Giga juke cant get the wireless part of my giga juke to work, steps 1.2.3. ok but cant get NAS-S55HDE on the home network screen, i just get update info and cant go further forward
Hi Koonjul. I have a similar problem with my Giga Juke occasionally, and the way I get around it is to power off (at the mains) both the server and the slave units. Switch back on the server and wait for it to connect to the network successfully. Then switch back on the slave unit and it usually reconnects to the server successfully. If this doesn't work, then switch them both off at the mains again and also power off the network router. Switch back on the router and wait for it to come back up completely. Then switch back on the server and slave units as above.
Posted on Feb 20, 2010
Windows vista is not detecting lacie network space 2 i am trying to install a lacie network space 2 (1T) on a home network. i use windows vista icw avg free virus software. i installed the latest...
In your office network, for sure, you have a DHCP server who gave the IP addresses to all devices for that network and this seems to be the reason for why you could see your NAS. On home, you also need a DHCP server. You don't say anything about you home network. The best idea is to just make a temporary network with 2 devices: your computer and your NAS by connecting the NAS directly to your computer's network adapter, set the IPV4 IP for that adapter to the same class addresses as your NAS was set by default (usually NAS had "192.168.x.y" where "x" could be 0, 1 or 2 "y" could be any value between 1 and 254, but mostly, 1) and try to access it via http to manage him (need a user name and a password). For NAS default address and username and password, consult NAS user manual. Access it with from your preferred browser using: \\192.168.x.y
Once you gain the control, cut off his DHCP service and tell him to accept the IP address from the network defined DHCP. (btw: one normal DHCP server is allowed on one network! Cascaded DHCP also is allowed, but it's a little bit complicated)
Jun 25, 2011 | LaCie Space 2 (301515EK) 1000 GB Network...
How do i connect my nintendo wii to my wireless home network
From the wii home menu...
Go to Wii Options in the lower left.
Click on Wii Settings to the right.
From this first list, click the right arrow.
Now on page 2, click on Internet.
Then click Connection Settings.
From this list, click Connection 1.
Then, click Wireless Connection...
and then click Search for an Access Point.
It will briefly search for any access points and when this screen comes up, click OK.
The following will be a list of nearby access points. If the one you are looking for doesn't show up, click Try again. Then, click the one you have access to...
When the following screen appears, click OK...
and OK again.
It will test the connection...
And if successful, the following will drop down. Click Yes to update Wii.
Sometimes the above screen is false, saying there is an update when there isn't and the following will appear...
Now, back in Wii System Settings, click on WiiConnect24.
From the following list click WiiConnect24.
Click On and then Confirm to save your settings. This feature allows for updates to be seemlessly sent to your Wii so you don't have to do the final step every time.
Ok, the final step, just as a way to make sure your Wii is up to date. Click the right arrow from the 2nd page of Wii System Settings.
Click Wii System Update...
click yes...
it will test your connection for a few seconds...
an update screen may quickly come up and tell you there is an update (whether or not your Wii actually needs one)
and the following screen will appear. Click Wii Menu to finish.
Feb 28, 2011 | Nintendo Wii Console
I want to connect to internet
Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button. Now, select "Wii Settings" to access the "Wii System Settings" menu. Using the arrow on the right side of the screen, scroll to page two and select "Internet." Select "Connection 1: None"(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.") Click on "Wireless Connection" and then "Search for an Access Point Select "OK" and the Wii will display all the wireless networks it finds. Select the wireless network that is yours Select "OK," "Save Settings," and then "Yes."
· The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen.Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates.
Dec 28, 2010 | Nintendo Wii Console
How do i set the Gateway, the IP and the Subnet Mask on my Officejet-7310? On Configuration Page, all wireless info (#15-22) is set to "not applicable" Under General Info #1 Network Status is...
on you printe.. press the setup button which islocated above you navigation keys on your printer, after the setup screen come up
step 1 - scroll down to option 8. Network and press ok
step 2 - scroll down to option 3. Advanced steup press ok
step 3 - scroll down to option 2. Ip settings press ok (there will be a warning message but just press OK again
step 4 - scroll down to option 2. Manual press ok
step 5 - Now u just choose which option you want to change, btw there are 3 options (1. Ip address, 2. Subnet mask, 3. Default gateway).
