Back to:
Tags:
Hobart 370 Watts A200 Stand Mixer
Gear problem
posted by gdt1 on Jul 26, 2008
My mixer does not run on speed 1, on speed to it works but skips when under load, any help appreciated, not sure if i can get parts in the UK, and we use the mixer everyday for bread making, looks like I will be building some arm muscles!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 24, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Cheers Bigg t for the reply, I got the mixer fixed by our local ish catering equipment supplier, they said it was a damaged fibre gear, repair cost £190 plus our transport costs to get the mixer to them.
It is now working well and making bread every morning.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on gear problem:
I don't want to Accept this solution
Solution #2
Not Rated (0)
bigg t
Rank:Guru Guru
Rating: 85%, 356 votes
Sounds like a sheared key,explain your problem a little more i work for hobart.
Thank You!
Can you Help with these Mixers problems?
Mixers
Where do i get replacement beaters for Black and decker...
Mixers
A friend had a soup strainer attachment for his Hobart...
We have a used Hobart A200 20 Qt mixer which will not...
Mixers
not starting, then when started cutting in & out
Need an authorized service agent in Chicago for my...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
