My zune is hooked up to my car stereo through auxillary cables and when im riding it just cuts off for no apparent reason
Zune hook up.
use mini jack for zune with two rca male. use a two rca female with a deck changer end. plug into the back of your car stereo and your done.
Posted on Oct 22, 2009
How do i hook up auxillary chord to a denon avr-884
There are several "line" inputs that should work.you will need an adapter to go from 3/5mm [1/8" phone] to RCA Stereo. This can be a cable with Male 3.5 mm stereo on one end and two RCA male on the other, or a 3.5 M-M cable plus a 3.5 female to RCA male adapter. or a stereo M-M RCA cable with RCA F to 3.5 Male...
If you have easy access to the back panel, plug into and use the CD/Tape [IN]. Or you can simply plug the RCAs into the front L and R audio and use that input sans video.
Jan 03, 2015 | Denon Audio Players & Recorders
What's your problemI bought a used car that has an alpine cda 9805 radio. It has an auxillary cable that appears can hook up to my I pod nano. I can't find the function/ mode on the radio to g
The source/power button in the top left corner changes the mode. Press the button until the aux appears. The auxillary device must be plugged in to register on the stereo.
Aug 19, 2012 | Alpine CDA-9805 CD Player
What Auxillary cord model will fit in my alpine cda-9853 stereo model?
Peripheral stereo mini plug cable (3 foot cable, male to male miniplug). around $20
Monster portable music player cable (stereo mini-to-RCA adaptor) around $20
Arista stereo mini-to-RCA adaptor (6 foot cable with mini and dual RCA plugs) around $5
Hope that helps.
Mar 30, 2011 | Alpine CDA-9853 CD Player
Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Jun 03, 2009 | Sony CDX-CA810X CD Player
How to use MP3 on it
That model has a front-auxillary port on it.
Just purchase a cable online (http://www.yourcablestore.com/6-Foot-25mm-Stereo-Headphone-Cable-Male-Male_p_76.html) or in Walmart, BestBuy, etc.
When you get it, hook one end into the stereo and the other end to your MP3 player.
Set the Aux as the source and press Play on the MP3 player.
Apr 13, 2009 | Alpine CDE-9874 Car CD/ MP3 Player
Bose stereo System
I would suggest checking the owner's manual on what the button does, but you could always buy an FM Transmitter hook it up to your Zune and play music from an empty station.
Apr 03, 2009 | 2008 Mazda Mx 5 Miata
Zune problem
ok first off, you need to set your stereo system to aux....remember aux the zune is not a cd player.
depending on the brand of stereo system there is a setting were you can change it from cd, to radio and AUX. SET IT TO AUX
do you have a stereo head phone jack on your stereo system, if you do a much better solution is getting a double sided audio cable and plugging the zune directly into the head phone jack to your stereo system it costs maybe $10 for a good gold plated phillips
what i mean just incase you didnt understand is you need a double sided plug for the headphone jack, this plugs into most stereo systems
Mar 31, 2009 | Microsoft Zune JS8-00001 Digital Media...
Can i hook a surround sound to my zune
It is usually as simple as getting a 3.5mm stereo headphone jack to RCA adapter, like this one:
http://www.radioshack.com/product/index.jsp?productId=3359117 (this will work just fine, even though it says 'ipod')
Or they have "Zune Ready" adapter kits, like this one:
http://www.radioshack.com/product/index.jsp?productId=3004031
Once you have the cable, you stick the headphone plug (3.5 mm stereo mini-phono) into the headphone jack on your Zune, then you insert the red and white RCA jacks into an open input on your surround receiver... most have an auxilliary input jack set on the front of the unit. All you need to do at this point is select the "aux input" for the source on the surround receiver, start your Zune, and make sure the volume on the Zune is somewhere in the 50 - 75% range, and you should be good to go.
Dec 08, 2008 | JVC THD-50 System
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
 Grubhead
Grubhead
