Question about Frigidaire ATF6000ES Front Load Washer
Noise when tumble spins a noise is coming from inside.there is a wire stucked inside.it came from a woman's bra.I can't see it or get to it.Please tell me how to get this wire out.
Problem solved,I removed the drainage hose on bottom of machine,opened the washer door,took a flash light to search for this wire that was stuck about a foot away froom drain opening.With a wire hanger I fished the stuck wire down close to the opening where I was able to grab it and remove it from the inside wall that it was stuck to.closed everything back up and that was that.
Posted on Jul 27, 2008
Model wm2487hwma - won't spin code 426 keeps coming up
try cleaning the filter out,it may appear clear but try putting your fingers right inside as some ties bra wires get stuck where you can't see them, hope it helps
Oct 25, 2013 | GE Washing Machines
Clicking noise
More than likely a bra wire stuck,,,get a torch,stick ur head inside drum & have a look,,,pulled hundreds out over the years
Jun 16, 2013 | Maytag Washing Machines
My front loader washing machine euromaid WM5 makes a terrible noise during spin cycle I think something like a screw is caught behind the barrel how can I access it ????
Hi! It's probably a bra wire if u have a woman in your life. They quite often get stuck around the heating element near the bottom of the drum. Get a bright light and stick your head in to see through the holes and see if you can pull it out! Hope this helps.
Feb 02, 2013 | Washing Machines
Bra wire stuck in washing machine
You could try a very thin pair of twezers, or a very thin magnetic pick up tool,you might be luck.. if not the only other way is to remove the ruber door seal to get acces to the inside of the drum.
Dec 28, 2011 | Electrolux Refrigerators
Our washer is making a grinding noise when the washer drains and when the tub spins any ideas what it might be. Washer seems to work fine just making that noise during a drain and spin cycle.
This sounds like you may have something caught in the drain pump. One of the most common items to get stuck in there is a woman's bra wire. Check it out.
Dec 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Problem with bra wire
a common problem, the wire usualy catches on the heater assembly and wraps around it, shine a torch into the bottom of the drum through the holes and you should be able to see it,if so remove the heater to remove the wire. the only other place it could be is in the sump hose so remove that to remove the wire,i must do six or seven of these a week
Jul 26, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Something stuck in drum, spinning cycle loud hammering/clacking sound
hi there,
sounds like you may have something caught between the tumbler and the cabinet. since the drum has holes in it, can you have a look if you can see anything that's come of clothing, like a bra wire. it's usually something bigger.
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bra underwire stuck
disconnect from electricity. take back panel off.you will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
Jul 14, 2008 | Electrolux EW1000i Front Load Washer
Bra wire stuck
you may not have to take the washer apart, take a good ligtht and look around inside the spin tub, if a part of the underwire is sticking thru, try and pull it out. Do not use the washer until the wire is removed or it actually could cut the tub and then the machine will leak $$$
Let me know the make and model if you need more assistance
T
May 22, 2008 | Washing Machines
Ticking noise in spin
Possible. First run your hand around the inside drum...be careful...sometimes there can be an object stuck in the holes and the extra vibration can set it off. common objects are bra wires and hair clips (sorry ladys its the truth) followed very closely by......(you guessed it ladys) Nails
Jan 03, 2008 | Bosch WFMC 3200 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
