Question about IBM ThinkPad T41 Notebook
0200: Failure Fixed Disk 0 IBM T-41
I received the following error message on my computer: 0200: Failure Fixed Disk 0 IBM T-41
The BIOS Setup Utility is not recognizing the Hard Drive. I plan to replace the Hard Drive, however, did I lose all my information when my current Hard Drive crashed? Is it possible to recover it?
  • 1 more comment
  • DIPTIparida Jul 28, 2008
    i have a IBM T-52 laptop.my laptop is showing the message"failure fixed disk 0".what is the problem.can u message me in my id paridadiptimayee@gmail.com.pl send the suggestion.
  • Anonymous May 11, 2009
    I was watching a movie on my T41p and closed the movie down and turn off the computer , the next moring i opened the computer and pressed start button and it went thru normal startup unitl it told me i
    had a error 0200: fialure fixed disk "O" I went thru the dianostics and tried to set every tining back to default etc but to know avail it seems
    stuck in this mode........what to do called IBM and then said $45.00 for a recovery cd. or %150.00 to $500.00 to send it in and fix it....help
    I have a T41p and it was perfect until i watched a movie and closed it out and shut it down and now it only shows a 0200 fiilure of fixed disk "O" error...........what to do.........
    Genius:
  • 1,269 Answers
There's a possiblility that you can still recover your files. Try to plug your hard drive to a different PC and check if it detects it. Otherwise, there's no hope but to buy a new hard drive.
Posted on Jul 26, 2008
Error 0200 failure fixed disk 0 ibm thinkpad
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 07, 2013 | IBM ThinkPad T30 2366 Notebook
My thinkpad 2628 wont recognize my hard drive and tells me i dont have a operating system on it
This means it has crashed. You will need to use your recovery disk that came with the laptop to re-install Windows and the system drivers.
May 05, 2011 | IBM ThinkPad A21m 2628 Notebook
My T30 keeps giving me an Error 0200: Failure fixed disk 0 message. I don't know much about computers. What does this mean?
That means that if you get back into your computer, back all your stuff up as the hard drive is or has failed!
Don't leave it back it up now!!
Jan 05, 2011 | IBM ThinkPad T30 2366 Notebook
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I am getting 0200 failer fixed disk message and bios setup keeps coming up and my thinkpad wont boot up???
try to replace the hard drive of your laptop. then re-install the windows operating system. then use a hdd enclosure in a usb type to back up your data.
Apr 09, 2010 | IBM ThinkPad T41 Notebook
Power off automatically after 10 - 15 min
Your hard disk has crashed. Take it in to a computer store (Microcenter, Fry's, TigerDirect, or Best Buy) to get a new one. The data on your computer's hard drive may not be able to be saved.
Jun 13, 2009 | Acer Aspire 5100 Notebook
New HDD Install Prob
Basic Troubleshooting Tips after Installing a New Hard DriveBased on Seagate IDE hard drives.
If you have installed your drive and it does not function properly, perform the following basic checks:
Additional Troubleshooting Tips
If you have performed the preceding basic checks but the problem persists, follow these guidelines for troubleshooting specific cases:
After you install your new drive, your computer will not boot, and no error message appears on the screen.
The screen remains blank when you power up the system.
The system does not recognize the drive.
The dealer partitioned and formatted the drive for you in the store, but the drive does not respond when you install it.
The system hangs in FDISK or fails to create or save the partition record.
The system error message, "Drive not Ready," appears.
The FDISK error message, "No Fixed Disk Present," appears.
The drive does not format to full capacity.
The DOS message "Disk Boot Failure," "Non-System Disk" or "No ROM Basic - SYSTEM HALTED" appears.
The system error message, "HDD controller failure" appears.
Check your computer manual or BIOS manufacturer to determine whether your BIOS supports drives that have more than 4,092 cylinders. If your system has this limitation, use the following procedure to configure your computer:
Turn off your computer, open the case, and remove your new drive.
CAUTION: To avoid electrostatic discharge damage to your computer or hard drive, make sure you are well grounded before touching the drive, cable, connector or jumpers.
Move the jumper on the alternate-capacity jumper, as shown in Figure 6. This causes the drive to appear to your BIOS as having a 2.1-Gbyte capacity (4,092 cylinders, 16 heads, 63 sectors per track). You may need third-party partitioning software, such as Disk Manager, to achieve full capacity of the drive.
Remount your drive in the computer and replace the computer cover.
Insert a bootable system diskette into drive A and turn on the computer. It should boot from drive A and automatically detect the new drive as a 2.1 -Gbyte drive.
Insert your DiscWizard diskette into drive A and type A:XDM. Then press ENTER. This runs the Disk Manager program.
