Question about Compaq Keyboard
Sticky key Sir, Please help me to fix the problem of sticky key numeric 5. It appears on its on without pressing the key. If I press the back key very hard it clears for a while. agai it start appearing. Please help. Thanks
  • Anonymous Oct 16, 2008
    I have the same problem with the letter m before. Now comma has the problem and the mouse's right click. up and left arrow keys and ctrl and alt do not function.. It's a burden. Help me.
I have the same problem with letter m before and now comma has the problem!
Posted on Oct 16, 2008
Just hooked up a kdc-4019...its asking for a code and i dont have a remote...can anyone help me ?
I was looking around and found these instruction that resets code but you need a remote to do this, i dont think there is anyway around without a remote.
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that "..." disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
IN YOUR RADIO: DISPLAY WILL ASK FOR CODE AND CODE ---- APPEARS ON, SO, HOLD .DISP AND PRESS VOL UP AT LEAST 3 SECONDS. THE "----" WILL DISSAPREAR. NOW TAKE YOUR REMOTE AND DIGIT "KCAR" WITH THE NUMBER PAD.
PRESS "5", "5", >>' (NEXT TRACK) YOU GOT A "K"
PRESS "2", "2","2" >>' (NEXT TRACK) YOU GOT A "C"
PRESS "2", >>' (NEXT TRACK) YOU GOT A "A"
PRESS "7", "7", YOU GOT A "R"
PRESS >>' (NEXT TRACK)
IF DISPLAY SHOWS "APPROVED" YOU'RE DONE ;)
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key "5" ( 2 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 3 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 1 time ) and press the Track UP/Next Track key
* Press numeric key "7" ( 2 times ) and press the Track UP/Next Track key
push buttom "track up" for 3 seconds
The security is canceled and the set enters the TUNER mode!
Feb 06, 2011 | Kenwood KDC-4019 CD Player
Secret keypad letters in computer
hi
Click on a text box or open a text document.
  • 2 Press the "Num Lock" key to activate your keyboard's numeric keypad.
  • 3 Press and hold the "Alt" key.
  • 4 Enter the numeric code on the number pad. Press "1" to create a "smiley face." Display a musical note by pressing "14". To make a heart symbol, press "3".
  • 5 Release the "Alt" key after entering each numeric code. The symbol will appear.
  • Jan 15, 2011 | Computers & Internet
    I hit the shift key too long on my keyboard at work and it asked it I wanted to filter the keys Or whatever and I clicked ok. Now my keyboard is not working. What do I do?
    Do you mean your keyboard is now not responding as it should do, or completely not working ?
    If you press the SHIFT key 5 times in succession, a box appears asking if you want to change the 'sticky keys' function in Windows.
    This means that instead of holding down the keys for SHIFT. CTRL, or ALT, you can just press them once and they will lock on (like an old style manual typewriter used to behave).
    It's most likely you now have sticky-keys turned on, so your keyboards going silly.
    Press the SHIFT key again 5 times, and that initial box will appear again. Make sure you click on CANCEL using the mouse only. That should fix it.
    Apr 09, 2010 | Computers & Internet
    Can't type anything without weird things happening the \'p\' prints,
    hi, check that Sticky-keys arent turned on.
    to toggle Sticky-keys on and off, press the shift key 5 times fast, then either Disable the sticky-keys tickbox, or click Settings for more configuration settings.
    when sticky-keys are enabled, you can press shift and release, and the shift key is still enabled. this also goes for Alt, and CTRL.
    so if it is enabled, pressing P will attempt to be Ctrl-P - which is print.
    Sep 10, 2009 | Acer NSK8458AN Keyboard
    Errors list : 46, 50, A1
    CP315C/310CN/120C/115C/117C/110C
    (1) Press the (1) Press the
    Menu and Mono Start keys. Menu and Mono Start keys. Next press the key four times to make the machine Next press the key four times to make the machine
    enter the maintenance mode. enter the maintenance mode.
    (2) Enter 8 and 0 by using the and (2) Enter 8 and 0 by using the and
    Set keys.* Set keys .*
    (*To enter a numerical code on models having no numerical keypad, press the key several times to (* To enter a numerical code on models having no numerical keypad, press the key several times to
    display the numerical code to be entered and then press the display the numerical code to be entered and then press the
    Set key. Set key. Repeat this operation for each Repeat this operation for each
    numerical code.) numerical code.)
    (3) Press the (3) Press the
    Mono Start key several times until the purge count appears on the LCD. Mono Start key several times until the purge count appears on the LCD.
    (4) Enter 2, 7, 8, and 3 by using the and (4) Enter 2, 7, 8, and 3 by using the and
    Set keys to reset the purge count to zero.* Set keys to reset the purge count to zero .*
    (5) Press the (5) Press the
    Stop/Exit key to return to the initial stage of the maintenance mode. Stop / Exit key to return to the initial stage of the maintenance mode.
    (6) Enter 9 twice by using the and (6) Enter 9 twice by using the and
    Set keys to exit from the maintenance mode.* Set keys to exit from the maintenance mode .*
    Mar 01, 2008 | Brother DCP 115C All-In-One InkJet Printer
    Vaio keyboard weirdness
    sir refer to you manual.. if i'm not mistaken the most laptops have integrated the numeric keypads with the alpha keypads... depending on what your laptop is there is a button that you will press toggle with the two functions... its just like the caps lock key that you will press to get all caps...
    rate me if this helps...
    Jan 20, 2008 | Sony VAIO PCG-K25 Notebook
    Please Help!!!!!!!
    Type 1
    During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
    Type 2
    Type 3
    * Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
    * Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
    * Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
    * Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
    Dec 14, 2007 | Car Audio & Video
    Cannot unlock
    Type 1
    Type 2
    Type 3
    Nov 23, 2007 | Kenwood KDC-C469FM 6-Disc CD Changer
    Compaq Keyboard Logo
    152 people viewed this question
    Top Compaq Computers & Internet Experts
    Alun Cox
    Abhinandan  Patil
    Abhinandan Patil
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
