Question about Nokia Cell Phones
3310 3315 battery drained
Battery drained
Posted on Sep 13, 2008
Battery overheating and draining
i think ur phone problem some short circuit problem thats y battery quick draining
Dec 04, 2013 | Samsung Galaxy Cell Phones
Tip
If your Cordless battery drains
There are many instances of battery draining but most of the time it is due to poor quality of battery including those that are in shelves which have lost the charge capacity.So here are some tips
Unless the phone is showing any malfunction we cannot confirm unless a drain test is taken in the standby condition of the phone.This must be quite negligible current about few mAmps . If there drains is more check for leak in the battery source to the IC feed, a possible zener shorting or a capacitor leaking.
However if the phone is using up power on talk time , it can be due to drain in a functioning circuit which will be hard to find , but check for unusual heating in any components.
If there was leak in the board this must be ccleaned out well with petrol and may be insulated with varnish.
If however the phone works fine then it can be the fault of the battery itself as it could have developed reverse polarity.
Let the battery drain off fully and recharge, if possible a jump charging with an external voltage might sometimes cure this issue.
If not change the battery with the correct current rating.
on Sep 26, 2010 | Cell Phones
My iPhone battery drains quickly
Hi, many things can contribute to battery drain, what model and IOS do you have?
Oct 31, 2013 | Cell Phones
Battery drain
One solution that may work is freezing the battery for atleast 4hrs.
Most likely you will need to replace that battery. You can find easy replacement batteries on Amazon
Jun 02, 2013 | Cell Phones
Nokia slide phone which drains battery power very quickly. Have tried new battery to no avail. (Bluetooth is off)
The problem could be virus, scan your phone for virus and if you have done that and yet the battery still drain quickly, then, it means the battery terminal on your phone is corrode that is why it drains your battery quickly.
Change the terminals of your phone battery and you will see that your battery will last you longer.
Take care.
May 02, 2010 | Nokia 6500 Slide Cellular Phone
Battery drains very fast
First, before we proffer any solution, we need to know the problem.
Before the battery drains, does the phone gets hot in any way?
If your phone gets hot, then maybe the problem is from the phone board.
But if your phone does not gets hot before battery drains, then it is obvious that the fault is from your phone battery.
The solution therefore is for you to change your battery to an original one. The same problem might persist if you don't purchase a good battery, please take note.
I wish you the best.
Dec 08, 2009 | Nokia 5310 Cellular Phone
ATT Blackberry Curve 8310 - new battery drains after 10 hrs - why
is your phone on auto key lock. this helps my phone so that the battery doesnt drain so quickly, ten hours constantly on it is sufficient for a new phone these days
Aug 26, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Display like lightning and phone draining battery
you have the bluetooth connection on and it will drain your battery, go into settings an turn off the bluetooth page 25 of your manual
Jan 04, 2009 | Motorola Mobility RAZR V3
Battery drains quickly during normal even without using video and cameras.
if the bluetooth is on that could also be draining the battery quickly if all these things are off and the battery still drains quickly then replaced the battery
Dec 07, 2008 | Sony Ericsson K800i Cellular Phone
Batteries draining problem?
this problem can be caused by many factors. Use of the phone can drain battery life for example if you use the phone for browsing the web or as an mp3 player, even to make or recieve calls the battery life will not be as long as it would if just on standby. also if the battery hasn't been conditioned or is being over charged this can also lead to short battery life.To resolve the problem try conditioning th battery, basically let the charge drain completely out of the phone until the phone actually switches off, then charge the phone for 24 hours. Next time the battery goes ded only charge for the recommended charging time (this info can be found either in your phone user guide or by contacting the customer service department of your network provider).
Mar 30, 2008 | Samsung SGH-d807 Cellular Phone
Cell Phones Logo
23 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
