Question about Dyson Flowcheck CRO1 Front Load Washer
Dyson CRO1 F11 Fault
I have an F11 fault. How do i fix it?
  • Rab J Jul 26, 2008
    I have turned the machine off at the wall. Will i need to leave it off for a set time or can I just switch it back on? I have been told that it may be a fuse on the switch board, could this be the case?
    Guru:
  • 1,894 Answers
Normally error like this disappear when a hard reset is performed? did you leave the unit turned off by plugging out from wall power for one night ??
until what cycle does this unit proceed?
Posted on Jul 26, 2008
  • 1 more comment
  • dewan nafees ahmed Jul 26, 2008
    even after leaving the unit plugged off from wall power for one night. and if the error exists then please read on..
    The F11 fault is a fuse blown on the circuit board.
    Apparently this
    fuse failing can blow the board so you may have to change the board if needed. The board is
    located at the back of the machine so you need to take the back off,
    unplug the board, change the fuse which you can buy at Maplins and put
    the board back.
    If it works fine, if not then you need a new board. Hope this helps you.
    thank you
    good luck
    Dyson will charge £85 for sending an engineer normally.
    so if you are experienced enough perform the job yourself at your own risk. else get it done by some experienced person.
    thank you
    in some cases this solution works. and hence i would request you to try this also before going to do a hardware repair.
    First make sure machine is turned off.
    Second press & hold temperature button .
    Thirdly press the on button & hold at the same time as the temperature button.
    Fourthly release the 2 buttons at the same time .
    Fifthly press the soil button .
    Sixly turn machine off then back on & F11 message saying fault F11 must disappear.
    if not try this process once again. if the error is not cleared then you will have to do as i have said you earlier.
2 Suggested Answers
jonniewalker
  • 1029 Answers
SOURCE: dyson cro1 fault f11 came up after interupted power suply
normally error like this disappear when a hard reset is performed? did you leave the unit turned off by plugging out from wall power for one night ??
Apparently this fuse failing can blow the board so you may have to change the board if needed. The board is located at the back of the machine so you need to take the back off, unplug the board, change the fuse which you can buy at Maplins and put the board back.
Posted on Jan 18, 2009
I HAVE FAULT F11 HOW DO I FIX IT
Dyson Memory CRO1 Front... Fault f11 Solutions - Fixya
www.fixya.com > ... > Dyson > Dyson Memory CRO1 Front Load Washer
Dyson Memory CRO1 Front Load Washer, fault f11 related issues. Get free help, solutions & advice from top Dyson experts.
Aug 08, 2015 | Dyson Flowcheck CRO1 Front Load Washer
F11 message
May be the fuse located on the PCB board ( bottom right hand side when looking from rear of washer ) - check and replace ( 10A 250V miniature fuse )- Can get from Maplins.
May 22, 2010 | Dyson Flowcheck CRO1 Front Load Washer
This morning got F11 fault on Dyson CR01 front loading machine, before that drum wouldnt turn and making grinding noises. Dyson have already removed the contra rotating cycle on this machine, is this...
may be the rear bearing has gone,my con/rota packed in and i took the drum out cleaned ,replaced, greesed, and alls well , if it is the rear bearing DON"T let them tell you its scrap if you are good at diy you can take the bearing out and fit new one, bit of a time comsumeing job
Mar 08, 2010 | Dyson Memory CRO1 Front Load Washer
Dyson washing machine fault code f11
Hi its Darran at Dyson.
So that we can assist you, please contact our Helpline on 0800 298 0298 so that one of our advisors can run through some checks with you as you may need an engineer.
Kind regards
Darran
Dyson Customer Service
Jan 23, 2010 | Dyson Memory CRO1 Front Load Washer
How do i repair a f11 code on my dyson cro1 contrarotor
Get Dyson out, the powerboard has failed, don't be fooled into thinking replacing the fuse on the board will do the job, it doesn't, a component has failed on the PCB which has caused the fuse to blow in the first place, £95 call out i'm afraid.
Dec 30, 2009 | Dyson Flowcheck CRO1 Front Load Washer
F11 fault code
Please find the steps that needs to be taken for trouble shooting F11 fault code specially if there was a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
I am sure it would help you to resolve the issue.
God Bless.
Jul 09, 2009 | Dyson Flowcheck CRO1 Front Load Washer
How to repair a F 11 fault on a DYSON CR01 flow check
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
May 29, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Dyson cro1 fault f11 came up after interupted power suply
Jan 18, 2009 | Dyson Flowcheck CRO1 Front Load Washer
DYSON washine machine fault
To Clear F11 Code after a power cut.
3, Power on
Sep 05, 2008 | Dyson Flowcheck CRO1 Front Load Washer
Dyson Flowcheck CRO1 Front Load Washer Logo
583 people viewed this question
Top Dyson Washing Machines Experts
Gerry Harvey
Gerry Harvey
paul
paul
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
