Question about Kenwood 107VR
Kenwood 107vr . no sound
I have a kenwood 107vr receiver. I disconect it when I moved.Try to hook it back up and no sound coming from the speakers.I have poer to the receiver.try the radio and no sound at all.
  • erick39 Jul 26, 2008
    THANKS
5 Suggested Answers
  • 18 Answers
SOURCE: no sound from speakers
check to make sure you have your speakers turned "ON" many amps have "A" and "B" speakers or 1 and 2 and then check the back to make sure no wires are touching and determine what output you are using for your speakers.... also you have to make sure that that corresponding button is depressed for those speakers.... also check you have the correct input selceted for your speakers and that no wires are crossed..... theres is probably notihng wrong with the speakers you just need to paly with your amp
Posted on Jun 18, 2009
  • 50 Answers
SOURCE: Yamaha RX-V463 Receiver Speaker Setup
That receiver has A and B channels. Look for the Speaker button and press it until B appears on the diplay. The other room speakers will play the same thing as in the main room.
Posted on Jul 05, 2009
  • 137 Answers
SOURCE: my kenwood 107VR keeps turning off on its own,
If you are sure your speakers are good. This unit has a protect circuit keeping the unit from turning on. This recevier uses an ic instead of output transistors. A ic incorperates transistors,resistors,capactors in one assembly for size and costs. There is a number right on the front of the ic ,you can go on-line to buy the ic is is fairly easy to put in as long as you can desolder and solder in.
Posted on Apr 17, 2010
dunnbiker
  • 8546 Answers
SOURCE: My Kenwood 107vr turns off
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 25, 2011
I have no sound coming out of my speakers for the reciever that is hooked up to my tv. i have 2 of the spekers hooked up and the audio cable plugged in to the tv but im getting no sound from the tv t
hi,try going into your tv setting and see if thers a setting for ext speaker as sometime ther is ,this is the place i would look and the only place i would think the fault would be ,you say audio cable i take it you mean
rca cables [two cables] if not check them but i dont think its both of them faulty,def in setting somewere.good luck
Jan 21, 2013 | Kenwood Audio Players & Recorders
My Kenwood 107vr turns off about 3 seconds after I turn it on. What could be wrong with it and how can I fix it?
Mar 25, 2011 | Kenwood 107VR
My kenwood kr v1074 reciever doesnt seem to do the job of my other reciever.....my sub is connected threw the red and black ports tried em all and my speaker just remains low volume even if i have it full...
You shouldn't hook things up and guess how they work.
BTW "KRV1074" doesn't bring up a valid link anywhere in the universe except your request.
Try finding the manual here...
http://www.kenwoodusa.com/ Use the Search box.
Mar 09, 2011 | Kenwood 107VR
Radio display says protect. does not emit sound.
Sounds like you have either a short in your speaker wire somewhere, wires touching in the back of the unit or a short inside the stereo itself... Try pulling the radio out and unhooking all of your speakers...Turn unit back on after all speakers are disconected...If unit still shows protect, then radio is bad...If it doesnt, power off and hook up speakers one by one and power it back on till it shows protect again....When it does, the last speaker wire you hooked up has either a crossed wire or the speaker is bad...
Oct 07, 2010 | Kenwood KDC-MP205 CD Player
Kenwood 107VR rec and No vol from Sub Output w/ menu Opt On
In the setup menu are the speakers set to large or small? On some receivers if you have it set to large all the bass is directed to the right-left fronts.
On my pioneer receiver if the speakers are set to large the sub-pre-out only works if the receiver is in a surround mode, if its in stereo mode and the speakers are set to large the sub-pre-out is dead. If the speakers are set to small the sub-pre-out works all the time.
Also, some receivers won't send a signal to the sub-pre-out if there is no LFE discreet signal info from the dolby digital or dts bitstreem.
For example I have several older dvd's that light up the L C R SL SR icons on my receiver, but don't light up the LFE icon. I have other older dvd's that just light up the L and R icons meaning they are only recorded in stereo like a vhs tape recorded in dolby surround.
In my basement I also have a kenwood dolby digital receiver.
I've noticed that when a dvd only lights up the left and right icons the pioneer will automatically switch to dolby pro logic surround. The kenwood will only send the signal to the left and right fronts (stereo). If I manually switch it (kenwood) to dolby pro logic I'll get sound from all the speakers just like the pioneer, but it does'nt do it by itself.
Most receivers that have a tape monitor won't work in surround mode with the tape monitor on. The pioneer will let me use the tape monitor with dolby pro-logic but won't pass through a dolby digital signal with the monitor on.
Hope this helps.
Apr 18, 2010 | Kenwood 107VR
My kenwood 107VR keeps turning off on its own, after about 3 secs it shuts off and the light blinks.
Apr 17, 2010 | Kenwood VR-209 Receiver
Do not hear the second click on speaker relay on kenwood KR-V5570 why?
I will assume no audio is coming out of your speakers.
When the reeciver starts up It looks at the load (resistance) of the speakers attached to see if it is reasonable. If It appears there are no shorts in the speakers then the speaker relay will close (second click) and send signal to your speakers. If there is no second click then either the the reciver is detecting a problem with speakers or cables or the detecting circuit has failed. I would start by disconecting all speakers then start the receiver up. If your not getting a second click after about 4 or 5 seconds then the receiver will need service. If it does click then shut receiver off, and hook up one speaker at a time, then re-start receiver. If one speaker suddenly makes the system fail then you have found your problem. If you have a Volt/Ohm meter, set it to resistance(Ohms) and measure each speaker. Anything Under 4 ohms will be a problem.
Good Luck
Apr 01, 2010 | Kenwood Audio Players & Recorders
Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Dec 30, 2008 | Kenwood VR-6070 Receiver
No sound from unit and everything is wired and hooked up properly tred every possible solution maybe i got a dud ???
Try pressinf the reset button (small black/grey one) that you would need a pencil to do,
Also kenwoods have a cup built in the audio ic to disconect sould if wires are touching together, although you may have it wired right a blown speaker will cause this problem, if thid did happen you would have to press the reset button to get sound after the problem was fixed, if none of this helps, i would sugest relpacing the audio IC'
Don
Jan 02, 2008 | Kenwood KDC-MP205 CD Player
Connecting subwoofer to receiver.
have u checked that the sub option on the reciver is on?
Jan 06, 2006 | Kenwood 107VR
Kenwood 107VR Logo
79 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
