Question about Packard Bell Computers & Internet
Install cmos battery - Packard Bell Computers & Internet
    Sergeant:
  • 310 Answers
Hi, replacing the cmos battery is quiet easy, just take off the side cover you will see a round lithium battery on the motherboard, take it out, find the same model of lithium battery and just pop in the new one and its all done, you usally get 3 of the batterys for about £5..
All the best
John
Posted on Jul 27, 2008
How do i replace the cmos battery
any generic replacement CMOS battery with the same specifications and size measurement as the original battery will do, I am not to familiar with the battery used on your laptop, for it may be installed with retaining clips, it may be soldered to the main board, or via sockets with wires, if you are not to savvy with electronics soldering , have someone who knows how , to do it for you. Replacing cmos battery is actually easy once you have secured the replacement part. refer to your computer manual for the location of the cmos battery on your laptop.
Oct 19, 2014 | Battery Biz CMOS Battery for Acer Compaq...
Were is cmos battery located
removing cmos battery doesnt work no matter how long you leave cmos battery out been there done that , you have to locate cmos jumper on motherboard , remove main battery & memory cards , peel back clearish foil on motherboard near where memory cards install , should see jumper points on motherboard , take bread tie touch jumper contact leave main battery out stand up like book plug in power adapter , and turn on only until boot screen then shut-off , install memory card , remove jumper and try starting laptop , if it hasnt cleared password , remove memory cards and try jumping it again
Mar 07, 2014 | Acer 4220-2346 Notebook
Cmos battery error failure
The CMOS (BIOS) battery keeps the computer'a comfiguration and the Date & Time settings in the CMOS (BIOS) chip in its memory. When the CMOS (BIOS) battery is flat these configuration information is lost.
Replace the CMOS battery with a new one, in most cases this battery is a lithium 3 volt battery type CR2032 and it is coin size battery 18mm in dia.(check it to make sure the type of battery is installed on your motherboard).
When you replace this battery then go into the BIOS and set the Date & Time etc.
Jan 26, 2012 | Intel DG31PR Motherboard
The clock goes to the wrong time after switch off. I then have to reset it on switch on. Is there a CMOS battery inside my desk top processor? If so, what No battery should I buy, and how do I install it...
Your CMOS battery is most likely dead, therefore you need to obtain a new CMOS battery either from another computer or most batteries are a standard 2032 battery purchased at any drug store. To install open up your computer and look at the motherboard for the battery that looks like a watch battery and install the new on in its place.
cheers
djbr1ck
May 13, 2011 | Computers & Internet
How to install CMOS Batterie
  1. loosen the scew 1but do not remove it: look at the picture below
mabroukmedal_1.gif 2. free the connector of the bacup battery:
3. install the new backup battery
Nov 08, 2010 | IBM ThinkPad 600X Notebook
Dell inspiron 1545 laptop (Time- of- date clock
This could mean two things: a problem with the cmos battery or the motherboard itself. Try to remove the cmos battery first and install. If not,then replace the cmos battery.
Oct 12, 2010 | Dell Inspiron 1545 Notebook
CMOS Battery do no work
Just change your CMOS battery with a new one and after that goto the bios settings and update the time and dare.
After that just save the settings and then check that the warning message is coming or not.
If its coming then it means you need to change the CMOS jumper settings.
Mar 09, 2009 | Asrock 845GV (P4I45GV) Motherboard
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
1. New hardware has been recently installed.
2. Error or confliction with settings in CMOS.
3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS.
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
CMOS BATTERY
Gateway 450ROG CMOS BatterySmall internal battery that maintains calendar and clock settings.
PLEASE NOTE: This is not the battery that powers your laptop; it only maintains certain internal settings. If you need a main battery, please refer to the page on our web site for your laptop model.
CMOS batteries are located on the motherboard; if you are not comfortable with the inner workings of your laptop, you may want to consider having the battery installed by a qualified technician.
Here is the link to their site for your cmos battery
http://www.gatewaylaptopparts.com/shopexd.asp?id=1082
Feb 25, 2008 | Gateway 450ROG Notebook
Computers & Internet Logo
1,048 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
