Question about Fujitsu fi-5750C Flatbed Scanner
I can not scan with duplex option
When i try to scan with duplex option, the scaner software give me the following error (see the following image) : With simplex mode, everything is OK. I have tryed olso to replace the mirror equipment of the back side with another one (wich i have taked from another scaner), and this work fine (without problems). Please can you help me with that problem or can you tell me where to get the mirror equipment of the back side?
  • 3 Answers
You will more than likely have to get it from fujitsu. You can contact them at 866-375-3788. It is the ADF optical unit part # PA03338-D820 and list at $1715.00
Posted on Jan 20, 2009
Can i skip blank pages while scanning duplex with a 5080c using capture perfect 3.0?
There is option to skip Blank pages. You have to specify in terms of percentage, above which the scanner will save and discard images below the specified percentage.
S. Mohan, India
Feb 28, 2013 | Canon DR 5080C Path-Through Scanner
Scan error try scan from computer or see documentation Press ok!!!
There are two ways to make your printer scan.
You can tell it to scan by pressing the keys on the front of the printer
OR
You can tell it to scan by using the software that came with your printer that is installed in your computer.
Your error message is saying that you are trying to scan by pressing the button on your printer and you have not set up this option yet. It is saying to check your documentation for instructions on how to set up this option if you wish to use it or try scanning using the software in your computer instead.
Go ahead and press "ok", if you have not done so already to clear the print que.
Then what I need to know from you is which option above do you want to use to initiate a scan from your printer?
In order to scan using the keys on your printer, you need to have an application (software) installed on your computer that it can recognize and send the image to. The printer will send the image to just about any graphics or photo editing software and others like Microsoft Word, or the photosmart software that came on your driver disk.
Make sure you have one or more of the above software titles installed on your computer, then press the "scan" button on the printer. The first time you set it up, you will see a message that says something similar to "gathering applications list" please wait. That means that your printer is connecting to your computer and checking for software that it recognizes and will scan to. Once a program is located it will then ask you where you want to send the image to and give you a list of acceptable applications it found installed. You use the up and down arrow keys on the printers keyboard to scroll the list until you see the one you wish to use then press the "ok" or "enter" key. Then just follow the prompts on your printers display and it will scan and send the image to your computer screen.
Using the keys on the printer is tougher to learn then scanning through the software on your pc.
If you want to try scanning by using the software, follow these instructions below:
Install the software that came with your printer on the driver installation disk. If you don't have the software or disk you can download a copy of the program from HP's website (http://www.hp.com). Look for downloads and then enter your printer make and model and follow the instructions to download and install on your pc.
Once the software is installed, turn on your printer and insert the document or photo you want to scan. Then open the program on your pc and click on the "scan" option (choose scan document, or scan picture or scan mixed ect.).
The pc will send the scan command to your printer, it will warm up and then send a copy of the image to your computer screen and ask if it is acceptable. If it is, choose "accept" and it will save a copy of the image file on your computer and stop. Double click on the image to open it for editing ect. Once you are happy with the finished product, click on "file" and then choose "save as" and pick a place that you will remember for easy locating then name the image and close it.
If you have any questions or encounter problems with the instructions above, just come back to this question and send me your concers through the "comment" section and I will help you solve this.
Click on the "Scan" option
Nov 08, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
I can´t find the option to scan something. In the menu is no button to scan. Can you help me an tell me how I can scann?
1. you may use adobe photoshop to scan images..
2. on the menu, just click import then select the model of your scanner.
it will automatically open the scanning software if not, the default windows imaging software
Jun 13, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Will not duplex - fails duplex quick test
Hello.
Here are some suggestions from Lexmark as to why the printer will not duplex:
The ability to select duplex printing requires the following:
  • -The printer must recognize the physical duplex option.
  • -The duplex option must be recognized by the driver under Properties > Install Options.
  • -The selected Paper Type must not be:
    -Transparency
    -Labels
    , or
    -Cardstock/Extra Heavy Paper.
  • -Under Page Layout > More Page Layout Options, the following options must not be selected:
    -Booklet printing
    Poster printing
Printer recognition of duplex option Some printers and MFPs have the duplex option built into the physical printer while others require physical connection of the duplex option or tray.
To check for an installed duplex option:
Print a Menu Settings page and check for DUPLEX under Device Information > Installed Features. (The embedded web server path is Reports > Device Settings > Device Information > Installed Features.)
If DUPLEX does not appear as an installed option, consider the following possible reasons: -The duplex drawer or tray is not properly connected to the printer. Try reseating the printer onto the duplex option so that the duplex option's upper auto-connect connector is properly aligned with the printer's bottom auto-connect connector. NOTE: A "982 duplex error" may also result from this condition.
-Turn the printer off for about 15 seconds, and then turn the printer back on. If the printer was quickly turned off and on, a low-voltage power condition could prevent the peripheral from being acknowledged during the initial printer start-up.
-The auto-connect connector is damaged on the printer or duplex option.
Software driver recognition of duplex option - reinstall driver.
Hope these suggestions help.
Nov 27, 2009 | Lexmark E450dn Laser Printer
Scanner error code
This generally indicates a driver error.
Download and run the Scan Diagnostic utility
  1. Download the HP Scan Diagnostic utility .
  2. When prompted, select Open or Run to start the download and run the installer, and then follow the on-screen instructions.
