Question about Sony Ericsson K800i Cellular Phone
Help!! i bought my phone just 2 mos. ago, had a problem using the button for the cam, instead I'm using the joystick to take pictures.. because every time im taking pictures using the button it wont work, just the light and even i long press, it didnt work.. whats the problem on my phone? pls. help me
    Genius:
  • 1,011 Answers
Dear,
it seems that your button is pressed permantly. it may be because of casing.. check it after removing the casing or try to solve it by repairing. but check it first after removing the casing. try to press it openly. if it is physically pressing then either that button is damaged or there is a possibility of software key selection.
try both options.
regards,
Posted on Jul 28, 2008
I have nothing but trouble with this thing since i bought it about 3 mos ago..now i can't even use it cause no one can hear me on it even tho i'am screaming... i'am on s.s. and payed 80.00
call the company and explain what is going on with the phone.. my mom had the same problem. they replaced her phone and now it works great.. she was told she got a defective phone. the phone number should be on the box the phone came in
Feb 23, 2012 | Uniden 2.4Ghz Cordless Phone w/ Caller ID...
Tip
For all SE T6XX phone users
Hi to all T6XX users. I created this thread just to help you find most of
the tips and tricks that can be done on T6XX. Hope this will help
reduce searching and posting.
I tried them on my T610 with fw R3C002 and all of them work.
1. O.k, i'll start with the camera.
On phones with newer firmware, u can use the joystick to adjust
saturation and shutter speed (brightness).
Up/Down to increase/decrease brightness
Left/Right to adjust saturation.
There are shortcut in the camera function:
Press 1 to change the size of picture
2 to act/deact Night mode
3 to turn on/off Effects
4 to act/deact Timer
To prevent the software from compressing the pictures taken by the
camera, u should continuously tap the joystick or the camera button
until it ask Send-Save-Discard and the backgroung will become black.
After saving the picture, take another one and the phone will process
the previous picture and u should get a clear and sharp picture.
But the disadvantage is that the picture will take about 50-60kb
instead of 30-40kb.
2. Cut-Copy-Paste function (only available whn editing contacts in
phonebook)
Highlight the contact to be edited and press More and choose Edit
Contact. Now, for example if you have replace the number in Home by the
number in
Mobile, just highlight Mobile and press and hold * followed
by 1, the number will disappear. Highlight Home and press and hold *
followed by 3. The number will be pasted here.
Cut - press and hold * then 1
Copy - press and hold * then 2
Paste - press and hold * then 3
3. Add a ghost image (not ghost that
ur thinking of, i'm talking about
a hidden image) to a contact.
Add the image u want to the contact. Now in My Pictures, open the image
that u applied to the contact and rotate it. When u'll erase the image,
the phone won't say that the picture is in use. U can erase it and the
picture will stay applied to the contact. To see the image, u just have
to Go in Phonebook-Pictures.
---Please note that u can't move back the picture in My Pictures, so
backup the picture before doing this---
4. Highlighting texts.
When u are writing a message or anything else, u can highlight a
part of it so that it can be erased or formatted quickly. to do
that, press and hold a Volume Button and move the joystick to
highlight.
5. Memory function in Calculator.
If u have save a number in memory when using the calculator, press the
Volume button +
6. Write text messages with the WAP button.
Create a new bookmark with any name and write mailto: in Address.
U can also use it as a template. For example if u want to create a new
text message with Hello already written in it, the address should be
written like that, mailto:Hello
That's a very nice trick as a new text message can be created with a
starting phrase already written using the WAP button.
7. How to get extra memory when it's full
Create an empty theme (without pictures) with Theme Creator, send it to
the phone.
When
ur memory is full and that u need some more memory to take
pictures or record sounds, apply the empty theme and u'll get extra
memory, the amount that will be freed up depends on the size actual
theme. Normally it frees up between 20-100kb.
on Sep 25, 2008 | Sony Ericsson T630
I need an unlocking code for my Sony Ericsson Xperia E15i
How to use the Unlock Code (This will be emailed along with your codes)
Sony Ericsson E15i Xperia X8 sony_ericsson.gif sony_ericsson-e15i_xperia_x8.gif
How to enter the Unlocking Code for a Sony Ericsson Model phone General Information about your Sony Ericsson unlock code
When you receive your email with your unique Sony Ericsson unlocking codes, you may see there's actually more than one code, as some models require more than one code to unlock them fully. However, for simplicity, we do aim to send you a single unlock code, which will be your network unlock code (known as the NCK).
(See below for more details about code formats and more - Please read all before you start unlocking?)
Option 1 - Sony Ericsson Models
1. Turn on the phone without SIM Card in it
2. Press the 'left arrow' or joystick left once
3. Press the * (Star) button twice
4. Press the 'left arrow' or joystick left once
5. The phone will display one of either messages saying 'Personalize with MNC2' or 'Personalize with MNC3'
6. Wait approximately 5 seconds.
7. The phone will display 'Network' and a picture of a closed padlock.
8. Press Select.
9. The phone will display 'Unlock (Net) 5' and 'NCK:'
10. You can now enter the Unlock Code provided.
Option 2 - Sony Ericsson Models
5. The phone will display the message 'Personalize with MNC2'
6. You can now enter the Unlock Code provided.
Note for options 1 & 2
- When doing the first 5 steps above you'll need to do it quite quickly. - If your phone has a joystick 'JOGDIAL' you must press the 'down arrow' instead of the 'left arrow' in steps 2 to 3 above. By 'Down Arrow' we mean move the joystick down
Quick Glossary
NCK = Network lock
SPCK = Service provider corporate lock
SPK = Service provider lock
Code formats you may receive for Sony Ericsson models:
Wherever possible we'll try and send you just a single unlocking code to unlock your Sony Ericsson.
