Question about Maytag Dryers
Model 8600 , drum makes loud noise, not a squeak
    Brigadier General:
  • 3,614 Answers
CHECK THE FOR THE BROKEN BEARINGS, KINDLY MOVED THE DRUM FRONT AND BACK..IF THIS MOVE MORE THAN AN INCH, IT IS POSSIBLE A BEARINGS FAULT... AND ALSO CHECK THE MOTOR BELT AND FOR ANY OBJECT THAT HAS BEEN STUCK IN TO THE DRUM
Posted on Jul 26, 2008
  • 3,037 Answers
How old is this dryer. Most likely you bearings have gone bad.
    Genius:
  • 3,422 Answers
HI,
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer is making loud noise when running, Gas Dryer, Model # WGD5790SQO Is it easy to change BRG on drum?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 29, 2010 | Whirlpool Dryers
I HAVE A GE GAS DRYER MODEL DDG5980VALWH SER. 3F302890G. WHEN THE DRUM TURNS IT MAKE A THUMPING SOUND,,NOT REAL LOUD. MORE OF A THUMP THEN A SQUEAK.
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 12, 2010 | GE Dryers
I have a maytag dryer model MDE3757AYW that is making a loud squeaking/sqealing noise. the drum still turns and dries the clothes though.
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 02, 2010 | Maytag Dryers
Whirlpool LEW0050PQ electric dryer makes a noise.
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
Loud squeaking noise
dont spray that on the belt lol that stuff is flamable i think lol you most likely have bad phelt glides  they are pads that sit between the drum and the drum support and when that wears out it squicks or maybe you have a bad idler pulley which is what holds the belt maybe its rusty or something but most likelt its the pads
Jun 09, 2009 | Maytag MDE6000 Dryer
Squeaking noise
Noise from dryers can be eliminated through the following checks
* Level the dryer
* Check the drum belt
* Check the drum support rollers
* Check the idler pulley
* Check the glides
* Check drum bearings
* Check the blower
* Check the baffles
Apr 10, 2009 | Maytag Dryers
Dryers Logo
146 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
