Question about Denon AVR 3808Ci Receiver
No output of hd audio
When i play my sony playstation 3,blu- ray discs with dolby digital,dolby true hd,and dts hd master,are not being encoded ,screen says mulit channel in. muts be in the settings,what settingsdo i need to change,ore set up to receive the new hd audio
Change audio settings on PS3 to PCM not bitstream
Posted on Nov 06, 2008
Is there a way to read Blue ray disc from Europe on a sony BDP-S1200?
No! Sony has kindly locked there BDP range of BluRay players to the region country they were made for only and not multi region.
Jan 18, 2015 | Sony BDP-S1200 Blu-ray Disc Player - 1080p...
Unlock Sony BDP-S1200
Have you been playing cd etc from different countries. The cd units in this country will lock you out after about three tries, that is the law.
Dec 19, 2014 | Sony BDP-S1200 Blu-ray Disc Player - 1080p...
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Onkyo HT-S3400 not showing DTS-HD Master Audio
Hello, with the source playing press the display button on the remote. What format do you see? Thank you, CB
Apr 05, 2017 | Onkyo 5.1-Channel Home Theater Package...
Different Audio output between DVD and Blu-Ray DVD
m4wolf
The issue is that not all videos use DTS. Look at the videos that you are trying to play do they support DTS if so make sure that you are selecting the DTS track in the audio setup.
In regards to your receiver if it does not support Dolby Digital then you might want to look at upgrading to a receiver that supports Dolby Digital and DTS if you want true surround on all your videos.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 12, 2010 | Sony PlayStation® 3 (60 GB) Console
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Oct 24, 2009 | Kenwood VR-405 Receiver
Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
Aug 21, 2009 | Audio Players & Recorders
Not showing DTS MASTEr OR DG True HD
In the menu is an option for switching master and true hd on. Standard its of and played als normal dts/dolby.
also: check the input (blu ray?): maybe it is set to only output no high def signals, so the amlifier doest recieve hd sound..
Igor
Dec 14, 2008 | Audio Players & Recorders
Playstation 3
First of all, Linear PCM is the best option to choose. PCM (Pulse Code Modulation) is a format for uncompressed raw audio data.
Some 5.1 sets have Dolby ProLogic II for example. The raw PCM output gets spread at your speakers dynamically. Meaning the decoder of your set interprets it the way it thinks is best. For example, if it gets a high frequency tone, it sends it to the center speakers as for human voice has a very high frequency. The center speaker is meant for dialogs.
But when you choose a compressed, encoded format such as Dolby or DTS the channel devidance is already mixed for you for optimal theatre experience.
When you choose DTS or Dolby in the menu of your Blu-ray Disc it will originally output a raw PCM audio stream. The decoder knows how to decode the DTS data out of it when you use the DTS audio track from the movie. The same goes for Dolby. Some movies can output pure PCM, but then most sets use ProLogic II to devide it over the speakers.
It's kinda hard to explain how it works, bottom line is.. there's nothing wrong.
I hope it makes sense to you and your question is answered.
Greetings,
DarkNeogen.
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
Denon AVR 3808Ci Receiver Logo
458 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
