Question about Nikon COOLPIX L18 Digital Camera
Jamed shutter, broken lcd screen - Nikon COOLPIX L18 Digital Camera
  • perry2222 May 10, 2009
    the shutter has trouble closing, and keeps buzzing
I am having the same problem
Posted on Aug 16, 2008
When taking picture outside lcd screen very bright no picture
Probably the shutter flexible cable is broken and has to be replaced,the cable is burried in the lensblock,or replace the whole lensblock,labor extensive ,technical skill required
See remarks on other similar faults.
Jean
Jan 20, 2011 | Canon PowerShot A430 Digital Camera
The viewfinder and LCD screen are blank. I have turned it off/on and looked in the FAQ's with the manual- no luck. Is it a setting I've messed with or is it broken? Help!
A stuck shutter is another common failure mode for digital cameras, especially for the S2 IS. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 07, 2010 | Canon PowerShot S2 IS Digital Camera
Image looks fine on LCD screen before snapping pictures and then has streaks or over exposed on the final picture
your problem is lens shutter maybe broken or stuck up. If you notice once you take picture and check to the display it was fine but try to zoom to the maximum you will found out that there's a line in you image.the only way to solve your problem is bring to service center and ask for cleaning the lens shutter.
Jun 03, 2010 | Kodak EASYSHARE Z1285 Digital Camera
When i take the picture there are no lines but then when i see them in the lcd screen there are lines and when i upload them into my computer the pictures still have lines
The shutter inside lens doesn't work, it could be a broken shutter cable which happens to break on this model (also V803). It is a well known problem and the only solution is to replace the shutter unit or whole lens unit. You will have to contact Kodak. It might be cheaper to buy a new one (at least in the USA).
I work for Kodak.
Tom
Mar 07, 2010 | Kodak EasyShare V1003 Digital Camera
My lcd screen will not show the picture. The
First try pressing the DISP or DISPLAY button to make sure that you didn't accidentally turn off the LCD. But if that's not the case...
Try taking and downloading a picture taken while the screen is blank. Is the picture also blank? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Read the users comments there also for more tips.
Jan 31, 2010 | Canon PowerShot SD1000 Digital Camera
Problem with canon a420 digicam
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
LCD screen is black-cannot take photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 16, 2009 | Kodak EasyShare CX7330 Digital Camera
Broken LCD TV Screen
Hi james daum,
Unfortunatly usually the price for the LCD panel cost more than buying a new tv. I would not throw it out though. You have a couple of options.
  1. Buy a non-working same model tv with a good screen and swap the internals over. You can sometimes find them on Ebay.
  2. Sell it as non-working on Ebay or like auction site.
  3. Try to find a used screen at a decent price. You may try ShopJimmy.com
Let me know if I can assist further and please rate this solution. Lone99star
Jan 23, 2009 | Televison & Video
LCD Dispaly malfunction
The screen has two components. The LCD, and the backlight. You can buy broken cameras relatively cheaply on ebay (or if you have it, craigslist). Do that, and you might be able to replace the screen.
Dec 03, 2007 | Canon PowerShot S30 Digital Camera
Casio Exilim EX-S500 screen is black when turned on
you camera shutter is stuck at close position, you will need to open
the thing up to repair.
As for the totally dark screen, either your LCD or driver board is bad. You will need to open and replace the broken part.
Nov 15, 2007 | Casio Exilim EX-S500 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
184 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