Hope this helps.
Dec 23, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Get stuck changing net settings, ie ssid...
if your home is set up with wireless modem or router and your computers are connected wirelessly its pretty simple to set up. more likely you or someone who set it up probably set it up securely meaning with security key and password. So you do have to know few things about your home network. like what is the name of your home network (SSID). the security setting of your home network. and finally the password of your network. if you don't know these things about your home network you will not be able to get connected wirelessly. but if you do have these info on hand read along....
JUST MAKE SURE YOU DO HAVE A WIRELESS HOME NETWORK... it definitely wont work if you don't have a wireless setup and u are trying to connect wirelessly. people overlook this no brainer.
1) go to Settings
2) Network Settings
3) Internet Connection Setting. confirm on "O.K."
4) easy *it may or may not give you a message reading "checking network configuration2_bing.gif"
5) wireless
from this point on you need to know few things about your network.....
6) scan -- once scanned it'll give you other wirelss access point for you home network and some other near your home along with few information such as SSID (which is what you set your network to be -- i.e. "the jones" or "linksys" or "summer home" or "my connection" etc etc) SECURITY (this is the password you set up your network with) SIGNAL STRENGHT (usually your network will be the strongest among your neighbors since you are closer to your router)
7) highlight your network and press x . (you should know what it is) selecting on the other network will probably not do you any good since it'll probably be all locked with password and such and so should yours be.
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network. if you don't know ask the person who set up your home network)
9) on WLAN SECURITY SETTING2_bing.gif page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password yours may be different so choose the one that you used.
10) WPA KEY - which basically means password. input the password you used to set up your home network (this is another thing you should know about your home network or ask the person who set it up)
**it'll give you "checking network configuration"
11) if you input all the correct info you should get the "setting list" screen
12) press "X" to save the setting
13) do the connection test and if all things were entered correctly you should have success.
all this seems complicated just reading but if you follow it step by step its easy. you just need to know the name of your home network, the home network security setting, and the password of your home network.
on the other hand if you are setting up a wired connection it makes it a whole lot simpler. you don't need to know your network name, security key, and password.
make sure you have the ethernet cable plugged in to your ps3 and to your modem or router
1) go to Settings
2) Network Settings
5) wired
6) auto-detect
7) automatic -- for the IP address setting
8) do not set
8) automatic -- DNS setting
9) automatic -- MTU
10) do not set -- PROXY SERVER
11) ENABLE -- UPNP
save connection setting
test connection
if your home network is set up and u got the ps3 connected it should work
May 19, 2010 | Sony Playstation 3 (PS3) Console
Cant connect wirelessly as i cant locate AOSS button
AOSS is what you would see on some high end routers. if your router doesn't support this method or have this button you can't set up your ps3 using it.
The PS3 does not have an AOSS button. AOSS (AirStation OneTouch Secure System) is used for wireless setup of devices for your network. Your router will have a button on it for this. If it does not then it more than likely does not have the ability to set devices up in this manner.
1)To use this set up for the PS3 go to Settings>Network Settings> Internet Connection Setting> (Method) Custom> (Select Connection Method) Wireless- (WLAN2_bing.gif Setting) Auto - AOSS. At this point the PS3 will tell you to push the button on the router and that you have two minutes or else the attempt to connect will stop.
Again this only works if your router has this button. and it is not found on your ps3
so you'll need to set it up differently. if your home is set up with wireless router and your computers are connected online wirelessly read along....
1) go to Settings
2) Network Settings
4) easy *it may or may not give you a message reading "checking network configuration"
5) wireless
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network)
9) on WLAN SECURITY SETTING page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password yours may be different so choose the one that you used.