Follow the Disk Manager instructions to install the dynamic drive overlay and to partition and format your new drive to its full capacity.
After Disk Manager is done, reboot your system. You should see the Disk Manager banner and be able to access the full capacity of your new drive.
If the steps listed above do not remedy this problem, try the following:
Make sure the monitor is plugged in and turned on.
Check all cards.
Make sure the video card is seated in its slot and secured with mounting screws.
Turn off the computer and remove the drive host adapter. If the screen turns on after you reboot, the host adapter may be incompatible or defective. If so, see your dealer.
Check all cables.
Make sure the power supply is adequate for system needs.
Reboot the computer and listen to make sure the drive motor starts up. If the drive is very quiet, it may be difficult to hear its discs reach operating speed. If the drive motor does not start up, recheck all drive cables.
Verify that for each drive, a drive-type is listed in the system setup program.
Try rebooting your computer by pressing the CTRL, ALT and DELETE keys simultaneously. If the drive is recognized after you reboot the system, the computer BIOS test may be completing before the drive is ready.
One solution is to slow the processor speed during startup. If your computer has a turbo switch, set it to slow speed before turning the computer on. If there is no turbo switch, you may be able to use keyboard commands; see your computer manual for details. After the computer is up and running, return the processor to the fast speed.
Another solution is to warm-boot your computer after every power-on.
Check for I/O address conflicts. To isolate the conflict, verify that the drive and host adapter are compatible with your computer. Turn off the computer and remove all the peripheral adapter cards except for the video card and host adapter. If the computer recognizes the drive when you reboot the computer, turn off the computer. Reinstall the other peripheral cards, one at a time, until the conflict reoccurs. After you have isolated the source of the address conflict, you can resolve the conflict by changing the 1/0 address of the peripheral that appears to cause the conflict.
If Disk Manager has installed the DDO on your hard drive and you have booted directly from a diskette, the information in the boot record for the drive may not have been loaded. Make sure there is no diskette in drive A and reboot. If you want to boot from the diskette, follow the "Booting with a Diskette" instructions under "Advanced Disk Manager Options" on page 20.
Reboot the computer and make sure the drive spins up.
Check all cables.
Make sure the DOS or Windows version the dealer used to partition and format the drive is the same version you have installed in your computer. If it isn't, see your dealer.
Verify the drive-type values in the system setup program. You must install the drive using the same drive-type values your dealer used to partition the drive.
Check for 1/0 address conflicts between peripheral cards.
Check for viruses.
Check all cables.
Your setup system diskette may be corrupted. Try using a backup diskette.
Make the partitions smaller.
Change the interrupt jumper setting on the host adapter.
Some BIOS have a Track 0 protection feature that protects Track 0 from viruses. This may cause FDISK to hang the system. You must disable this feature in the system setup program before you can use FDISK. See your computer reference guide for assistance. Be sure to re-enable this important feature when FDISK is done.
Check all cable connections. Make sure pin 1 of the drive is connected to pin 1 of the hard-disc controller or host adapter.
Check for 1/0 address conflicts.
Verify the drive-type values in the system setup program. One of the following problems may have occurred:
The values may be set with an incorrect translation characteristic.
You may have entered a parameter value that exceeds the physical capacity of the drive.
You entered a translation characteristic that does not take full advantage of the drive's capacity.
The drive's physical specifications exceed the translation limits imposed by the BIOS.
CAUTION: If you change the drive-type values in the system setup program, you must partition and format the drive again. This erases data on the drive.
If you have partitioned the drive into individual logical drives, you may need to make the partitions smaller to access the full drive capacity.
If your computer supports LBA mode, you may need to enable LBA mode in the system setup program to access the full capacity of the drive. Refer to your computer's reference guide to find out how to enable LBA.
Your computer may not support drives that have more than 4,092 cylinders. Follow the instructions on page 25 for After you install your new drive, your computer will not boot, and no error message appears on the screen.
Reinstall the DOS system files using the DOS SYS utility.
Check all cables.
Use FDISK to verify that the primary partition is active.
Check for viruses.
Confirm the jumper settings on the drive.
Verify the drive-type settings in the system setup program.
If a problem persists, please search for a solution or post a question in our tech support forum in our Help Desk.
Oct 19, 2008 | Computers & Internet
Won't start up!!!
its a hard disk problem.. backup your important files then reformat it... or try to reinstall your os..
Apr 14, 2008 | IBM ThinkPad T30 2366 Notebook
Error 0200 fixed diskette error
Your hard drive crashed. They're fairly easy to replace. Ebay has great deals on 40 and 60 gb hard drives.
Feb 14, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T41 Notebook Logo
2,751 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
