Question about Dell POWER SUPPLY PS-5201-5D (PS52015D) Power Supply
Latitude D505 Just bought new charger so the problem its not powercord or some I guess. The charger /PA-1650-05D/ has small green light what comes on when pluged. Problem is, when I plug it in the laptop /Dell Latitude D505/ the green light dissapeares and there is not measureable power end of the powercord. Took laptop apart to see is there anything wrong with a jack but could not see anything not a crack on connection or some. Have to unplug my power from socket, plug it again and tried to measure the jack pins, even didnt see the green light but of course nothing. Pls help, for the only thing Ive been advise to change the motherboard, but the whole laptop doesnt worth, what they asking for one. Hope there could be another solution and sorry for my bad language. Thx!
Just repaired a laptop with the same symptoms:
Won't charge the battery, won't power from AC.
Also if you power the AC adapter when not connected to laptop you get green power LED on the adapter. When you plug it in the laptop the green power LED immediately goes out.
Opened it up and found SO-8 P-ch mosfet by the DC input socket. Source (pins1,2,3) is connected to the inner barrel (+19.5V), Gate 4 gets driven low, applying the input to the Drain. (pins 5,6,7,8) On my board the drain was short to GND. Applying power directly to the Drain via a current limited bench PSU (set 1A limit) showed a couple of volts.
Placing a finger on the opposite side of the board revealed a SMT ceramic cap getting hot.
CP13 I think. Opposite side to the power connector, almost under it. I would guess at 1206 or slightly larger and there is an 0402 cap just next to its bottom pad at 90 degrees to it. Cap was glued before soldering so had to flow both sides at the same time with a soldering iron and force off. Would likely have been 1uF or bigger 25V. Removal restored operation. Runs OK without but would suggest putting something in there 0.1uF 1206 50V, perhaps a couple stacked ?
BTW you have to strip down everything and remove the main board to get to the cap :-(
Hope this info is of use....
Robin
die4laser.com
Posted on Nov 13, 2008
The screen on my Dell Latitude D505 became grainy and exhibited pink and green areas. Normal colors were gone. And then, the screen went black, however when I shine a flashlight on the screen, I can...
hello
very much sounds like the back light in your screen has gone. this is a small flourecent light that is fitted inside the bottom edge of the lcd screen, these can be replaced , best bet is try another screen. if screen ribbon cable is ok, realy only a few other things it could be, inverter, or graphics card. i hope this helps you
Aug 09, 2013 | Dell Latitude D505 Notebook
I got a dell latitde d505 wont power on or anthing no blinking lights no noises. i plug it into the charger n the charger light goes off. can some1 please help me??
Sounds like you may have fried your dell latitude. I have seen many laptop's fry and it is nothing you did, but they just go sometimes.
Recomendaitons:
Take the battery out of the laptop.
Plug the charger in.
Hold the power button for a minimum 10 secs (which will reset the power options)
If there are still no lights than it is your cpu
If the computer turns on then you have a bad battery.
When batteries are bad or dead, the computer tries to run off of the battery befor the charger, it switches over to the charger after your OS has booted. In that case you can just order a new one no big deal, but if your cpu is fried then there is no hope for the laptop. :( I have lost four laptops because of this, so for your sake I hope its the battery or the GND Drain.
Also possible that the GND's drain on your board is too short and Gate 4 is driving low. To fix this you have to remove a SMT ceramic cap, which is located opposite side to the power connector, almost under it. I would guess at 1206 or slightly larger and there is an 0402 cap just next to its bottom pad at 90 degrees to it. A couple of Dell Latitude d505 have had this problem and can easily be fixed, but must be cautious and know what you are doing. I would advise seeing a professional.
Please don't forget to rate :), Thanks!
Oct 07, 2010 | Dell Latitude D505 Notebook
When I plug in the power cord to charge the battery, the light on the cord goes off. I tried several charges and they work. Can charged battery on another computer and place on the dead computer and it...
There's no fuse problem with that computer, try this first, Plug in the charger to an outlet don't plug it in the laptop, if the light on the charger turns on, then the charger is working try to plug it on the computer if the light on the charger goes out there's a problem with your motherboard. Contact the tech support for that so you can get that part replaced.
To double check try to use a known good charger if it works then you'll need another charger if not, Then contact your tech support for your dell make sure you still have a warrant.
Hope this helps!
Feb 15, 2010 | Dell Latitude D505 Notebook
Where is cmos battery located in Dell d505?
It's called the Reserve Battery in a Dell Latitude D505.
(It's also called an RTC battery in others, {Real Time Clock battery}, and CMOS battery in older laptops)
1.Remove the AC adapter if plugged in. (Charger)
2.Remove the Battery.
3.Right up against the outside edge of the battery compartment, in the middle. you will see the battery latch.
Push it down. The Reserve Battery Cover will come loose at the top. Rotate the top, towards the inside of the battery compartment.
The Reserve Battery is right there.
Pull the Reserve Battery towards the battery compartment.
(Comes right out of the small rectangular compartment it is in)
(It looks like three round coins put side by side, and has a green plastic coating around it.
In actuality, there are coin sized watch batteries inside that green plastic cover)
You will see a Red wire, and a Black wire twisted together, that go to a small white connector. The connector is two piece. Separate the connector, and you can take the Reserve Battery out.
http://support.dell.com/support/edocs/systems/latd505/sm/reserve.htm#1123661
Dec 19, 2009 | Dell Latitude D505 Notebook
I have a loose charger port on my dell Latitude d505. How can I fix it?
common design flaw, charger port is part of motherboard it breaks mb can be fixed by replacing motherboard i know it sucks
Jul 06, 2009 | Dell Latitude D505 Notebook
Old battery not charging plug in charger green light goes out
If the system will not power on, and the LED on the AC adapter goes out when plugged into the system, then the most likely senario is the motherboard has failed. Remove the battery, Wireless card, Drives, RAM and connect the AC adapter see if anything changes. If no change, the MB is most likely bad.
May 01, 2009 | Dell Latitude D505 Notebook
Latitude Charger wrong
Firstly, you should try to use correct sentence structure.
Secondly, as long as it's a pa-10 or pa-12 for the d600 you should be fine. the chargers are not specific to each laptop, rather they are more specific to the dell product family(the type of power connectors on each).
Jul 09, 2008 | Dell Latitude D600 Notebook
Dell battery
Bring it in the Geek Squad they can test your charger there, If the charger is ok send the whole pc to dell so they can check all the componets, charging unit might need to be replaced or you might have a short in the motherboard...
May 28, 2008 | Dell Latitude D505 Notebook
Computers & Internet Logo
359 people viewed this question
Alun Cox
