Question about Dell Latitude D800 Notebook
Laptop My laptop is frozen on a blue screen states checking file system on C disks need to be checked for consistency then states verifying stages 1 of 3 but cant get past 25 % then states it is unreadable this is on a windows blue screen help thanks C
    Genius:
  • 2,028 Answers
A blue screen is an operating system error. this can be caused by either a corrupt operating system or a failed hard drive. What you will need to do is run a system repair with your recovery or operating system disc. If the repair doesn't take then reformat the hard drive and install a fresh operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced.
Posted on Jul 26, 2008
My external hard drive shows up in devices but i cannot access the files on it. The laptop does not recognize it as a hard drive
C:\Documents and Settings\mpos>chkdsk c:
The type of the file system is
NTFS.
WARNING! F parameter not specified.
Running CHKDSK in read-only
mode.
CHKDSK is verifying files (stage 1 of 3)...
File verification
completed.
CHKDSK is verifying indexes (stage 2 of 3)...
Index
verification completed.
CHKDSK is verifying security descriptors (stage 3 of
3)...
Security descriptor verification completed.
CHKDSK discovered free
space marked as allocated in the
master file table (MFT) bitmap.
CHKDSK
discovered free space marked as allocated in the volume bitmap.
Windows found
problems with the file system.
Run CHKDSK with the /F (fix) option to correct
these.
156280288 KB total disk space.
12116176 KB in 34467
files.
11304 KB in 4337 indexes.
0 KB in bad sectors.
110084 KB in use
by the system.
65536 KB occupied by the log file.
144042724 KB available
on disk.
4096 bytes in each allocation unit.
39070072 total allocation
units on disk.
36010681 allocation units available on
disk.
THIS IS WHAT I GET WHEN I
TYPE IT IN. WAIT A FEW MINUTES WHEN U TYPE CHKDSK E:OR TYPE IN
TYPE IN
CHKDSK E: /F
Sep 15, 2013 | SimpleTech 320GB SimpleDrive External by...
Tip
How to check the PC system for errors, repair the damages or check disk.
1.) Go to 'Start'
2.) Press run and type CMD
(You will see a box eg: C:WINDOWSsystem32CMD.exe )
3.) Type CHKDSK , press enter
*CHKDSK is verifying files (stage 1 of 3) You have to wait for a few seconds/minutes.
Then you will get a message 'run chkdsk with /F (fix) option to correct these'.
4.) Type CHKDSK /F . press enter
( *Remember there is a space between Chkdsk and F: chkdsk<space>/F )
Again, you will get a message 'chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
5.) Type Y
You will get a message ' This volume will be checked the next time the system restarts.
6.) Now, exit the box and restart your computer.
It will the check the disk. You will see this on your screen as you restart 'A disk check has been scheduled. Windows will now check the disk (stage 1-5)'
*Note: It will take some time to check your system disk. You need to perform 'check disk' regularly so that you can speed up your PC performance and to repair damages in your system.
* You can try it on any kind of Windows PC.
on Jan 25, 2010 | Computers & Internet
Bad sectors
Yes your hard drives electronics are failing. you need to replace your hard drive.
Jul 15, 2012 | Toshiba Satellite Computers & Internet
Desktop will not start.. will only go through Chkdsk
Try and tap F8 and see if you can boot to safe mode and go to my computer and rt click on C, and pick properties then tools, then
check for errors, and check auto,and scan.
Go to dell.com if you don't know who made the hard drive in your model. Then go to the mfg of the hard drive and download a hard drive diagnostic disk to check your hard drive for bad sectors.
You should go to dell.com and check your warranty and you can also ask dell what you should do.
This link posted below has a lot of drive mfg diagnostic tools.
http://www.tacktech.com/display.cfm?ttid=287
Apr 14, 2009 | Dell Dimension 9200 PC Desktop
Error message
That is not an error, Windows is trying to verify that there are no issues with your hard disk. Is what you wrote above all that you see? If so then check disk is freezing before it completes. Try to cancel the chkdsk before it starts by pressing any button when it prompts you to, log into windows, back up everything up that you need and restart your laptop. Worst case scenario you need to reinstall windows on your laptop
Mar 04, 2009 | Dell Inspiron 1525 Laptop Jet Black
Checking file system on C: The type of the file system is NTFS. I turn on my hp pavillion ze4400 and get a blue screen with this message: One of your disks needs to be checked for consistency. You may...
You got a bad disk
Get an external hard drive.
Reboot and Cancel the disk check for you to log-in to Windows.
Back-up all important data.
Once data is safe, open My Computer and right-click on you C: drive then choose Properties.
Click on the Tools tab and click the Error Checking button then select all options and follow on-screen instructions.
Nov 12, 2008 | HP Computers & Internet
LAPTOP
Reboot it and keep pressing F8. Select boot to Safe Mode.
-Try to uninstall the last application that you installed.
-Try to do system restore as well
Jul 26, 2008 | Gateway MX6912 Notebook
Won't boot up
sounds like the hard drive is failing, if things are not backed up then get it to a professional without trying to start it again as more damage my result
Jun 21, 2008 | HP TouchSmart IQ770 PC Desktop
Dell Latitude D800 Notebook Logo
121 people viewed this question
Alun Cox
