Question about Olympus FE-210 Digital Camera
Shows empty battery even with new batteries - Olympus FE-210 Digital Camera
  • weavnon Jul 27, 2008
    Thank you freshly recharged batteries done the trick Regards Weavnon
Problem fixed witth freshly charged batteries
Thanks
Weavnon
Posted on Jul 27, 2008
    Champion:
  • 216 Answers
If they're AA, don't use "HEAVY DUTY". They don't have enough power. Use alkaline or rechargeable, and recharge at least 15 hours even if your charger show they're fully charged after a couple hours. Please leave feedback if this helps.
Posted on Jul 26, 2008
3 Suggested Answers
peteandrosan
  • 14 Answers
SOURCE: battery empty message
Put brand new batteries in. The battery empty message means there is no "juice" or power left in the batteries. If they are recharagable batteries, "re-juice" them (charge them).
Posted on Dec 27, 2008
HarryHarley
  • 343 Answers
SOURCE: my olympus sp-310 camera shows empty battery but I
Are you sure you put them in with the correct polarity facing the right way. Its a common mistake.
Also try a "known" set of batteries just to make sure.
Good luck
Posted on Jan 21, 2010
Nikon D80 showing empty battery
Are you using the same charger for all of the batteries? If so, you might want to try another charger. I had a charger for my batteries (I have a D7000) that turned out to be bad. It would show it charging and then having charged them, but they were still dead.
If that's not the case, check the contacts inside the camera, that they are clean and free of debris. Those little gold contacts needs to match up nice and solidly.
If it's still a no-go, call 1-800-NIKON US (1-800-645-6687) 9AM-8PM EST, Monday through Friday.
Mar 16, 2014 | Nikon D Cameras
Even after putting a new fully charged battery camera shows battery empty
The reason you are still getting this error despite the fact that you've placed a new fully charged battery means that the battery is not compatible with the camera. The fact that it states this is because the battery isn't capable of handling the Olympus camera. I would suggest for you to buy a recommended battery pack by Olympus, or a rechargeable battery pack to avoid these errors.
Jun 30, 2011 | Olympus Cameras
Camera consistently says "battery empty"....will not hold for more than a few minutes...yes I have tried new batteries!
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
The above is service and repair information for your camera.
Even, the manual says that you can use alkaline, NiMH, or Oxyride batteries. which are generally 1.25V for each AA, try the Lithium batteries which are 1.5V. They might work in your camera if your camera has some characteristic where the voltage falls below a certain limit and the 'battery empty' message shows up.
They are more expensive, but might solve your problem, even though the manual says that Lithium batteries are not to be used (in a new properly functioning camera)
Jul 22, 2010 | Olympus FE-310 Digital Camera
Battery indicator reads empty when batteries are fully charged
It looks like your question was cut short... all I see is "Battery indicator reads empty when batteries are..."
With my experience with the Pentax *ist DL, I think the problem is probably that brand new batteries still show "empty" on the indicator.
Chances are that you are not using the CR-V3 camera batteries in your *ist DL. I have tried 2400mAh NiMH rechargable batteries and brand new alkaline batteries in an attempt to save money.
Neither lasted anywhere near as long as the CR-V3 batteries! While you may be paying $15-$20 for two CR-V3 batteries, they last a LONG time!
One of the advantages of DSLRs (and digital cameras in general) is that you save money by no longer buying film and paying for developing/prints. But, even at $20 for two CR-V3 batteries, I save money! I am able to take several hundred photos on a pair of batteries (I think the manual says 500+) instead of $10-$15 ($2-$7 for film + $8 dev/print) for every 24-36 photos!
May 29, 2010 | Pentax *ist DL Digital Camera
Battery shows empty with new batteries. Recent development. Put batteries in, take a couple shots, battery is empty. Tried with several pairs of batteries. Contacts OK and tight. Suspect a software...
Take a look in your camera's menus. There should be a place where you can select rechargeable or non-rechargeable batteries. That setting enables or disables the battery charging circuit. If you are using rechargeable batteries, the camera must be set accordingly so that the battery charger will turn on. If you are using
Alkaline batteries such as Duracell or other types of non-rechargeable batteries the charger must be disabled. If you do not set that parameter correctly, you will get the symptoms you describe.
Oct 04, 2009 | Pentax Optio M20 Digital Camera
"battery empty" on screen after I disconnected camera from compu
Hi, have olympus fe-280 camera. Battery on screen shows full but shows empty (an inch strip) in middle. I have charged it. Even bought a new battery. Can anyone help. Thank you. ...... I want thinking I may have two faulty batteries and just need to buy another one?!
Jan 25, 2009 | Olympus FE-280 Digital Camera
Hi, I have a Nikon D300. First problem - The battery started showing empty / full / then empty again. Bought a new battery, worked first time, then the same problem empty / full / empty. Change the...
A capaciter in your camera is not working properly and is discharging your battery even when the camera is turned off (this is a cheap problem to fix but must be sent back to NIkon for repair
Dec 06, 2008 | Cameras
Battery empty message
Nov 24, 2008 | Olympus FE-230 Digital Camera
Battery problems
Check the battery contacts inside the camera. Use a strong light, and if you see corrosion (black or greenish areas) on the contacts, rub them lightly with a pencil eraser until they are shiny.
Apr 05, 2007 | Canon EOS-1V with 28-105 and 100-300 lens...
Olympus FE-210 Digital Camera Logo
289 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
