Thefirst thing to check is to make sure you have scripting enabled in InternetExplorer. Internet Explorer is integrated into Yahoo Messenger so things thatgo wrong with IE can affect Yahoo Messenger. Here is the yahoo help page aboutthat: http://help.yahoo.com/l/us/yahoo/messeng... 2)In the Start Menu click on Run. Type, without the quotes, "regsvr32jscript.dll" and then click OK. Next, repeat the process but this time type inthe Run box "regsvr32 vbscript.dll" and click OK. Please note, if you are usingWindows Vista temporarily disable the User Account Control (UAC). You caneasily turn it back on. On the Control Panel (Category View) choose UserAccounts and Family Safety, next choose User Accounts, and then click Turn UserAccount Control on or off. 3)If the above does not fix your problem and you are using Windows XP, you canupdate your Windows Script to version 5.7. In my experience helping others,this is the step that has helped the most people. Exit all browser windows andchat programs including Yahoo Messenger before installing. run registry cleanerreginout cleaner to easily fix it
Start off by doing one of the following: Select the range of cells that you want to make into a table within your worksheet then proceed to Step 2 OR Start immediately with Step 2.
Click on the "Insert" tab at the top of the document.
Find the "Tables" group, then click on "Table." The "Create Table" dialog box will appear.
Type in a range for your table if you did not select a range in Step 1. If you did already select a range then that range will automatically appear in the dialog box.
Check the "My Table Has Headers" box if the data set you selected already contains the headers you want to use. If you don't check this box, the table will display default header names, which you can then go in and change.
Hit the "OK" button at the bottom of the Create Table dialog box to create your table.
