Question about ViewSonic VX2235wm LCD Monitor
Display A vertical green line appears on screen
  • 1,183 Answers
HI,
Disconnect the monitor from the computer and check if the vertical line still appears on the screen . If yes the monitor needs to be replaced.
Generally all viewsonic screens come with 3 yr warranty and you can call them up for repairs or replacements .
Thanks
Proton
Posted on Jul 26, 2008
1 inch red and green lines in a strip across top third of tv
Id start by replacing the tcon board, its the small board generally at the top of the set. sometimes under a metal cover
Nov 27, 2017 | Vizio Televison & Video
Lines on display, numerous horizontal, 3 vertical
This problem is caused by a defective LCD display. It is a common problem too. The only way to repair it is to replace the LCD display.
Dec 20, 2012 | Garmin nuvi 1450 GPS Receiver
My eee pc suddenly had screen problem a week ago--- when it boots up the screen is solid fluorescent green, then as Win XP starts there wide vertical bands appear, and finally what i'm left with is an...
I just had a smilar problem with the vertical lines and resolved it by disabling the display adapter, the display driver was corrupted, and i am using it to type right now and no problems. Go to the device manager and disable the disp0lay driver by right clicking on it and selecting un9install and restart. I could hardly see through the lines but I did it and it worked. Windows automatically comes with drivers from many manufacturers for many devices and it seemed it has one for mine and it worked as my display adapter is still disabled but my graphics are perfect....All the best!
Aug 17, 2010 | Computers & Internet
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
Vertical lines appear permanently on the screen
your display is going out you can contact Dell for a replacement.
Nov 01, 2009 | Dell Inspiron 2200 Notebook
Green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green line on each side of the plasma display.
Anybody knows how to reapair about vertical color- stripped lines appeared on screens and some trace of greenish images exist after each images changing, my TV is Toshiba Plasma Color 42HP83, I appreciate , thanks
Jun 05, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Lines on tv screen
Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
Vertical line at the left of the picture
Replace L506 on A board, replacement part number 1-407-366-00
Nov 26, 2007 | Televison & Video
Green picture tube fluid
If this fluid is gone, it has to be leakinfg out of the tube from bad seals on the tube. This fliuid can be purchaced from MCM electronics. What you are looking for is here: http://www.mcminone.com/search.asp?keyword=&restrict=3830007 Good luck
Jun 09, 2007 | Akai PTH5498 54" Rear Projection...
ViewSonic VX2235wm LCD Monitor Logo
318 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
