SOURCE: Format error in Sony Cyber-Shot DSC-S650
Format the memory stick via setup menu inside the camera. Let me know if this works.
SOURCE: sony cyber shot DSC F717
Hi
Switch your camera to Setup on the control **** located on the top.
Take out the memory stick and press the reset button located inside the battery compartment.
Now switch on the camera and insert the memory stick.
If you do not get the error go to the little toolbox on the menu. Select the format option and proceed through the warning messages. Remeber you will loose all data on the memory stick.
Things should now work. If not some simple thing that sound bezare but has worked for me is pushing the memory stick in and out before the camera displays the error. Do this several times until the camera actually reads the stick and them format the stick first chance you get.
Good luck.
SOURCE: Sony Cybershot DSC S650 Memory stick not formatting
Well I have the same camera.
And mine won't turn on.
Suggestion dont trust this camera.
Or maybe it just can't hold that much memory.
SOURCE: Memory Stick error c:13:01
Is your new 2GB memory stick is original from Sony or after market? some of them will not detect in CAM because the contact on MS were not touched iside the slot of CAM
Reinsert your 512 MB MS if it work fine then change your 2MB MS
Good luck
SOURCE: Cyber-shot DSC-F828 memory stick error C:13:01
HI,
Please clean the gold contacts of your memory card.Take any lead pencil. Take the eraser and rub it on the gold contacts
on the memory stick as if you are erasing writing on paper. Do this for
about 30 seconds or more until you get all the gold contacts. Put the
stick in the camera, switch to 'Setup', then turn the camera on. The
'C:13:01' error will automatically disappear. At this point, quickly
format the memory stick using the camera's format feature.NOTE:
Al;ways use the camera's built in function to format your memory card.Do not use the computer to format the memory card.
If you still face any problems then you will have to get it repaired.
Thank you
