Question about Arris WA840G 802.11g/b (49832000100) Wireless Access Point
Can not connect to the WA840G.
Hi, since new 5 Ghz wireless network intall in my area i can not get access into my WA840G access point networ.
Is the new 5 Ghz wireless network invalidating my WA840G network ?
Thanks.
The problem was that WA840G was not configured with the "open access" option, and that's why my USR PCMCIA card can not authentify automatically because it has not got a correct user ID and password to get access into network. Solucion: configure the WA840G access point to and "open access" system.
Posted on Aug 04, 2008
When I connect one particular access point the whole network goes to limited
Have you had a technician diagnose the fault? It might be that there is a physical problem with it.
Jul 04, 2015 | Computers & Internet
Apple products won't connect to network
May experience is that a lot of Apple products have problems with 5 Ghz wireless unless the conditions are near perfect. 5 Ghz has more difficulty penetrating things like walls than the older 2.4 Ghz. If during the setup you decided to disable the 2.4 Ghz, this could be the problem.
Apr 17, 2017 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Slow connection low signal
If a wireless network has low signal strength, the transfer of information across the network could be slow or you might not be able to access certain parts of the network. Here are solutions to some common problems with low wireless signal strength: Your computer is too far from the wireless router or access point. Move your computer closer to the router or access point. If your computer is portable, try moving it around to determine the range of the wireless signal and the best place to use the computer. If you can't get closer to the router or access point, consider buying and installing an external antenna for your wireless network adapter. Many wireless network adapters are set up so that you can attach an external antenna to them, which provides better reception than the built-in antenna. Check the information that came with your wireless network adapter to see if you can install an additional antenna. The wireless router or access point is turned off or isn't working properly. There are two things to try: o Make sure the router or access point is turned on and that the wireless signal light is illuminated. o Reset the router or access point by turning it off, waiting at least 10 seconds, and then turning it back on. If you don't own the access point or don't manage the network, contact the network administrator. There is interference from other devices. If you have 802.11b or 802.11g network hardware, it uses the 2.4 gigahertz (GHz) frequency. Other devices that use this frequency include microwave ovens and cordless phones. If you have 802.11a network hardware, it uses the 5 GHz frequency. Some cordless phones also use this frequency. These devices can cause interference between your computer and the network. There are two things you can try in this situation: o If any devices like these are near your computer, turn them off temporarily or move them farther away. o Change the router or access point settings to use a different wireless channel, or set the channel to be selected automatically if it's set to a fixed channel number. Sometimes one wireless channel is clearer than others. In the United States and Canada, you can use channels 1, 6, and 11. Check the information that came with your access point or router for instructions about setting the wireless signal channel. The network you're looking for is set to not broadcast its network name (SSID). Wireless routers and access points can be set up so that they don't broadcast the network name. In this case, you can't detect that the network is in range (in order to connect to it) unless you've previously connected to the network or you manually connect to the network using the service set identifier (SSID). To connect to a network that's not broadcasting, follow these steps: 1. Open Connect to a Network by clicking the network icon ( or ) in the notification area. 2. Click Unnamed Network, and then type the network information. The network will be added to your list of networks and will be available to connect to in the future when your computer is in range of the network.
Dec 27, 2012 | Computers & Internet
I can not connect new laptop to existing personal wireless networ
unplug router for 10 seconds and plug back in. Then try. If needed, use network setup wizard.
You can also renew your pc's ip address by going to start menu, then run. Then type ipconfig/ release then type ipconfing /renew and everything should be fine.
Nov 09, 2009 | NetGear WG602 802.11g/b Wireless Access...
I set up my my motorola WA840G with my old PC which is now long gone. When i set it up i didn't put in any security. It worked fine on laptops and the PS3 After the PC went. I disconected wireless to...
Go to a friends house and google the defaults on the router. Put in the model etc. Once you reset it the defaults should work and then you can set up a new network name and wep or wpa key.
Oct 04, 2009 | Computers & Internet
I need a software download for the motorola wireless access ponit model# wa840g part# 513313-001-00
Just follow this link then enter the code and click on download: http://www.nodevice.com/driver/WA840G/get32378.html got it?
Jun 10, 2009 | Arris WA840G 802.11g/b (49832000100)...
Motorola WA840G
192.168.40.1 is the standard ip address for that model.
Apr 28, 2009 | Arris WA840G 802.11g/b (49832000100)...
I want to use my WAP to share my internet connection.
i have motorola wa849g.i reset now i want to cofigure this i open explorer put 192.168.10.1 didnot open show page canot open
May 22, 2008 | Arris WA840G 802.11g/b (49832000100)...
What should I do after "Easy Software Setup"?
just unplug the Ethernet cable from the computer and plug it into the router and put the other end of Ethernet cable in to the wan port of WA840G
Oct 25, 2007 | Arris WA840G 802.11g/b (49832000100)...
WA840G firmware went bad :(
Hi, Based on your post/description, I would assume that though you did not complete the upgrade, you were able to restore the WA840G to the original/old firmware. Second, you still wish to upgrade again but using a different method other than web configuration. Perhaps you can try a telnet session to 192.168.1.1 or the default which is 192.168.40.1 or the IP add you have set it to if you have modified it before. I have successfully tried this on a LinkSys WRT54G & NetGear MR814V2. Might or might not work for you. "?" or help should give you the basic line commands. But then again, if the system has crashed and the unit is bricked, that is a harder problem and you might be better off replacing the unit. Hope this be of some idea/help. Post back how things are or should you need further information. Good luck and kind regards.
Sep 13, 2007 | Arris WA840G 802.11g/b (49832000100)...
Arris WA840G 802.11g/b (49832000100) Wireless Access Point Logo
191 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
