Question about Oreck XL Ultra Bagged Upright Vacuum
Vacum cleaner appears to be cloddedmit is noit picking dirt from floor
    Guru:
  • 1,894 Answers
"cloddedmit" means??
cont understand your problem sir. sorry..
Posted on Jul 26, 2008
  • dewan nafees ahmed Jul 26, 2008
    Check the handle tube for a collection of hair, paper, dirt.
    if it is fine look at the base.
    Sort of below/behind the roller brush, off to the one side, there is an opening/port.
    if it is clogged clear it and use the machine.
    thank you
    good luck.
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
I have a Samsung SU3364 vacum cleaner have never been able to use the crevice tools as there is no suction when you take pipe off, only when you use it as a floor vac, any suggestions have tried every
If the vacuum is old, the intake path from the hose to the dirt receptacle may be plugged from years of dust, dirt and grime. This happened to one of our vacuums, and I had to take off the bottom guard, the belt and the sweeper bar to access the intake, and it took me about an hour to get it unplugged.
If this is a new machine, the hose may not be properly connected when you are using the crevice device. Check the manual for proper installation.
Jul 22, 2014 | Samsung 5490M Lightweight Upright Vacuum...
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
The hand cleaner picks up dirt but the floor cleaner does not.
A couple ideas.
1. Have you emptied your dirt?
2. Are your filters clean?
3. Is your roller brush working and if not, is your belt broken?
Hope this helps and good luck!
Mar 17, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Vacuum cleaner not picking up and sometimes spits ouit dirt
Check to see if bag (or if not bag then chamber is full).
Check to see if filter is clean.
If your vacuum has a bag, check to see that it is properly mounted.
Sorry I couldn't be more specific but it would help if you would specify what type of vacuum you have, whether you are using the hose or just the floor part, and where it is spitting the dirt from.
Hope this helps. If not, let me know the answer to the above questions and we'll go from there. Good luck!
Mar 13, 2010 | Vacuums
I have the bissell powertrak revolution. I have hardwood floors...even on the lowest setting it is throwing some dirt back at me instead of picking it up....
do not worry about this....it is a common issue with every brand of vacume this style....the poblem is not of power or quality..but rather one of friction or lack of resistance because of the smooth floor surface....carpet surfaces permit the brush part of the roller to FLICK the dirt back up high enough ( only millimeters) to be sucked by the continuous suction flow of the vacume...however smooth finished hardwood or tile floors allow for the heavier none dust particules on your floors to be swept accross the floor with speed...if there was a back drop on the back end of your vacume cleaner these particules would be stoped and sucked up....try taping a strip of brstle board paper with scotch tape to the back part of ur vame head and see if it makes a differnce. Put the paper at dragging floor level and tape it..then sprinkle some dried toast on the bare floor and try it....let me know if it works...
Feb 20, 2010 | Bissell 6591 Power Trak Revolution Bagless...
The vaccum doesn't pick up dirt, it sprays out
There is probably a second or third filter (besides the canister) that needs to be cleaned.
I doubt that it's rotating the wrong direction.
Apr 25, 2009 | Dirt Devil M084600 Dynamite Bagless...
Floormate not picking up liquid at all
you may need new brushes and check sqweege in front.Also clean injecters for cleaner at bottom of unit.
Sep 04, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Oreck XL Ultra Bagged Upright Vacuum Logo
62 people viewed this question
Top Oreck Vacuums Experts
Roger Potts
Jim Parker
Jim Parker
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
