Question about HP OfficeJet d145 InkJet Printer
HP Officejet d145 print head problem
Message said replace magenta printhead. This I have done and still get the same message. I think it is unlikely new hp printhead is faulty. Could there be another problem?
  • 2 more comments
  • elliebaby54 Sep 08, 2008
    The print heads are new, but the machine says replace black printhead all the time. It is a little bit expensive to do this when they are only four month old and been used about twelve times.
    Have done most things everyone suggests except buy new heads
  • LifeDZIgns Oct 28, 2008
    Just today replaced the 3 color printheads. The same "bad printhead" message came up. I am sure I replaced the printheads as I have been replaces the ink cartridges for around 6 years now. I have faxes that come in on regular basis and have had that set on black only for a while. So I thought, the lack of use for color would have made the printhead replacement logical. Now I'm a bit annoyed that I wasted the money for the new printheads. By the way, the black does not print well either, often too faint to read.
  • jenniferreye Dec 02, 2008
    all my colors print except magenta, and i do have a new ink cartridge and a new magenta printer head, still can't get magenta to print? any ideas?
  • drplatt Dec 04, 2008
    I have the same problem. Printer is asking for new black printer head. replaced the black ink cartridge and the black printer head and I am still having the same problem. It just will not print with any black ink and the printer keeps asking for new ones and they are new. Please Help!
Did you replace the PRINTHEAD, or did you replace the INK CARTRIDGE? They are not the same on the D145.
Good chance that you may have replaced the ink cartridge, not the magenta PRINTHEAD which sits under the ink cartridge.
PS - in my experience, non-HP ink cartridges clog up HP printers with separate printhead mechanisms... any possibility here?
Posted on Aug 12, 2008
I replaced all my printheads. Also Both the black
call the manufacture or tech support. Maybe there is a printhead reset on the printer??
Sep 26, 2009 | HP OfficeJet d145 InkJet Printer
My HP Officejet Pro L7780 All-In-One InkJet Printer was jammed with paper. I believe I got it all out and now the display reads" Printhead problem- the following printhead has a problem: magenta/cyan...
There are two possibilities here Joanne, first, it could be a false error message or else second, the Cyan/Magenta print head has gone bad.Try the following:
1. Take the Cyan/Magenta printhead out. Remember, the printhead...not the cartridges.
Clean the copper contacts with a Q Tip, moistened with plain water. Wait till it dries, put the printhead back in.
2. If this does not resolve the issue, unplug the power cord from the back and press and hold the power cord for 30 sec. This will drain all the static charges. Plug it back after a couple of minutes and see if the error message re appears.
Jul 02, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Message "A printhead has a problem:magenta/cyan" is driving me nu
Hi Gran, I think these cartridges have print head built into them just change the cartridges that are reported magnta and cyan and i think it should rectify itself Often the simple solution is the one thst works and msany people look at all the hightech answers without considering the message that is given.
You can check the situatioin by removing the cartridge aqnd checking if there is what lkookjs like a circuit board with holes at the base of the cartridge This will be the print head. try wiping with alcohol first and then replace or put in a new one (only 1 first) and seeing iof its just the nesxt color being the problem
See ya
Lil red hooding ride...
Jun 23, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet pro l7580 magenta won't print, new HP cartridge 8/11
You will have to reset the printer.If you want any further support, a technician from techbuddies can help you for free.For this log on to www.techbuddies.org
Jun 18, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Printing with my second hand hp officejet d145
You can clean it with maybe a little alcohol then go thru the motions of cleaning from the printer controls
Feb 26, 2009 | HP OfficeJet D145xi All-In-One InkJet...
HP D145 need new print head (magenta)
You can purchase a magenta printhead from HP's site here. Before you do that make sure it is the printhead - this model uses separate ink and printheads. Are you receiving an error message that the printhead is defective?
regards,
Bob Headrick, MS MVP Printing/Imaging
Nov 05, 2008 | HP Office Equipment & Supplies
The following printhead(s) has a problem Black/Yellow[K/Y].
Simple solution is:
Replace the Black and Yellow Print Catridges. The print heads are mounted to the bottom of the catridges and these, depending on whther they're from HP or not. can have a hard time conducting electricity properly, and in turn.. spitting ink out properly.
Also happens often with aftermarket Catridges because HP puts chips on the catridge. be sure to put an HP catridge. Sometimes you get what you pay for :)
Oct 31, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP officejet D145
Does it happen when you try to print from an application - like Microsoft Word or even Notepad? How about printing a test page from the properties page of the printer?
Sounds like either the printheads are clogged or there is no ink at all. Try running a few cleaning cycles. If you're sure you have ink, then try cleaning or replacing the printheads.
Dec 31, 2007 | HP OfficeJet d145 InkJet Printer
Print Heads
Make sure the printheads are not expired. Check the dates. Order new from HP direct
May 09, 2007 | HP OfficeJet D135 All-In-One InkJet...
HP OfficeJet d145 InkJet Printer Logo
294 people viewed this question
Ben Johnson
