Question about Dryers
Creda T620CW condenser dryer
My dryer does not get warm anymore, I have changed the thermostats but there has been no change.
  • Anonymous Jan 02, 2009
    I have a Creda dryer and I've changed the thermostats -- the first set blew (it's a good thing I ordered 2) so went to 2nd -- even with the new thermostats it's blowing cold air -- is there a diagram of the wiring I have blue and orangie wiring -- is there a placement for them ***** contact me at christyj51@yahoo.com Thanks
Recently bought condensor dryer which was working fine till the very cold weather came. Is situated in the garage so temp has been going well below freezing some nights. Now keeps switching off after a few minutes and empty water light flashes although resovoir has no water in it. Is this due ti pipes freezing?
Posted on Jan 03, 2011
Creda T601CW 6Kg Advance Condenser Dryer The belt
Creda I don't know from. Sorry
Nov 20, 2011 | Dryers
My creda mode tcr2 isnt drying my clothes anymore
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 30, 2011 | Dryers
WE HAVE REPLACED HEATING ELEMENT. AND THERMOSTATS. ON A CREDA T620CW TUMBLE DRYER. AND STILL NOT HEATING UP.ANY IDEAS PLEASE.
Reset overtemp thermostat should be small round disk attached to drum with a little red button.. Press firmly should reset ..
Feb 28, 2011 | Dryers
I HAVE A CREDA SIMPLICITY T620CW WHICH CUTS OUT AFTER A SHORT WHILE AND WILL NOT RESTART FOR A WHILE. IS THERE A THERMAL CUT OUT ON THIS MODEL OR IS IT THE START SWITCH THATS AT FAULT? WHILE IT IS ON IT...
Yes, this model has a thermal cut out and you are correct in thinking that this is the reason why the dryer cuts out and will not re-start for a while.
However, although it's possible that the thermal cut out is faulty, the more likely and common cause is a failed thermostat. If the thermostat fails in the closed (on) position, it means that there is constant power to the heating element. This will cause the dryer to overheat and the thermal cut out will trip to prevent damage to the dryer. A correctly functioning thermostat opens and closes to switch power to the heating element on and off to keep the dryer at a roughly constant temperature.
Hope this helps.
Regards,
BElectric
Nov 18, 2010 | Dryers
My white knight condenser dryer doesn't heat up anymore what do i need to replace?
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat is this video does not help go to our video section and there are a few on other condenser dryers
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Mar 25, 2010 | Dryers
How do I replace the belt on my Creda T620CW tumble drier
most credas you need a stretch tool to stretch the belt from drum to motor if there is no jockey pulleys good luck.
Sep 14, 2009 | Dryers
Trying to find spare parts in Australia for my Creda T620CW Dryer
A lot of times you can go to the manufacture websit and find a dealer in your area. Also you can call the company and they may be able to guide you to a vendor as well. Hopefully this helps.
Apr 10, 2009 | Dryers
No heat in tumble dryer
Is this a gas dryer, if so check the thermal fuse, should be white plastic with 2 wire ports. These tend to bad first. Thanks Dave www.washermd.com
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Creda condenser dryer
remove the back plate and check the heater and stats. probaby the stat open circuit
Jul 11, 2008 | Dryers
Tumble dryer wont dry
hi do you have any blockages in the vent system (lint) can you hear the fan running and are the filters clean.did you put it back together correctly.hope this helps.
Mar 05, 2008 | Dryers
Dryers Logo
271 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
