Question about Hobart A200 Stand Mixer
Hobart A200 My mixer does not run on speed 1, on speed to it works but skips when under load, any help appreciated, not sure if i can get parts in the UK, and we use the mixer everyday for bread making, looks like I will be building some arm muscles!
Hi I work on these all the time, sounds like a tooth from the one of the gears has sheerd off so making the gear rings rotate when they should sit solid in its casing..... you need to open her up or get a tech to look at it £150 is an approx fix
fritz
Posted on Aug 21, 2008
Hobart speed issue
http://hobart.co.kr/manual_pdf//013.pdf this is a manual of parts, speed is controled by gears. if you are not sure of what you are doing call for service from hobart or an authorized tech. it is a messy job to boot.
Jan 03, 2012 | Hobart A200 Stand Mixer
Hobart A200
hi there,
did you make it sure that all part has been back into place and no small parts has been put away into its place.?
check for any loose screw,
Oct 24, 2008 | Hobart A200 Stand Mixer
How to change oil in 20 quart hobart mixer and the type of oil
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Dec 20, 2009 | Hobart H600 Stand Mixer
Speed reduction of Hobart A200 mixer
Hi Don. If your mixer is hurling honey, you must be very popular in the ant world...Sorry!
The Hobart electric motor on your mixer was designed and engineered to operate on 115-120 volt current and is the most dependable, and capable commercial mixer out there Is it possible for you to use a commercial Imerssion Blender for the first part of your mixing operation. Once your honey thickens a bit perhaps the a200 wouldn't hurl honey. Another consideration would be to either try a different beater or modify the one you have by removing surface area from the beater. If you remove metal, be sure to do it in a balanced fashion to avoid unwanted vibration in the beater. If you're not up to removing metal, take it to a machine shop and they'll do it for you. It probably won't take long, or cost much, and they have the expertise and the equipment to do it properly. If you found this solution helpful, please rate it. Good luck! ricardok45.
Feb 02, 2009 | Hobart A200 Stand Mixer
Hobart A200 Mixer not working
Sundance,
Please visit the corp website www.hobartcorp.com and click on the "Sign In" link in the upper right hand corner. You'll need to complete a brief registration form, but then you'll land in the Hobart Resource Center.
Hobart no longer manufactures the A200 mixer - but you can review and download a user manual and a parts catalog from the Resource Center on your mixer. That should help you understand the parts need.
We do sell replacement parts direct to end users, just visit our service website at www.hobartservice.com - and click on the "Locate on Office" link. You'll be able to contact your local Service branch to purchase a replacement part OR to have them take a look at the unit and provide a quote on fixing it.
If you have additional questions on Hobart products - please contact me at sherri.wilmoth@hobartcorp.com .
Thanks!
SHerri
Oct 11, 2008 | Hobart A200 Stand Mixer
Gear problem
Sounds like a sheared key,explain your problem a little more i work for hobart.
Jul 26, 2008 | Hobart A200 Stand Mixer
Motor replacement for A200
If the motor runs and when under a load the planetary stops its not the motor.You either have a sheared key or broken gear in the transmission.
Mar 22, 2008 | Hobart A200 Stand Mixer
A200 problem
Check the planetary.this is the bottom part of the mixer where you attach the hook.
You will see two nuts; make sure their tight as the planetary may have moved down.
Also have a look below:
http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
Feb 04, 2008 | Hobart A200 Stand Mixer
Same speed
I believe the speed control needs to be replaced. It controls how much electricity is sent to the motor.
Jan 28, 2008 | Hobart A200 Stand Mixer
Hobart a200
will it move in any speed,i need to know this in order to troubleshoot your problem.im a hobart service tech and i service these mixers alot.
Nov 13, 2007 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
296 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
