Question about Whirlpool GD2SHGX Refrigerator
Light the light on fresh food side only is out, i check the switch,and change bulbs
I have a Whirlpool side-by-side refrigerator. The freezer is too cold, ice cream get has ard as rock, but the fridge side is very warm, althought i turn it to to the coldest setting. Food is getting bad very fast. Does someone know how to fix it?
Thanks.
Posted on Aug 02, 2008
Why on my model FRS6LR5EW3 freezer side is working maintains ice but fresh food side is not working, no light, no fan??
Good Morning Friend,
I understand the freezer portion is working on your Frigidaire refrigerator, model# FRS6LR5EW3, but your refrigerator does not seem to be as cool as it should, due to the fan not working. I also see that the light is not working, even after changing it out. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and see if the light is on. Also, listen for the fan to run and give the refrigerator portion of your appliance 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire Refrigerators
No power and no light in the fresh food compartment
Start with a light switch. Might need a new board too.
Jul 25, 2012 | Frigidaire Refrigerators
Light does not come on when you open door
Test your 40 watt light bulb in another fixture if the light bulb is OK then unplug the refrigerator and open fresh food compartment and pry out the light switch. Test for continuity HERE For some reason your model shows an additional light switch on the control panel located inside the fresh food compartment above top shelf. Try switching the ligh switch on from there. Here is a Photo Click HERE Here is a replacement light switch=> Light-Switch-2149705-00557365 If you have any questions I will be here to answer them for you, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire side-by-side model GHSC39EJPWO. Light in frig don't work, tried changing bulbs; didn't help. I cannot find the light switch - where is it located? I have examined everywhere!
I too am very perplexed by that i have looked at the parts breakdown and see a switch for the freezer in the side wall but no switch for the fresh food section. I have included the link for the parts breakdown i was looking at, the freezer light switch is item# 14A
http://c.searspartsdirect.com/lis_png/PLDM/R0804082-00003.png
Good luck
Gene
Aug 02, 2011 | Frigidaire Side by Side Refrigerator 26...
Light wont shut off, heats up to 88 degrees
Most times this is a defective fresh food section door light switch located in this photo as location number 609. Click Here=> PSC23NSTESS Fresh Food Section I am going to send you the service manual for your model and the information that explains how to change the switch is on page 19. If you do not already have the new free Adoobe Reader installed on your computer click here=> Adobe Reader X (10.1) Just make sure to uncheck the items not needed during the download. There also could be another problem related to the mother board that can also keep the light on while door is close but not likely. The part number for the light swirch is=> WR23X10175 Light Switch Information on how to test the switch is also on that page. Until we have repaired the problem please unplug and remove the lights because this heat will keep the refrigerator running and possibly melt the plastic housing holding the bulbs. Click here for the=> GE Artica/Profile Service Manual
Here is another page with information and wiring diagrams=> GE Artica/Profile Technical Information
I will be here to assist you if you have any questions so feel free to let me know, Thanks Sea Breeze
Please rate this solution and as always Thank You for using Fixya!
Jun 21, 2011 | GE CustomStyle PSC23NSTSS Stainless Steel...
Light in fresh food compartment is not working & bulb are good
May be door switch or just that the bulb is not turned in far enough to make contact.
Nov 18, 2010 | Frigidaire PHSC39EGS Side by Side...
Ess22xgmdww light wont turn off and fresh food is not cold
push the light switch in and see if light goes out,if not change the light switch,if it goes out check to see if door has dropped down,sometime the door cam or hindge problem drops the door down and can't hit the light switch to shut it off,i've seen 40 watt light bulbs deform the plastic on the door and the floor of the fridge so take out the bulb for now,
Nov 01, 2009 | GE Refrigerators
Problem with fresh food side of my refrigerator freezer
The bulbs dim glow is a worry, sounds like not enough voltage is getting there. If you are comfortable with a multimeter, check what the voltage is at the bulb socket. If you have a low voltage issue due to say the transformer not working properly then the fan will also have low voltage (or no voltage). No power, no fan, no cooling. I'd suspect there are voltage issues with that transformer, especially since it's a 240 VAC model. A transformer typically steps down the 240 volts to 120 volts for light bulbs and maybe even the fans (or the whole refer). The repair man may be correct in that the transformer is built in to a circuit board but it COULD be a stand alone transformer.
Oct 29, 2006 | GE Profile PSW26P Stainless Steel Side by...
Fresh food compartment not cold, light is lit when door closed
Engwah, is this the correct model number or does it start with PSS. The light should do just the opposite, off when the door is closed and on when the door is open. This could be part of the non cool problem. If this model has the mother board wich controls the refrigerator it is very possible that the defective fan motor has damaged the motherboard. This is very common in GE refrigerators. The technician will have to run some tests on the board to eliminate it...Catriver..post back.
Oct 28, 2006 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool GD2SHGX Refrigerator Logo
77 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
