Question about Canon PIXMA iP3300 InkJet Photo Printer
How to remove the ink cartridge from the wrong slot for canon mp530
I was trying to replace my black ink cartridge for BK8 but by error I have input into the slot for PGBK5 but it is struck and cannot be removed.
Pls help. I purchased a compatible black cartridge for my printer but the printer does not recognise it and won't print. Now it is jammed in the machine and I can not get it out. Help.please
There is no solution to this problem unless you know how to take the printer apart to remove the cartridge. The printer has probably been damaged when trying to get the cartridge out anyway so my solution is buy a new printer.
Posted on Jul 28, 2008
CHECK CARTRIDGE u052
Remove all ink tanks (printer is on), remove printer ink cartridge carrier head. clean head with alcohol wipes thoroughly, not contacts. Push in gently print cartridge pistons on cartridge carrier. Reseat print cartridge and ink tanks, replace any very low ink one's. turn off printer, unplug electrical, remove usb on printer and computer. plug all back in, turn on. Alarm and message should disappear. Clean and realign with software.
Feb 07, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Set ink cartridge message on canon mp530
1. Set all the printer cartridge both black and color cartridge (including the empty one)
2. Right click on printer driver properties
3. Click Maintenance tab
4. Click on Ink Cartridge Setting mark
5. In pop up menu, select the cartridge which has ink inside (black only or color only). or get more information for set ink cartridge .
Jan 29, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP600 printer. Black Ink cartridge PGBK5 is
You need both. One is pigment and the other is dye. One is used for photographs and the other for non-photographs - but it's the printer that decides which one to use.
All Canon printers (to my knowledge) will stop working if any one ink cartridge is empty. This is to prevent damage to the print nozzles. The ink itself is the cooling medium for the hot nozzles.
Nov 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I have a mp530, and when the large black is out of ink, it wont print. It has a second black cartridge, but it seems as if that is never used and not needed. What is wrong? Why have 2 black cartridges if...
Printer use big PGI-5 black cartridge have pigment ink for printing text, documents or other only black pages.The little CLI-8 cartridge have dye-based ink for printing photos and other color pages.You need to replace your PGI-5 black cartridges to continue printing.
Nov 16, 2009 | Canon PIXMA® MP530 All-In-One Printer
Canon MP530 All in One Printer won't print black
Try deep cleaning the black cartridge in the Maintenance section of the printers properties. Print head might be clogged cli-8m
Sep 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error message "More than one ink tank installed...etc
I scraped the terminals in the printer gently with a screwdriver cleaned them nicely problem seems to be fixed
Apr 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma MP530 All-In-One
I had contacted Canon to resolve my problem.
Through the technician I am informed that the printer has to be sent back for service as one of the 4 pins on print-head print has dropped off leaving only 3pins that is why the error code U043 simply occur which is why replacing another new ink cartridge does not resolve the issue.
I have understand from him that:-
  1. Most of the time when error code flash up, usually are due to the unique feature that Canon has build on the ink cartridges not properly done which resulted to be faulty. Canon's purpose is to prevent the usage of 3rd party ink cartridges. Of course this causes inconvenient to users, but if users are not using 3rd party ink cartridges, once detected is Canon's ink cartridge issue, do contact Canon, they will provide house call for 1 to 1 exchange for the ink cartridge.
  2. Other times if by replacing new ink cartridge the problem for error code still occurs, it might be the pin on the print-head has lost the alighting, this will require for Canon to service to alight back the pin on print-head in order for the printer to operate smoothly again.
  3. If your problem is like mine, inputting the ink cartridge into the wrong slot, well I guess only have to contact Canon as the printer's components used seem to be highly sensitive, by input the wrong slot would have caused scatches on the pin, well it is better to have the ink cartridge remove by the expert than to DIY. (Maybe check with your own nearby technician if by any lucks they can help to rescue your printer, which I hope Canon does not have further enhancement on their printer with other Unique features to prevent users from using 3rd party technical support.)
I hope the above information will help all the troubled Canon printer users as I notice from previous search on this website, there are other users having problem like ink cartridge is only partial used, but error code appear to check ink cartridge, maybe trying to taking out and putting back, it works sometime and problem occurs again, by replace a new ink cartridge will help as the partial used one would be faulty already, and do call up Canon to report the issue and they will exchange a new ink cartridge for the faulty partial used cartridge.
Mar 26, 2008 | Canon Pixma MP500 All-In-One InkJet...
halo dear
for mp530, you can use a plugins catridge ... as cahnge your chips original , after use that you can refill your catrigde as well
the price about $4-5
try this site for clear information
http://exchangerate.ws/inkjetprinter.php?printer=Canon+PIXMA+MP530&lazySID=LcuxpiHFCsshJVujrrruBaNoo1203340519
oke
thks
cropp
Feb 29, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma MP530 no cartridge
Hi Cathy,
First, take the ink cartridge out and wipe the ink head with a tissue. If that dont work try to re-install your printer drivers that should reset your printer back.I hope this helps you.
Jan 17, 2008 | Canon PIXMA MP530 All-In-One InkJet...
MP530- Printer issue
Install recommended ink tanks in the correct order MP500 / MP530 / MP800 / MP800R / MP830
Ink Tank Order Install ink tanks in the correct order (from left to right) CLI-8BK (Black) PG-5BK (Pigment Black) CLI-8Y (Yellow) CLI-8M (Magenta) CLI-8C (Cyan) mp500_inktankorder.gif 05sj00141_08_en.gif
Jan 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  iP3300 InkJet Photo Printer Logo
154 people viewed this question
old marine
old marine
