How to install Memorex USB 2.0 1GB flash drive on computer with microsoft 2000 OS
Evidently the flashdrive can't be used on 2000 OS so I'll give up....thanks for the info
Posted on Jul 26, 2008
    Sergeant:
  • 221 Answers
Windows 2000 should recognize the flash drive immediately after it is inserted. The flash drive should install itself. Besides, there are only drivers available on the Memorex website for Windows 98se.
I have purchased, and (unfortunately the packaging is trashes... for use) a Verbatim 8 Gig Flash Drive which now appears to be incompatible (useless?) for my older computer systems Microsoft Windows 2000...
Newer high-end flash drives will often trigger a network security response because they want to load a driver onto your machine...and many network systems will not allow that without a network administrator password. So...I suspect it's not the drive asking for the password, but Windows or OS-X.
You'll probably need to talk to your network administrator on this one.
Hope that's helpful.
Jan 18, 2011 | Computers & Internet
Memorex compatibility with Mac computer.
first, go to my computer and right click the drive.
select "format".
click start. or OK.
this shoult format the drive. now you can write to it.
Aug 24, 2008 | Memorex Electronics - Others
Tip
Steps to create a bootable Vista or Windows 7 USB flash drive for the purpose of...
<b>Steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS<br /> <br /> <br /> Microsoft Provides a tool to do this for you - Windows 7 USB/DVD Download Tool which is available for <a href="http://images2.store.microsoft.com/prod/clustera/framework/w7udt/1.0/en-us/Windows7-USB-DVD-tool.exe">download here</a>. If you need instructions on how to use the tool, see the Microsoft Store Help on the ISO-Tool (<a href="http://store.microsoft.com/Help/ISO-Tool">http://store.microsoft.com/Help/ISO-Tool</a>).<br /> <br /> or <br /> <br /> <br /> <span style="text-decoration: underline;">Please follow the steps below</span><br /> <br /> </b> <b>Required:</b><br /> <ul> <li>USB Flash Drive (4GB+)</li> <li>Microsoft OS Disk (Vista / Windows 7)</li> <li>A computer running Vista / Windows 7</li></ul> <b>Step 1: Format the Drive<br /> </b>The steps here are to use the command line to format the disk properly using the <i>diskpart</i> utility. [Be warned: this will erase everything on your drive. Be careful.]<br /> <ol> <li>Plug in your USB Flash Drive</li> <li>Open a command prompt as administrator (Right click on Start &gt; All Programs &gt; Accessories &gt; Command Prompt and select "Run as administrator"</li> <li>Find the drive number of your USB Drive by typing the following into the Command Prompt window:<br /> <span>diskpart<br /> list disk</span><br /> The number of your USB drive will listed. You'll need this for the next step. I'll assume that the USB flash drive is disk 1.</li> <li>Format the drive by typing the next instructions into the same window. Replace the number "1" with the number of your disk below.<br /> <span>select disk 1<br /> clean<br /> create partition primary<br /> select partition 1<br /> active<br /> format fs=NTFS<br /> assign<br /> exit<br /> </span><span>When that is done you'll have a formatted USB flash drive ready to be made bootable.</span></li></ol> <b>Step 2: Make the Drive Bootable <br /> </b>Next we'll use the <i>bootsect</i> utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:<br /> <ol> <li>Insert your Windows Vista / 7 DVD into your drive.</li> <li>Change directory to the DVD's boot directory where <i>bootsect</i> lives:<br /> <span>d:<br /> cd d:\boot</span></li> <li>Use <i>bootsect</i> to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I'm assuming that your USB flash drive has been labeled disk G:\ by the computer:<br /> <span>bootsect /nt60 g:</span></li> <li>You can now close the command prompt window, we're done here.</li></ol> <b>Step 3: Copy the installation DVD to the USB drive<br /> </b>The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you've copied all of the files the disk you are ready to go.<br /> <b>Step 4: Set your BIOS to boot from USB<br /> </b>This is where you're on your own since every computer is different. Most BIOS's allow you to hit a key at boot and select a boot option.<br /> <br />
on May 19, 2011 | Computers & Internet
Trying to install in Mac G4 OS X 10.5.8 a no go
Try reformatting it:
**THIS WILL DELETE ALL THE DATA ON THE DRIVE**
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
Dec 30, 2010 | Memorex Mini TravelDrive - USB flash drive...
My computer keeps on restarting everytime I connect a USB device like, flash drive, printer etc. I tried restarting my computer, then when everything's done loading, i connected a flash driver and after a...
I would reinstall xp OS... you should be able to do a restore without loosing any of your own files. After an os restore you may have to reinstall a few programs but your data files should be ok if you do the correct type of install.
Sep 22, 2010 | Microsoft Windows XP Professional
How to use flash drive
Cruzer Micro is an USB external memory where you can store files.
It is automatically detected and installed on all Windows OS from Windows 2000 onward, same on Mac OS and recent Linux versions.
All you have to do is plugging the device into USB.
After the flash drive had been automatically installed , it will be displayed under Computer as an external disk.
You can copy and transfer files using Cut, Copy and Paste functions, or Send to function in windows, or the file manager, depending on the OS used.
In Windows, before unplugging the memory from USB , it is better to turn off the computer or use the 'safely remove USB' function located near to the clock, on the lower right hand corner.
Read also the documents below:
Introducing the Cruzer Micro
Find Answers || BeCompliant Corporation
How to Use Sandisk Cruzer Flash Drive
May 15, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Software on flash drive
Stomp is computer backup software.
Nov 26, 2008 | Memorex M-Flyer 1GB USB 2.0 TravelDrive
Problem with sony USB 2.0 8GB flash drive
My Sony USB 4 GB flash drive will not work on my XP Microsoft OS. It had been working fine for about 3 months, now when I go to open it, it asks with what program do I want to us. However, it works just fine when I put it on a computer with VISTA. Got any suggestions?
Howard
Sep 28, 2008 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Can't seem to find usb
Here is compatibility information:
Compatibility
  • Windows 98SE/2000/ME & XP
  • Mac OS 8.6 to 9.2 & 10(X) or higher
  • USB 2.0 or 1.1 compatible
Looks like it might not be compatible. Sorry!
Jan 06, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