May 18, 2010 | Sony Playstation 3 (PS3) Console
Can't connect to wireless from laptop
  1. Step 1 Plug one end of the Ethernet cable into the DSL modem.
  2. Step 2 Then plug the other end into the "WAN" port on the back of the D-Link wireless routermag-glass_10x10.gif.
  3. Step 3 Connect wired computers to any of the other Ethernet portsmag-glass_10x10.gif on the router using another Ethernet cable.
  4. Access the D-Link Configuration Screen
  5. Step 1 Open your web interface and type "http://192.168.0.1" into the address bar, then hit "Enter" or "Return."
  6. Step 2 Use "Admin" as the username and leave the password blank when the login screen appears.
  7. Step 3 Click "OK." You should now see the D-Link configuration screen.
  8. Set Up General Security
  9. Step 1 Change your administrative password by clicking on the "Tools" tab and choosing the "Admin" button. Enter a new password under the "Administrator" heading. Confirm it, and click "Apply."
  10. Step 2 Disable the wireless Local Area Network (LAN) if you don't need to use the wireless access and you want to make sure no one else is able to access your network.
  11. Step 3 Under the "Home" tab, choose "Wireless" and select the "Off" option.
  12. Enable Wireless Encryption Protocol (WEP)
  13. Step 1 Locate the "Home" tab in the D-Link Configuration screen, and click on the "Wireless" button.
  14. Step 2 Use the "Open System" button beside "Authentication."
  15. Step 3 Select the "Enabled" button next to "WEP," and set the encryption key to "128 bit."
  16. Step 4 Set the "Key Type" to "ASCII" and choose a 13-digit password for the "Key 1" field.
  17. Step 5 Write down the password in a secure location.
  18. Step 6 Click "Apply."
Sep 03, 2009 | D-Link DI 514 Wireless Router (DI-514)
Sony UWA-NA1 - no available driver for Windows? what specs does it have? It seems that with a Giga Juke Hifi-stereo, it will only communicate with WEP encryption, but the Wireless Giga Juke player station...
I found it! Sony UWA-NA1 USB Wireless Adaptor is a OEM products of Quanta Microsystems Inc, it's using the same USB adaptor as Ralink RT73 USB Wireless LAN card with RT2571WF chipset. I did it work ok in window 7 64-bit. But in the link below, its support XP, Vista as well.
1. Download Drivers for XP/Vista/Win7 here: http://www.station-drivers.com/page/ralink.htmChoose Ralink RT257x/RT2671/RT520x (RT73 series USB Wireless LAN)
2. After download it, run it to install the Ralink Wireless App, check for the driver only. When it done, find the folder it has installed. 3. Open device manager in window managerment, choose the Wireless USB (have no driver with yellow !), right-click, update driver software..
3.a Click "Let me pick from a list of device drivers on my computer". Find the "Network adaptor" in the category devices list, click on it, OK.
3.b In a new window name "Select Network Adapter", choose "Have Disk..." then browse the path of folder Ralink has installed. Your will see a file "netr7364.inf" (may be in XP-32bit or Win7 32bit you will a difference *.inf file). Click on it, click open, then OK.
3.c In the left box, find Ralink Technology Corp. click on it, the find RT73 USB Wireless LAN card, then click NEXT, a "Update Driver Warning" pop-up will appears, just click yes. Then windows will install the driver for Sony UWA-NA1 as "RT73 USB Wireless Card". Good luck! (You may try another devices in the list at your own at risk)P/s: Sorry for my bad english! English is not my primary language.
Jul 08, 2009 | Sony Computers & Internet
Belkin 8233 - no routing between hardwire and wireless...
Try to see if file sharing between computers connected to the Belkin is working. If it does not try to update the firmware of the belkin. If it does not work its switching function si defective.
Feb 07, 2009 | Belkin (F5D8231-4) Wireless Router...
Dlink Router not assigning IP to NAS
DI-624 (Update to FW 2.70+)
See: http://www.infrant.com/wiki/index.php/Hardware_Compatibility_List_-_Network_Switches/Routers#D-Link
Dec 28, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
154 people viewed this question
 Grubhead
Grubhead
