Question about Aiwa Audio Players & Recorders
AIWA Xr M6 C.D player won't play
Hallo can you please advise?
The c.d Player on my Aiwa XR M6 won't play? thank you claire
4 Suggested Answers
  • 29 Answers
SOURCE: aiwa xr-ms5 cd recognition problem
If your player won't recognize a disc, make sure the CD is properly loaded and not scratched, and that the lens is clean. Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully. Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function. good luck :-)
Posted on Jan 11, 2006
  • 133 Answers
SOURCE: where do I get drive belts for a aiwa xr-m10
Try eBay, i've been looking for these on the internet, they sell kits (long and short variety), containing several pairs of different measures (about $7 per kit), and are supposed to fit various brands and models (including aiwa).
...a hint: a belt measure tells you the diameter of the circle formed by that belt
...another hint: old belts are loose, which means they are a bit longer than the new ones, so when you select the new belt from the kit, it should be a bit shorter than the one you removed from the deck (old belt - bigger circle, new belt - smaller circle).
I'm aware that not all aiwa models are the same, the one i was repairing a while ago had a double tape deck, each deck containing two belts, one long and one short, they were a bit tricky to change, but i didn't need to disassemble any of the mechanisms, i just had to remove both decks from the housing for easier access to the belts which required prior removal of the top cover and rear panel. After that it was some 4 to 6 screws and 4 connectors (just about half less in your case, i believe).
I can't tell what your unit looks like on the inside, but in my opinion aiwas are relatively easy to take apart, but then again, i could be wrong...
Hope this helps you get closer to a solution.
regards
3rq8 (Triarcuate)
Posted on Jul 17, 2009
SOURCE: tape deck won't open Aiwa XR-M55
I think the main drive belt is worn and I am going to buy a new one when I find a source.
Posted on Feb 26, 2010
  • 19 Answers
SOURCE: how do i open the speakers on Aiwa XR-EM50 CD
on most speakers like this you will Pry the Grille Off and the actual speaker drivers can be removed by loosening screws holding them in the enclosure.
Posted on Oct 26, 2010
Tip
Aiwa XR-DV370KN Region Free Fix
Aiwa XR-DV370KN DVD Player Region Free Fix
Would you like to unlock your Aiwa XR-DV370KN DVD Player to Region Free?
Follow these steps to unlock your Aiwa XR-DV370KN DVD Player:
  1. Press the Pause button on your remote control.
  2. Using your remote control enter the numbers 3, 1, 4, 1, 5 and 9.
  3. Press the 0 button on your remote control for Region Free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control.
  5. Power off your player and wait a few seconds.
  6. Power on your player.
Your Aiwa XR-DV370KN DVD Player is now Region Free.
I hope that helps.
on Apr 25, 2010 | Televison & Video
I cannot get the AM radio stations to play or the CDs to play on the AIWA XR-M10. FM stations come in fine.
as for the am radio you need to connect the am aerial to pick up am frequencies as for the cd player need a bit more info on that
Oct 14, 2010 | Aiwa XR-M10 Shelf System
Resseting the preset channels
Please download user manual of Aiwa XR-MN5 from here. This will help you to set new stations presets.
Oct 11, 2008 | Aiwa CA-DW235 Boombox
AIWA XR-EM20 CD player
dude, u dont have the instructions?
Usually with the c button u can do everything..with the b one u shoose and the a one u save.
Aug 20, 2008 | Aiwa XR-M88 Shelf System
I connected an external MD to Aiwa XR-EM220 but it doesnt work...
If I remember correctly its the button on the front that says AUX, if not then check with the website and find out for sure http://www.us.aiwa.com/default.asp?page=support&browse=yes&cat=7
Feb 29, 2008 | Audio Players & Recorders
Aiwa xr-ms5 cd recognition problem
Jan 06, 2006 | Aiwa XR-MS5 CD Shelf System
125 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
