Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore portable dishwasher model 587-17252202
Seems like this dishwasher does not exsist? Problem is that it does not finish a cycle? It sounds like it rinses only and does not wash? This is a two year old system thats NEW....because it has not been used , for this reason.
Called old friend that worked for sears
Posted on Jul 27, 2008
Dishwasher wont finish any cycles
That blinking light is trying to tell you that there is something wrong with the dishwasher. You need to fix the problem or else that blinking light will come back. And the number of times it blinks (before it pauses and repeats) will tell you (or a technician) what is wrong. How many times does it blink?
Jul 04, 2014 | Kenmore Dishwashers
Kenmore 13789 draining/cleaning issues
Check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher or placing large plates or pans in front of the soap dispenser. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
Dec 31, 2012 | Kenmore 13789 / 13782 Dishwasher
Kenmore portable dishwasher not working
THERE IS A PLASTIC COVER GRATE IN THE BOTTOM OF THE DISHWASHER TAKES A 1/4 INCH NUT DRIVER TO REMOVE IT, TAKE IT OFF CLEAN OT THE DEBRIS AND FLUSH WITH A BUCKET OF WATER, THIS IS SUPPOSED TO BE THE FILTER, IF ANYTHING IS IN THERE YOU WOULD BE ABLE TO SEE IT, I HAVE FOUND STRAWS AND KNIVES IN SOME DISHWASHERS, HOW THEY GET IN THER IS A MISTORY BUT THEY DO
May 29, 2009 | Kenmore 17252 Free-standing Dishwasher
is the buzz sound when you ask it to drain or ask it to fill with water? or is the buzz sound when it is trying to wash? IF it is when you ask it to drain either you have something stuck in your air gap causeing no drain or there is something in your pump I would check the easy stuff first by checking the air gap this is if it is buzzing when you ask it to drain. let me know what is the senario.
if you can get underneath it try spinning the motor manually (after turning off the circuit breaker). sometimes the motors on dishwashers get jammed.
May 29, 2009 | Kenmore 22422 Top Load Washer
Water standing in bottom of dishwasher,after wash cycle is finished? This is a Kenmore model 665.1565591
My problem too recently.
I blew compressed air back through the drain line and let it bubble up in the standing water in the dishwasher. Then I put it through another cycle and everything was fine. Something must have gotten clogged and the air blew it out.
Mar 19, 2009 | Kenmore Dishwashers
Kenmore dishwasher not draining when finished full cleaning cycle
sounds like a cycle timer problem. Look for a loose wire on the cycle timer. If yours is a digital timer, it is a board issue. Sorry.
Aug 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
329 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
