SOURCE: It alway diplay No SIM Card inserted even when there SIM Card in it.
Solution, try putting a paper behind the sim card before placing it in the cellphone. The paper adds thickness to the sim card and makes it touch the connectors in the cellphone.
SOURCE: unlocked code restriction code
hi! u call the vodafone customer service centre! and get therestriction code! and then you change the sim into 2630 and give the restriction number.
thank you..........
SOURCE: Nokia N70 Insert sim card problem.......
i can solve this
if you want to format your memory follow this:
menu>tools>memory>then press options>from the list select format mem.card.
SOURCE: Insert Uim Docomo mobiles japan
Insert sim? try to remove the sim card then wipe the gold part of the sim, try to place it back in.
SOURCE: my aircel sim is blocked and asking for puk code
PUKs, or personal unblocking keys, are used to unblock a mobile phone which becomes blocked. Mobile phones may become blocked when a PIN (personal identification number) is entered incorrectly on three consecutive occasions. In some instances, the phone may become blocked, which requires a PUK to unblock it, and in other instances, the SIM (Subscriber Identity Module) card itself becomes blocked and again will require a PUK to unblock it.
Mobile phones are also blocked when they are reported stolen and if there is an outstanding payment on the account.
It is important to differentiate between unblocking phones (using a PUK) and unlocking mobile phones (using another type of code). More information on unlocking phones will be available here in the very near future.
NOTE: It is a criminal offence for anyone to attempt to unblock a mobile phone, other than the network provider who put the block on the phone.
If your phone has become blocked by mistake, for example you have entered the PIN incorrectly on three consecutive occasions, then you need to contact the mobile phone network operator with your details. To explain a little more, specific to your mobile phone network, use the links above to navigate your way to the specific PUK details for your mobile phone network operator.
