Question about Brother DCP 130C All-In-One InkJet Printer
Brotherdcp-130c printer cannot get the magenta to print despite several cleaning and test printing
Brother DCP-130C is not printing and is refering me to the manual which is useless. It also says "Unit unable 43" .
Any help great! Cheers
Posted on Jul 27, 2008
Hello, I have problems with color printing with the DCP130C. First it printed no colors at all (even in the test print). Replaced cartridges - no change. After unplugging the mains cable for several...
If it is running on windows xp then you can log on into safe mode and remove the password from the admin account. Following are the steps listed to do so:
1. Turn on the computer and keep tapping F8 and it will show some options. 2. Select safe mode. 3. Log on using Admin. 4. Go to control panel by clicking start. 5. Then go to user accounts and remove the password from the account you are trying to log in with.
Jun 03, 2011 | Brother DCP 130C All-In-One InkJet Printer
When printing colour pictures they appear with greenish hue and there is no red at all...
For some reason it's not printing with the magenta ink. If you were out of that color it would tell you, so either all the magenta nozzles are clogged, or the printhead has gone bad.
At the top of the control panel is a button labeled Ink Management (or just Ink). Press that and choose Cleaning. Some machines will allow you to clean only certain colors - you want Magenta. When it's done, print a test page - also in the Ink Management menu. If it's improved, do it again until all the dots print for each color. Inkjet machines clean their nozzles by blasting them out with ink. If you're low on ink you should have spare cartridges ready to swap.
If no magenta prints at all, but the other colors are fine, your printhead has failed. If the machine is less than a year old it's a warranty repair, see Brother's website for the closest service center. If it's just past warranty, call Brother's customer service line and beg for a Work Order to be sent to a service center to cover your machine. Note that they will insist that your ink cartridges be genuine Brother brand before doing free repairs for ink problems.
If it's out of warranty, a repair would probably cost more than a new DCP 130C. Good luck.
Feb 15, 2011 | Brother DCP 130C All-In-One InkJet Printer
I have a brother DCP-135c printer. the magenta ink not printing
The process to get to the print head will take you approx. 1 hour. Without being trained on it, there is a high failure rate upon completion.
The Scanner assembly needs to be taken off. Harness Cables for the Scanner need to be removed.The Upper Case Assembly needs to be taken off. Printhead casing and printhead tubing calbes need to be removed, printhead mainboard needs to be removed, and then you have access to the printhead.
Thanks
Dec 19, 2009 | Brother MFC 420CN All-In-One InkJet...
MP830 Magenta not printing
same problem - rubbed the contacts with a clean paper toel, snapped it back in, worked fine.
Aug 19, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Blue (CYAN) not printing despite changing ink tank
enough ink b ut not printing at all - blank paper on every time despite noise as if printing
Aug 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Brother DCP-130C refuses to print the magenta ink
If you don't print at least once a month, you will clog the machine. You unfortunately have to get it fixed by a professional or get a new printer. Sorry!
Jun 14, 2008 | Brother DCP 130C All-In-One InkJet Printer
Will Not print magenta
hmmm...even on a test print page?
Feb 24, 2008 | Brother MFC-5440CN All-In-One InkJet...
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Aug 18, 2007 | Canon i860 InkJet Photo Printer
Brother DCP 130C not printing magenta and yellow
after replacing the ink cartridges it took several cleans to come good. I have no idea how to "manually" clean the heads. So I told the printer to do it many (about 7) times. It eventually worked
Aug 11, 2007 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP 130C All-In-One InkJet Printer Logo
375 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
