Question about Dryers
How to fix a Simpson Maxidry 1000p?
My brother was repairing his Simpson Maxidry 1000p and the tensioning bracket and spring have come off. He didn't see where it came from and three of us cannot work it out. Is there a picture i can get as he dooes not have internet connection to find out himself.
  • Murray720 Apr 27, 2009
    I have seen on another website that one end of the idler wheel bracket tensioning spring goes around the electric break-apart gizmo attachedto the outside of the dryer. When the spring comes off, this gizmo pulls apart and cuts the power. It is a white nylon plastic thing, with a wire out each end, and "grooved" to take the spring. The other end goes in one of the 2 holes on the mount bracket. I still need a diagram to see how to route the belt. The triple-groove runs on the motor pulley, and the flat outside seems to run on the idler wheel. April 2009.
    I haven't fixed mine yet
Idler pulley and spring have come off while cleaning dust from inside cabinet a diagram whould be a great help as Im 500kms from nearest service place simpson maxidry 1000p Ray bushed
Posted on Jan 04, 2010
Can you please tell me where I can get a Simpson Maxidry 1000 user manual or any other kind of manual for this dryer?
Try this link:
http://fasterbetterdownloads.com/simpson-maxidry-1000p-user-manual/
Jun 20, 2015 | Dryers
Simpson Maxidry 362. Tips on putting back together....? Roller tensioner spring attached to...?
Here are the steps to get the belt and tension pulley and spring attached properly.
1. Remove the drum from the dryer housing
2. Fit the belt around the drum, secure the belt to the drum (grooved side towards the drum, flat side away from the drum) with small strips of masking tape. Leave a loop of about 10-15 cm's free to fit around the motor. (This was Hurdle #1, it was next to impossible to hold the belt on with one hand and attempt to work out the tension pulley thing at the same time)
3. Place the drum back in to the dryer housing and rotate it so that your belt loop is facing the motor.
4. (Hurdle #2) Attach the tension pulley to the motor assembly bracket. (There should be slots in the bracket for the pulley bracket to insert into. The pulley faces away from the motor, about a 45 degree angle.
5. (Hurdle #3) Feed the belt through (under) the pulley and then over the motor's drive wheel or nub, whatever it's called.
6. (Finaly Hurdle) Attach the spring to the pulley assembly. In the centre of the dryer housing floor, there should be a seam, in the centre of this seam there is a small hole where the other end of the spring attaches too. Stretch and insert the other end of the spring into this hole.
7. Remove the masking tape that's holding the belt down.
8. Re-assemble dryer and your done.
Jun 20, 2008 | Dryers
Air no longer venting out back of dryer
sounds like the fan not working.
Apr 06, 2013 | Dryers
I want to mount my Simpson maxidry to the wall but unsure how. I have the brackets, does it go upside down ?
I'm afraid I can't help because I have the same issue, but I know the controls come off and remount the other way around so that, while the dryer is upside down, the controls are the right way up. I know this because a service man did it to the dryer in my unit while he was repairing it. I wish I'd watched him. :-[
Jun 08, 2011 | Dryers
No power to motor checked continuity of main switch the door microswitch is brand new and has continuity so to has the spring loaded idler circuit breaker switch, dryer was running after pulled down and...
I know you have already checked but first things first: breaker is not tripped, have 220 volts at outlet, have 220 volts at terminal lugs of dryer, if yes to all then some motors have a switch on the motor, do not know if yours will, it is where the power plugs into the motor, one is a trip the other a reset. Now we get into the other aspects of why dryers will not start, since the door switch is eliminated, then it is on to the others, here is a website that will help, now if all checks good feel free to post, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 28, 2010 | Dryers
Hi guys got a simpson maxidry 1000p dryer problem is that it has no heat is it stuffed or can it be fixed
Well first of all you may check out the Heating element - If a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter (volt meter). No continuity means the element is bad and you need to replace it (electric heating element not repairable) further you may check the Thermal fuse - A thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse, which is about an inch long, usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. And the last dought goes on the Wiring - you need to deep inspect the wiring in your dryer and check for any burnt sign.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Dryers
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
Clothes Dryer tripping house circuit breaker
If it is breaking the main circuit of the house there is something wrong. It should throw the breaker to the dryer only. It sounds like you are having a problem with a short between the main breaker and sub panel in the house. Is there any way you can move the breaker in the panel to a different place on the same panel to see if it is that circuit only. If not check the outlet and the plug on the dryer and make sure the wiring is connected correctly.
Aug 03, 2009 | Dryers
Dryers Logo
1,184 people viewed this question
Top Dryers Experts
