FixYa.com
Tags:
QuickShot Super Warrior  Joystick
Joystick Configuration?
By Odud - usenet poster
When I try to configure a QuickShot (QS-201) Joystick in the Control
Panel, Joystick Icon I get a message that the Joystick is not
connected.  But, it is connected and it does work on some of the older
DOS games.  Any suggestions?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 07, 2005
Helpful (85)
Bomber
Bomber - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Yep.  It's probably a driver incompatibility problem.  You'll need to remove
the Windows 98 joystick drivers and install the ones that came with your
sound card (or gameport adapter or whatever you're plugging your stick into)
driver diskettes or CD-ROM:
(1) Explore the disk/disc that came with your sound card (or system) and
find the drivers for the game controller on that disk/disc.  You may need to
check a README file or other documentation to find the drivers.  Be sure you
know what directory they're in before you proceed.
(2) Start up the Device Manager (right-click My Computer, then select
Properties, then the Device Manager tab) and expand the branch labeled
"Sound, Video and Game Controllers" and look for your joystick entry there.
Highlight the Game Controller entry and check on the Driver tab with "Driver
File Details" to see what drivers are listed there.  One of them you will
want to keep (MMDEVLDR.VXD) but make a note of any other files listed there
(like JOYSTICK.VXD and such).
(3) After you've made a list of the driver files, go back to Device Manager
and remove the current game controller entry by highlighting it and clicking
the Remove button.
(4) Exit to DOS mode and go into the \WINDOWS\SYSTEM directory.  Move the
files that you listed above (but not the MMDEVLDR.VXD file!) into a
temporary directory somewhere else.  You will want to save these files for a
little while just in case.  :-)
(5) Restart your computer.  It will detect the game controller and try to
install drivers for it.  Instead of using the Windows 98 CD-ROM, instead
insert the floppy disk or CD-ROM disc that has the drivers on it and click
the "Have Disk" button.  You'll need to tell Windows where the drivers are
on the disc/disk from step #1 above.
(6) Now try your controller out.  It should work just fine now and there
should be no more "Not Connected" errors.
This problem seems to happen when Win98 installs its own set of joystick
drivers that are almost but not quite compatible with the joystick
controller on your soundcard, motherboard or gameport.  If you remove and
reinstall the joystick in the Game Controllers panel it will work until you
reboot - then it shows as Not Connected again.  Removing the Win98 drivers
and installing the ones that came with the controller/soundcard/whatever
will solve this problem.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these PC Gaming Devices problems?
PC Gaming Devices
Up-dateing Adobe Acrobat...
Checking my Plugins, needn to... Answer This...
PC Gaming Devices
I have Sims Life Stories and It...
Everything else on it works but... Answer This...
PC Gaming Devices
Dexxa Flatbed Scanner
I Need the driver for this... Answer This...
PC Gaming Devices
tetris DS
in line clear what does... Answer This...
PC Gaming Devices
v3 playstation steering wheel
I'M HAVEING TROUBLE WITH THIS... Answer This...
Repair Service
Find PC Gaming Device Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
