Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Aquarius wd 440
I have cleaned and replaced filter problem still exists with lights on front panel still flashing etc.Any ideas ?????
  • 57 Answers
Hi mate the problem you have is cause by a short in the motor which has blown a track off where the motor connector plugs in you will have to get a new motor and repair the track
Posted on Jul 28, 2008
Led key light flashes on my mwa64 hotpoint washer
Possible that the INLET and OUTLET - DRAIN filters are clogged or there is limited action. Remove and clean inlet and drain filters.
Also check on the connectors from the panel, reset all connections.
Jan 17, 2013 | Hotpoint Aquarius WF000 Front Load Washer
Hi our hotpoint wf541 starts its cycle as normal but doesnt spin and the mini load and reduce crease buttons flash as well as the on/off button, any ideas of how i can fix this thanks.
hi i had the same problem.
its either your filter is blocked or your pump is not working.
after switching the power off, remove the front bottom panel of the machine and unscrew the filter cap on the right behind that panel. check it's intact and clean iside, if not clean it out or replace it and that should fix it. be careful screwing the filter cap back in and make sure its on tight.
to check your pump is working you can pull out the machine and check that water is coming out of the hose by putting it on the pump out / drain cycle after pouring in some water for it to pump out.
Dec 08, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Dec 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Aquarius wf541. Am trying to remove pump filter to clean .
think yourself lucky my plastic broke when i was unscrewing it or tying to ended up cutting my knuckle open on the shard of plastic and water pumping out all over my kitchen is there somewhere that you can purchase the cap from and how do you get the broken one off???
Nov 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Will not pump out
you will filter is blocked if you pull the machine out and the the waste pipe drop into a bowl or a bucket the water should run out the filter is underneath the tub black hose going to pump held on by screw clip remove back panel to see this UNPLUG MACHINE FIRST. undue screw clip pull down black pipe gentle there is a ball in there then a plastic filter clean and replace.
Jun 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarious wd 440 two years old tripping main board
A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
Mar 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
69 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
