Yulia, you will need an antenna to view anything. Find a pair of " rabbit ears " ( just 2 pieces of wire joined together by 300 ohm line.) You will also need something to connect the antenna to the antenna connectors in the back of the TV.
yes u can .when ur hvin a voice call n a text is received ,just unlock the cell and press accept call key and u will enter into the call log and will able 2 read the text
If the battery light flashes red, this is usually an indicator of a bad cell in the battery or the battery is not being charged. This could be a power supply problem, a battery problem or a power adapter problem on the motherboard (The piece mounted to the motherboard that the power cord plugs into). Laptops are becoming notorious for this last problem.
I believe the overal coolant capacity (this includes the heater, block, radiator and such is @ 12 quarts. If your draing down your radiator for repair you onle be able to drain out @ 7-8 quarts or so. To get all of the coolant you'd need to remove the drains found in the block (that would be more troble then its worth)
I hope this may have helped,
Tom
It may be the plastic pieces that are connected to the shifter, they have been known to break easily and render the shifter stuck in place. To check this part, you must remove the center console pieces and when you get to the shifter you will see two pink pieces of plastic, if one of these pieces are broken removing it will let the shifter move, but it will slide easily of course so be careful. The part is inexpensive from the dealer and easy to replace. If you need assistance removing the console without breaking or snapping your panels, get a service manual from Promanuals.net, here is link to your 2005 Chrysler 300. It will give you easy step by step instructions on removing and replacing.
