Question about Hoover Washing Machines
Water leak at rear of drum on Hoover Nextra HNF 3157 washing machine
The outer plastic casing around the drum was cracked by change left in a pocket. I fixed it with a secondhand casing
Posted on Jul 30, 2008
Washing machine wont spin
A lot of times the bearing wear... they are placed around the drum and maybe sticking.. If it squealed or made funny noises check those first. It would be like putting on a break and trying to drive a car.
Feb 20, 2018 | Hoover Nextra HNF 3157 Front Load Washer
Nextra is shaking itself to bits and extremely
sounds like the bearing has gone possibly taken out the drum support to shaking could also be one of the wieghts has worked loose.
Mar 15, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Hoover washing machine model HNF71683D not draining water
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Feb 28, 2010 | Hoover Nextra HNF 3157 Front Load Washer
I need to fix the handle of a hoover washing machine hnf3157.I have the kit but can work out what way round the spring goes. Please help. Thank you Silvia
the hook faces away from the center of the door.
The handle goes around that.
The spring goes around both, on the inside of the hook, facing the center of the door.
Jan 16, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Water does not heat up
90% your heater is faulty and 20%your th/stat.
Sep 24, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Washing machine not heating water
Washin machines "do not" have heating devices, make sure to check your water heater and turn it back on to get your water heated.
That will get you back in hot water business.
GOOD LUCK.
Aug 30, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Error message EC03 appears on cotton cycle after 5 minutes into wash
I found the basic instructions that came with the washing machine and found that you need a screwdriver to undo a screw to remove the filter cover. I then gradually released the filter cover to empty the water out of the machine in small quantities into a shallow tray. I was then able to remove the filter and clear it of 2 x 20p pieces and a load of gunk. I then removed the 'washable' floormat from the drum as the rubber backing from the mat was crumbling and probably not helping the filter. Filter cleaned and cover screwed back in, mat in the bin, and everything working fine since.
I did try ringing the customer support number and after pressing loads of keys to select appropriate options; confirming my address, postcode, name, date of birth, email address, mothers maiden name, what the kids had for breakfast etc, I was allowed to ask how to get the filter cover off. Apparently this is a technical query and would involve arranging an engineer to call. I declined this very kind service option and opted for a screw driver, common sense and a positive attitude. Worked for me! No blood shed, a tiny bit of sweat whilst trying to get through on phone, and only tears of joy when I fixed it all by myself.
Jun 01, 2009 | Hoover Nextra HNF 3157 Front Load Washer
My washing machine is not finishing a cycle and is not pumping out the water. It will start a cycle, but then it will stop half way through, and the "delay/start" button will flash red. Please help
i had same issue turned out pipe was blocked and washing machine gave up trying to get rid of water, so would stop, cleaned filter, uncloged drainig pipe and was good to go
May 12, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Programme problems hoover nextra megaload
I had this problem soon after I purchased mine. The engineer came out and readjusted the dial. Hope this helps.
Feb 26, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Washing Machines Logo
188 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