However for certain models we may need to send you more than one code, even if you don't use them all.
It would be a sting of codes as per this example:
CCK: 0984118391686835 or 0984118391686835
ESCK: 0000000000000000 or 0000000000000000
NCK: 4176979876474847 or 4176979876474847
NSCK: 3908320398047435 or 3908320398047435
PCK: 2061751224321908 or 2061751224321908
SPCK: 9960493992337231 or 9960493992337231
Note: The NCK (Network unlocking code) is the main and usually the only one you'll need.
Please note:
- If you see the message 'NCK: (0)' or 'Not Allowed', this means the phone is hard-locked. The phone cannot be unlocked because there has been more than 5 wrong unlock attempts.
- If your Sony Ericsson has a Joystick, then you must press the DOWN Arrow instead of the LEFT Arrow. DOWN Arrow meaning Joystick downwards
May 30, 2011 | Sony Ericsson Cell Phones
Can anyone help. How can I unlock my Sony Ericsson X8 which is on Vodaphone Ireland. Thanks in advance.
Instructions Unlocking Instructions for Sony Ericsson XPERIA X8
How to insert the Unlock CODE into your Sony Ericsson XPERIA X8
  1. Power ON your Sony Ericsson XPERIA X8 with an accepted SIM Card.
  2. Press the LEFT arrow or joystick button once.
  3. Press the STAR (*) button twice.
  4. Press the LEFT arrow or joystick button again.
  5. You will briefly see one of the following messages listed on your Sony Ericsson XPERIA X8 display:
    • Personalized with MNC2
    • Personalized with MNC3
  6. Wait approximately 4 seconds.
  7. The display will indicate "Network" and a picture of a closed padlock.
  8. Press Select.
  9. The display will indicate "Unlock (Net) 5" and "NCK:"
  10. You can now enter the Unlock CODE supplied by UnlockallCellular.com.
  11. Your Sony Ericsson XPERIA X8 will display "Network unlocked" and then "Insert SIM" message.
  12. Your Sony Ericsson XPERIA X8 is now unlocked!
If your Sony Ericsson XPERIA X8has a Joystick (for example SonyEricsson K700i), then you must press the DOWN Arrow instead of the LEFT Arrow for step 3 & 5. By DOWN Arrow I mean directing the Joystick down!
Feb 14, 2011 | Sony Ericsson XPERIA X8 Cell Phone
Replaced engine 2 mos ago. Shuts off, start back
fuel pump is probably in need of replacement. big problem with grands they will work intermittently or overheat an short out. make sure gas tank is low before replacing it, please also replace fuel filter (bosch brand fuel pump better than airtex) i hope this helps you
Sep 04, 2009 | 1999 Jeep Grand Cherokee
Z525a screen comes on but stays vacant.
If you have access to a laptop computer that has an Infrared Port or Bluetooth communications, you can download your videos and picture files via either of these two methods. I use an old IBM Thinkpad 600 with IR port to download mine. You have to put your z525 phone into Infrared mode first, its kind of tricky with out seeing what you are doing. First, open your phone, press upper right (-) sign to get menu, click joystick control down 2 times then right 1 time. next press upper left (-) sign to select. next joystick right 4 times, and down 1 time. press upper left (-) sign, then joystick up 1 time. press upper left (-) 1 time. Your Infrared Port will now be turned on, and your I.R. enabled laptop can now receive the files from your phone. Close your phone, open it again, press upper right (-) , press joystick down 1 time, then left 1 time, then press the joystick center select button 2 times. Joystick right 1 time, press joystick select 1 time. press upper right (-) 1 time, joystick down 5 times, joystick right 1 time, joystick down 3 times, joystick center select 1 time. Hold the lower left corner of your phone toward the I.R. port of the laptop, it will receive the first photo file in your camera pictures file. Another possible method would be to obtain a usb connector cable for the z525 phone to connect it to your computer. Using the usb cable the computer would recognize the phone, you could click on the phone icon, under "MyComputer" and transfer the files to your hard drive. I hope this helps. -Mike
Mar 09, 2009 | Sony Ericsson Z525a Cellular Phone
Setup wizard
First open your phone, then press upper right (-) key to get to menu. press joystick down 2 times, then right 1 time, to get to Settings. Press joystick center select button, press joystick down 9 times to get to Master Reset, press center select button. Joystick down 1 time to get Reset Device, press center select, then press upper left (-) key. This will delete all user settings & data, including pictures, messages, data, sounds, games, contacts etc. The phone will be restarted. If this doesn't fix the problem, you will most likely need to replace the internal wiring harness.(Not a job even I would enjoy!) Hope this helps.
Oct 31, 2008 | Sony Ericsson Z525a Cellular Phone
Kodak easy share self-timer
You use the the self timer as follows:
(1) Push the Menu button on back of camera
(2) Scroll through the Menu items using the small joystick located in the center of your circular selector switch, until you highlight the self timer ON/OFF area
(3) Push the small joystick straight in, like a button
(4) Use the joystick to highlight the on position
(5) Push the joystick button
(6) & just snap the picture as usual.
You will have to use the viewfinder instead of the screen to point the camera.
Hope this helps
Ron
Dec 25, 2007 | Kodak EasyShare DX7440 Digital Camera
When using the zoom button the cam stops working
This suggests the zoom motor has failed. As you only purchased it 2 weeks ago - it should be replaced under warranty
Aug 21, 2007 | Panasonic Lumix DMC-FX50 Digital Camera
Sony Ericsson K800i Cellular Phone Logo
32 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
