I have a 61 in rear prjection Sony TV. The picture has become concave at the top and red and green colors areof by an inch from each other.
  • 19,396 Answers
It is a convergence problem
Posted on Jul 26, 2008
  • Ginko
    Ginko Jul 26, 2008
    It is a convergence problem, probably one or both the convergence ICs has
    blown and must be replaced. Call the number in the last pages of your
    user manual to get repair service in your area.
    Brigadier General:
  • 3,614 Answers
May i know if you done to adjust everything on the settings..
let me know/..
  • 1 more comment
  • micromaster
    micromaster Jul 26, 2008
    how old is your TV now??
  • micromaster
    if you done some changing on the settings and it could be a failure on the parts inside the television, kindly check & change the 120k resistor on the video output module. Resistor is located parallel and in front of the video output transistor heat sink.
  • micromaster
    micromaster Jul 27, 2008
    thank you for using fiXya..
    micro-
Three pictures red green & blue and it looks concave
Install the Sony type 1 convergence repair kit available from www.tvrepairworld.com the kit includes the components and the cd with instructions.
Jun 30, 2010 | Sony KP-51HW40 51" Rear Projection...
Dont know what color to stick where
X-box can be hooked up to component video. This is for better picture quality. Not all tvs have this option. Most newer tvs do. It uses green, red, blue. Those will give you the video. Then a red and a white give you the audio. Just match up the colors.
Apr 08, 2009 | Sony KP-61HS10 61" Rear Projection...
Picture is concaved and all the colors are off.
you will need to get a convergence done and the resistors on the conversion IC's checked and bad ones replaced
electech
Oct 30, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony 61" Projection (KP-61HS10)
Your TV requires Geomatirc Adjustments in proper manner by qualified servcie person.
Jul 19, 2008 | Sony KP-57WV600 57" Rear Projection...
Televishion kepts going concave picture rier prejecter
concave picture with colors red and green away from each other
Jun 26, 2008 | Sony KP-61V90 61" Rear Projection...
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
Bad picture
Try to consider the following tips:
Smearing out of one or several colors, best seen in txt-mode, my 27CE4599/30R smeared out in red and green, not in blue, fully exchanging the drivers (input and output complete, otherwise the RGB driver will blank the crt) moved the fault to the other color
Replace the 180K feedback resistors in the amplifiers with normal 1/4W metal film instead of 1/8W, they can become open circuited (in mine both green and red were faulty in this way). Change all 3 and not just the defective ones, replace also all the paralleled 75K resistors per color (fe by 47K+27K) to prevent bright color raster (they can also become open circuit)
Nov 29, 2007 | Toshiba 55H70 55" Rear Projection...
61 inch proj. warped concave picture.
Josh Any chance you could send a photo... Too many ideas come to mind from what you've described. Would actually have to see the "warp" in the picture itself to see if it's one or all colors, any boarders and if the bend is actually pulling from top or bottom.. Bill premtech@willapabay.org
Jun 14, 2007 | RCA P61960 61" Rear Projection Television
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
