Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Rm 2852 model refrigeration
My freezer is freezing good but my bottom part is slightly cool. there is a fuse holder in the back which when I try to replace the fuse in blows the fuse immediately. Could this be the problem.
    Genius:
  • 1,269 Answers
That might be it. Did you replace the exact fuse AMP?
Posted on Jul 26, 2008
    Brigadier General:
  • 3,614 Answers
MAY I KNOW THE EXACT MODEL/MAKER OF YOUR UNIT..?
THANKS
I have a Domatic RM 2852 in my RV. The freezer works fine but the refrigerator won't cool to 40 on electricity. It cools fine on gas.
You need to unplug the heating element from the circuit board and using a digital multi meter check the ohms. You should read approximately 44 ohms +/- 10%. If it is out of range change the heating element.
Aug 15, 2013 | Dometic RM2852 Refrigerator
Freezing in the refrigerator
you probably have a damper control that is sticking open letting the cold air in fromthe reezer but not closing the small door when the freezer is to tempreture check this first
Apr 30, 2010 | Dometic RM2852 Refrigerator
Dometic 2852 freezer gets cold but refridge does not
If your freezer is getting down close to zero degrees (F) then I doubt that your refrigerant is low. The most common cause of the refrigerator section not getting cool (approximately 40 degrees (f)) is a fan that pulls the coils in the freezer into the refrigerator has failed. A very common failure of a cheep little fan motor. Normally that fan is behind a panel in the freezer section at the bottom. Determine where the cold air in the refrigerator section normally enters and the fan will be above there.
Aug 11, 2009 | Dometic RM2652 Refrigerator
2005 dometric rm 2852 wont cool
I suggest the main control board is faulty because of the spike. The voltage would have damaged some of the control circuit - even though the fuses did not blow. Sounds like a memory fault on a control chip.
Aug 05, 2009 | Dometic RM2852 Refrigerator
Whirlpool Model # GB2SHTXTS00 refrigerator not cooling. it has bottom freezer...coils in the freezer are icing up... I checked the heater, and stat ohmed ok.i ran the service test everything appeared...
Sounds like the defrost timer is not tracking the time properly. The unit needs to defrost once every 6-8 hrs. in order to work. Make sure the inside (evaporator) fan is running ok. If it rund for a few days and then warms up in the refrigerator section (coil iced), then the defrost timer is the culprit.
May 28, 2009 | Whirlpool GB2SHKXL Bottom Freezer...
2002 RM 2852, the refrigerator (lower section) will not work its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
I ALLWAYS RECOMEND REPLACING THE FRIDE COMPLETLTY
you get all new electronics and a new box
May 28, 2009 | Dometic RM2852 Refrigerator
Fridge is warm, Freezer working ok
I had the same problem , you have to clean your freezer compartment out completely and take the covers off the inside back of the freezer being carefull not to break any wires, then defrost the cooling module by hand hot water towels messy job.
Make sure the cooling sensor is attached in the right spot and hasn't fallen down, it has a plastic holder it clicks into.
once clean and defrosted put back together and it will be fine...
Try not to put any frozen chip bags or peas etc right at the back of the freezer this causes the cooling system to freeze up.
How the system works it blows cold air from the freezer compartment down to the fridge to cool it and when the system freezes up no cold air to fridge ,hense the problem you are having...
If you are not confident in doing the job you can call a fisher and Paykel tech and they will charge you $150 to do the job.
Apr 01, 2008 | Fisher and Paykel Active Smart® E522BR...
Refrigerators Logo
106 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
