Question about Carrier Heating & Cooling
I have a Carrier Model 38CKB030320 outdoor A/C Unit. I hit the re-set button that start the unit, but the button will not set on the copper strip and turns off. Also, when the system was on the blowers or no air was coming from the vents
    Guru:
  • 1,894 Answers
First check your filter
and then check your fan motor voltage sir.
this will help you sort out the problem
Posted on Jul 26, 2008
  • dewan nafees ahmed Jul 26, 2008
    1st
    check your filter to see if its clean , it may need replacing 2nd check
    your vents to see if they are open , third your coil inside your A C
    unit may be frozen, turn off the A C unit and turn your vent fan to on
    till it thaws out the coil. if none of this works your coil may be
    blocked with dirt , due to not using a fliter or air leaking around
    it. This will take professional help.
  • 19,396 Answers
Trydisconnecting unit from power for few minutes and connect it back, this should reset the unit.
Mr slim MXZ, working but not cooling, no error codes on outdoor unit
Possibly the outdoor board??? Are the copper lines sweating? Are you heating or cooling?
Jul 15, 2017 | Heating & Cooling
Carrier ckc outdoor unit not starting automatically after installation
It is important that the connections from the outdoor unit is wired to align correctly with the indoor unit where the main control panel is located . The outdoor unit compressor is switched on from the processor here and so it is marked in detail to connect the wires.
Now the if the indoor unit is not powering then there is fault in the main control panel and you need to get help as this is a new unit and warranty should not be compromised.
It is possible that the new unit has a damaged control panel or power and so does not power. take help.
Aug 22, 2011 | Carrier 38CKC042 Air Conditioner
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
Wansa split a\c outdoor unit both pipe size
It depends on the make model of your unit , the capacity of the unit. It will be best to check the pipe sizes that are on the outdoor unit and the indoor unit that needs to be connected.
The copper pipes can then be decided after checking the length of your fitment.
Jan 08, 2011 | Heating & Cooling
I have a carrier heat pump model # 38RQ034300 I need instructions for. To maintenance and use thermostst correctly
That is model number for your outdoor unit. Thermostats are not dedicated to any particular model outdoor unit. You need instructions for the thermostat so the thermostat make and model number are needed.
Oct 16, 2010 | Carrier Heating & Cooling
I have a domestic carrier air-conditioner in
There should be an Error code cheat on the back of the electriacl cover that explains what each blink or sequence means. If it doesnt have one then just go online and look up the Model/Serial number up on the Carrier website and it should tell you.
Jan 07, 2010 | Heating & Cooling
Outdoor carrier cond. comes on but the indoor
Bearings in fan motro bad or bad capacitor. Depending on size of unit should be 5uf 370 capacitor. Replace cap. ans try to start unit.
Jun 10, 2009 | Heating & Cooling
Carrier hi wall split unit on light flashes 4 times ???
as i am a mechanic in sydney australia, i can honestly say that the chance of you getting help via carrier is very very slim... the reason it is doing that is that it has a legitimate problem unfortunately i have a carrier 42g250h which is flashing 4 times aswell... i have been waiting now 10 working days for carrier to call me to tell me what the problem is... if you can afford to do it, throw the damn thing out and buy a new one, i hate to say it but even an LG will work better than these heaps of ****
Feb 23, 2009 | Carrier 38CKC042 Air Conditioner
RE: Carrier Unit Central
Try first cutting system power for a couple of minutes, even from main. With some luck it can be enough to reset the system, as it looks like a problem with the control board. The control board has also a coin battery and a reset bridge on it , but to access them you need to take apart control unit. Try fist turning off main power switch for 5 minutes or so.
Jul 26, 2008 | Heating & Cooling
Heating & Cooling Logo
212 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
