Question about Lenovo ThinkPad T61 Notebook
Screen image rotated through 90 deg.
My screen image has rotated through 90 degrees. this happened as i was resting something on it. i cant find out which keys to press to get it back normal
  • Anonymous Mar 13, 2014
    rotation 90 degrees counterclockwise about the origin
  • Anonymous Mar 28, 2014
    My screen displays upside down
  • 87 Answers
Hello , friend
Please do this shortcut
ctrl + alt + arrow keys
Posted on Jul 30, 2008
Well it worked wonder...........
thanks
Posted on Aug 15, 2008
Hi , can you tell me what is the torque settings for Main,biggens and head bolts for Opel combo 1.4 16v 2006 model z14xep motor?
STANDARD TYPE GM ROD BOLTS
STAGE 1---18 LB/FT (GRAPHITE GREASE UNDER HEAD, OIL THREADS)
STAGE 2---30 DEG's additional bolt head rotation.
CRANK BOLT
GRAPHITE GREASE UNDER HEAD & WASHER, OIL THREAD
STAGE 1---70 LB/FT
STAGE 3---15 DEG's additional bolt head rotation.
CYLINDER HEAD BOLTS for standard gaskets
GRAPHITE GREASE UNDER HEADS & WASHERS, OIL THREADS
SEE SEPARATE SHEET FOR TIGHTNING SEQUENCE
STAGE 1---18 LB/FT 25NM
STAGE 2---90 DEG's additional bolt head rotation.
STAGE 3---90 DEG's additional bolt head rotation.
STAGE 4---90 DEG's additional bolt head rotation.
STAGE 5---45 DEG's additional bolt head rotation.
Nov 06, 2016 | Opel Cars & Trucks
MY LHP LV 2311 MONITOR SCREEN IMAGE ROTATD 90 DEGREES
Press Ctrl + Alt + Up Arrow Keys at the same time to rotate it.
Dec 08, 2013 | Computers & Internet
Gateway laptop computer screen is upside down and can not use mouse
Shortcut Key To Flip The Screen In the Windows TO 180 Degree..
The shortcut is (or should be, read below**)
for normal windows : Ctrl + Alt + <Up arrow> (or shift+alt+<up arrow>)
and for 180 deg it is : Ctrl + Alt + <Down arrow> (or shift+alt+<down arrow>)
However, you should know that these are default shortcuts for
Intel Extreme Graphics Controller, and you can change them. To
check / change or disable these keys go to control panel->Intel Extreme Graphics->Hot Keys.
**sometimes the shortcuts do not work. This happens when you have not enabled rotation
feature in Display Settings under Intel Graphics Media Accelerator media. You need to
enable rotation in order to be able to Rotate / Flip your windows screen upside down / 90 / 180 / 270 degrees.
Mouse: with mouse, do you mean a usb mouse or the mousepad? if the mousepad isnt working, check ur "F" keys for an icon that looks like a mousepad icon. Then press the "Fn" key + the corresponding mousepad icon key and see if it works.
Oct 15, 2013 | Gateway CX2610 Notebook
F 20 error message
F 20 errors are presented by front loading washers that have debris in the filter sreen / pump inlet area. Open the lower panel... have something like a cake pan and mop ready then rotate the 5 inch circular piece CCW 90 deg and pull it out. This is the filter. Clean out the screen.. then look inside the cavity and remove any debris in the cavity paying particular attention to the pump inlet. Once clean press in the filter and rotate it 90 deg clock wise. Close the lower panel and reset the machine. Test for leaks....
Thanks for choosing FixYa,
Kelly
Jun 16, 2011 | Kenmore Washing Machines
Ok so my math hw only gave me the degree, minute, sec format of the angle. How do i input it in the fx 155 es to work out and find the rest of the angles, sides, etc?
Label of key [deg symbol ' "]. It is between [(-)] and [hyp]
To enter a value in decimal degrees
12.58 [deg ' "] [=] Screen displays 12.58 deg on top line and 12 deg 34' 48" on bottom line.
Pressing the [deg ' "] key while this value is displayed will show 12.58
To enter a DMS value:
Press the [deg ' "] key after each number even if one of the numbers D,M,S is nill (0).
Exemple Enter 25 deg 0 ' 48"
25 [deg ' "] 0 [deg ' "] 48 [deg ' "] [=]
Screen displays 25 deg 0' 48" on bottom line
Pressing the [deg ' "] key converts this result to decimal degrees 25.013
This showed you how to enter angles in DMS or DD. For the rest 'find the angles, etc.' you should refer to your trigonometry manual: You have the definitions of the trigonometric ratios, the sine law, the cosine law to resolve triangles.
Feb 24, 2011 | Casio FX-115ES Scientific Calculator
How do you change out water filter?
Hi and welcome to FixYa, I am Kelly
Press in hard.. rotate it 90 degrees Counter clockwise and wiggle / pull it out. When you re-install a new filter align the filter with the internal locking tabs and press in hard and rotate 90 degrees clockwise.
Some times the filter can br really fussy to remove you just have to keep wiggling and pulling to get it out of the recepticle once you have rotated it 90 Deg CCW.
Kelly
Feb 14, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Screen does not display
I had the same problem. more than likely your connector cable between the camera and the display has become brittle over time and is beginning to break. as you open the screen the small wires inside the cable are separating. mine went from 30 deg view to 90 deg no display as yours is now, then 30 deg fuzzy display (cant make out the picture like a VHS when it needs heads cleaned) then the cable gave in and snapped. all the way through. Simply not a lasting camera. I got quotes and it was about $200 to fix. for that price these days u will pick up a better camera anyway. Good luck
Nov 19, 2008 | Panasonic NV-DS60 Mini DV Digital...
Samsung Monitor image rotates 90 degrees
Use ctrl+alt+ up Arrow key (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Mar 27, 2008 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Elongated desktop and software screen images
Many graphic cards enable you to rotate the screen up to 360 degrees. You could try to post this question again under you graphic card model instead of computer screen model as it is your graphic card that is certainly the problem.
Jul 25, 2006 | Microsoft ChiMei CMV938D 19" Widescreen...
How can the image be rotated?
To rotate a vertical image, display the image in playback mode, press the down key to cycle through the three positions: 90 degrees counterclockwise, 90 degrees clockwise, and horizontal. Upside down position is not available.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
Lenovo ThinkPad T61 Notebook Logo
1,477 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