  3. Try the scan again.
The Scan Diagnostic utility checks the physical connection between the device and the computer and address the issues with the following components of the scanning software:
  • PML (Printer Management Language)
  • Yellow DOT4 entries
  • Scan Folder
  • Registry Mismatch
  • HP Digital Imaging Monitor
  • Multiple HP Digital Imaging Monitors
If an error condition is identified with any of these items, a red X ( ) appears next to the item. If there is no error condition, a green check mark ( ) is displayed next to the item. The utility is equipped with a Fix button to correct the error conditions.
Run the Unexpected Internal Error and Communications Failure patch
  1. Download the patch for HP Image zone/photo, imaging unexpected internal error and communications failure.
  2. Double-click the patch to install it on the computer.
Try scanning without HP Imaging software
Try to scan with the built-in feature of Windows operating system called Windows Image Acquisition (WIA). To perform a WIA scan, follow these steps.
  1. Make sure the product is turned on.
  2. Click Start , and then click Control Panel .
  3. Click Printers and Other hardware , and then click Scanners and Cameras .
  4. Look for an icon for the product.
    • If there is not an icon for the product, click here to uninstall and reinstall the software .
    • If there is an icon for the product, click the icon, and then follow the on-screen instructions to scan images or documents to the computer.
Sep 21, 2009 | HP J3680 Officejet All In One Printer
Fujitsu fi5650 hispeed duplex scanner
Check the following items:
1 Does the document satisfy the paper specification?
2 Clean the Feed rollers and the Plastic rollers and see if the error is resolved.
3 Replace the Pick roller and the Brake roller and see if the error is resolved. Check the consumable counter in the software operation panel or in the built-in Maintenance mode. When the counter exceeds the values, replace the Pick roller or the Brake roller.
4 Are the cables between the Control PCA and the Feed motor damaged? Are the connectors connected properly?
5 Is the Optical unit ADF installed correctly?
6 Is the Belt ADF installed correctly?
7 Is the Belt ADF damaged?
8 Replace Feed motor and see if the error is resolved.
9 Replace the Optical unit ADF and see if the error is resolved.
10 Replace the ADF unit and see if the error is resolved.
Pls acknowledge of the issue is resolved.
Regards,
Tech Satya
Aug 06, 2009 | Fujitsu fi-5650C
Canon DR-2050C - Duplex scanning
Try and reinstall the driver software. IF you had scanned only one page and also had chosen multipage option, the second side will not be visible, unless you use a proper software that can display 2nd side.
S. Mohan
Aug 18, 2008 | Computers & Internet
I am trying to scan a pic and my scaner says no scan options
Step one: Verify that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete. If the Digital Imaging Monitor is in the system tray, proceed to Step two. If the Digital Imaging Monitor does not appear in the system tray, follow these steps. Windows 98, Me, and XP
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig .
  3. Click OK .
  4. In the System Configuration Utility window, click the Startup tab.
  5. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Proceed to step three to uninstall and reinstall the software.
  6. Select the HP Digital Imaging Monitor check box.
  7. Click Apply , and then click Close .
  8. Click Yes to restart.
Windows Vista
  1. Click Start .
  2. In the Start Search text box, type msconfig and press Enter .
  3. On the User Account Control window, click Continue . The System Configuration Utility window displays.
  4. Click the Startup tab.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
    If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab. NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, proceed to Step three to uninstall and reinstall the software.
Step three: Uninstall and reinstall the software
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  2. If the software installer does not automatically start, complete the following steps.
    2. In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
    3. Click OK .
  3. On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
  4. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  5. If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
  6. Follow the onscreen instructions until the printer software is completely installed.
  7. After successful installation, scan a document.
Jul 08, 2008 | Office Equipment & Supplies
How to Default Duplex Scanning
  1. Image Scan Can not be Found.
  2. please check and Cable connection
  3. and the scanner is not used by other application.(Code:DS42019)
THIS THREE ERROR WILL SHOW AT MY SCANNER.
AFTER PUT GHOST IT WIL SLOVE.OTHERWISE WIL NOT SLOVE.
COULD U PLS GIVE SOLUCATION
Jul 02, 2008 | Fujitsu fi-4120C Path-Through Scanner
No power
Hi Bret! Since this is a brand new printer, I would advise calling Lexmark. I'm afraid that you may void your warranty if you do much more at this point except for going back through the steps to make sure the duplexer was installed correctly.
1. Power off the printer and unplug the power cord from the wall outlet
2. Push the release button, and gently lower the front door.
3. Release the green tabs and lift up the image transfer belt.
4. Remove the cover over the duplex connector.
5, Remove the duplex option from the packaging. Carefully install the option into the printer, under the image transfer unit. NOTE: Make sure to line up the arrows on the duplex option with the arrows on the printer. Make sure the duplex option locks into position.
6. Lower the image transfer belt back into position. Make sure the belt locks into position.
7. Close the front cover.
8. Plug the printer back in, then power the printer on.
9. Try printing a few pages to confirm that the duplex option is securely installed. Then select the duplex option in the software and print a few double-sided pages to confirm that the duplex option is working.
The following link will take you to the instructions for enabling the duplex option in the software.
If the above does't work, I would strongly suggest contacting Lexmark for further help.
May 13, 2008 | Lexmark T630 Laser Printer
Fujitsu fi-5750C Flatbed Scanner Logo
227 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
