore as well
Posted on Jul 26, 2008
Error message stop 0x00000024
which operating system ?
If you get the Windows blue screen, you can determine which stop code you have and determine what you need to do in order to get your computer back to working correctly.
First, make sure that you have this error code - Stop 0x00000024 or NTFS_FILE_SYSTEM. This message shows that a problem occurred within Ntfs.sys, the driver file that allows the system to read and write to NTFS file system drives. One possible problem is a malfunctioning SCSI and Advanced Technology Attachment (ATA) hardware or drivers. This can also adversely affect the system's ability to read and write to disk, causing errors. If the computer is using a SCSI hard drive, check both for cabling and termination problems between the SCSI controller and the disks. You will need to periodically check the Event Viewer for error messages related to SCSI or FASTFAT in the System log. You can also use Autochk in the Application log. Try the following. First, Double-click My Computer, select the hard disk you want to check. Then, on the File menu, click Properties. Then, click the Tools tab. Next, in the Error-checking box, click Check Now.
Finally, in Check disk options, select the scan for and attempt recovery of bad sectors check box. You can also select the Automatically fix file system errors check box.
http://answers.microsoft.com/en-us/windows/forum/windows_xp-system/windows-xp-blue-screen-error-message-0x00000024/9d6475ed-dc42-4fa7-a2a2-506c42f6ee63
Feb 24, 2013 | Computers & Internet
Hard drive capacity loss!!
What the re-installation did was partition the HD with the small (24GB) partition and most likely left the rest of the disk un-partitioned. If you are familiar with Control Panel / Administrative Tools / Computer Management / Storage / Disk Management, you may be able to add a second partition to the present one in the laptop. If you see an open area that doesn't appear to have a partition this is what occurred. Right click the "C-drive" line and add a partition.
Sep 18, 2009 | Toshiba Satellite A105 Notebook
Blue screen with error codes
That is probably a disk error, related to the NTFS file system.
Did you try a "chkdsk /f" command to check and fix the disk?
Microsoft has more information on it in the knowledge base.
For further blue screen error troubleshooting check this article.
Jules
Apr 05, 2009 | Toshiba Satellite M35X-S163 Notebook
Error message
That is not an error, Windows is trying to verify that there are no issues with your hard disk. Is what you wrote above all that you see? If so then check disk is freezing before it completes. Try to cancel the chkdsk before it starts by pressing any button when it prompts you to, log into windows, back up everything up that you need and restart your laptop. Worst case scenario you need to reinstall windows on your laptop
Mar 04, 2009 | Dell Inspiron 1525 Laptop Jet Black
Compaq presario V2000 laptop
D: is a partition on your main drive C: NTFS = New Technology File system.
Feb 22, 2009 | Compaq Computers & Internet
Dell Laptop Inspiron 6400 - "Stop Error Screen" appearing
This stop error means that your ntfs file system is corrupt (damage in the file system, bad hard drive data, corrupt SCSI or IDE drivers or a corrupt ntfs.sys file).
There are two ways,you might be able to fix it
1, If you still can access Windows, try to disable any backup programs, virus scanning programs or disk defragmenter tools. Try also to run a hardware diagnostics tool to detect any errors your hard drive might have. And run chkdsk /r to detect and repair any file system structural damage.
2, If you are unable to load Windows. Then you should try to access your ntfs partitions by making a ntfs boot disk with NTFS4DOS (freeware).
After you load the bootable floppy disk onto your damaged system, select either option one (1) or option three (3). If you selected option one (1), type chkdsk /r at the command prompt, and your problem should go away after the disk has been repaired.
Note! Unfortunately there is a chance that your partition is corrupt beyond repair and all of your data is lost. In that case, you need to reformat the partition to be able to use it again.
Jan 04, 2009 | Dell Inspiron 6400 Notebook
Blue screen error 0x00000024 dont have recovery disk
This Stop message, also known as Stop 0x24, indicates that a problem occurred within Ntfs.sys (the driver file that allows the system to read and write to NTFS drives).
Resolving the ProblemDisk Corruption. Corruption in the NTFS file system or bad blocks (sectors) on the hard disk can induce this error. Corrupted SCSI and EIDE drivers can also adversely affect the systems ability to read and write to disk, thus causing the error.
Check Event Viewer for error messages from SCSI and FASTFAT (System Log) or Autochk (Application Log) that might help pinpoint the device or driver that is causing the error. Try disabling any virus scanners, backup programs, or disk defragmenter tools that continually monitor the system. You also need to run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owners manual for your computer. Run Chkdsk /f /r to detect and resolve any file system structural corruption. You must restart the system before the disk scan begins on a system partition. If you cannot start the system due to the error, use the Recovery Console and run Chkdsk /r.
rate me if you think its fixya...
regards,
Dec 06, 2008 | Gateway MX6025 Notebook Computer...
Checking file system on C: The type of the file system is NTFS. I turn on my hp pavillion ze4400 and get a blue screen with this message: One of your disks needs to be checked for consistency. You may...
You got a bad disk
Get an external hard drive.
Reboot and Cancel the disk check for you to log-in to Windows.
Back-up all important data.
Once data is safe, open My Computer and right-click on you C: drive then choose Properties.
Click on the Tools tab and click the Error Checking button then select all options and follow on-screen instructions.
Nov 12, 2008 | HP Computers & Internet
Laptop
A blue screen is an operating system error. this can be caused by either a corrupt operating system or a failed hard drive. What you will need to do is run a system repair with your recovery or operating system disc. If the repair doesn't take then reformat the hard drive and install a fresh operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced.
Jul 26, 2008 | Dell Latitude D800 Notebook
Gateway MX6912 Notebook Logo
81 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
