I recently ran a scan on my computer and now I don't have sound. Speakers are plugged in and on, volume is up.
    Problem Solver:
  • 17 Answers
First thing: check that the volume in the computer (not the speakers themselves; you've already checked that) is on. Go to Control Panel, click on Sounds & Audio, click on the Volume tab, and make sure the "Mute" button isn't checked. Make sure the Device Volume slider is up. Click on the "Speaker Volume" button and make sure that's up, too.
If all of that is correct, then try plugging in a set of headphones. Is there sound? If not, then you may have to re-install the drivers for your sound card. If it's an onboard sound card (like Realtek AC97, a pretty common one), you can download it from your computer manufacturer's site, or from just about anywhere, really. If it's an add-on card, like a SoundBlaster, you can go to their site and get the drivers. Or, hopefully, you still have the CDs that came with it!
Hope this helped.
Posted on Jul 26, 2008
My computer speakers don't work & i've tried everything even my headphones don't work so what should i do
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 27, 2011 | HP Audio Players & Recorders
My speakers won't turn on at the outlet that my power strip is plugged into, nor when plugged into any of the outlets on the strip, however the computer and monitor are running off the power strip and...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar:
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 01, 2011 | Logitech X-530 Computer Speakers
Hi have recently purchased logitech 5500 system, it was working fine for a few days but now even with no sound running through it when you turn it on blast out a loud sreeching short out sound, just...
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
don
Feb 25, 2011 | Logitech Z-5500 Computer Speakers
When I plugged them up the light on the speakers did not come on and no sound
also
hope this helps
don
Feb 25, 2011 | Dell A215 Computer Speakers
We have default buildin sound card on HP brand PC. i setup windows recently, from then sound device not work. show now sound
also
hope this helps
don
Feb 24, 2011 | HP (400745-001) Sound Card
I've recently deleted a virus on my Dell Dimension computer, and now my sound card isn't showing on my computer, and no sound
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
also
hope this helps
don
Feb 20, 2011 | ATI Computers & Internet
My speakers work fine. I don' t know why thay keep turning. i have the internet. How do i keep my speakers on all the the
also
hope this helps
don
Feb 16, 2011 | Audio Players & Recorders
Hi just bought these speakers and only the right and left work?? any suggestions??
you might have to select stereo speakers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
don
Feb 15, 2011 | Logitech X-530 Computer Speakers
Only getting half the volume
The first things I would check would be the volume control within your operating system. If I assume you have Windows XP, you would go to Start-->All Program-->Accessories-->Entertainment and click "Volume Control". Make sure all of the sliders are at least 1/2 way up. You might also want to check to make sure the cable from the speakers to the computer is plugged into the proper jack (usually the green one), as sometimes computers have jacks for rear speakers, which might make them sound quieter.
Mar 04, 2008 | Logitech Z-2300 Computer Speakers
Computers & Internet Logo
David Payne
David Payne
